Ok I made it work, but the shape isn't still perfect, now I veryfied in Octave. Basically none of the Q definitions work well here. In 44k sampling rate, it mostly looks ok, when the selected frequency is below say 10k. Above it the shape starts getting "thin", maybe not as normal filter, but still a lot. Also when Q < 0.4, it starts doing really weird stuff. For example when using Q = 0.05 and moving the frequency accross the spectrum, the "thickness" of the peak filter is getting up and down, more or less waving. It looks to me like the approximation of the requested gain in Nyquist may not be right. Any ideas? jungledmnc
How to create peak/shelf filters, that are symmetric close to nyquist?
Started by ●November 3, 2011
Reply by ●November 10, 20112011-11-10
On 11/10/11 8:28 PM, jungledmnc wrote:> Ok I made it work, but the shape isn't still perfect, now I veryfied in > Octave. >lessee... what did i say? On 11/3/11 11:05 PM, robert bristow-johnson wrote: > > but there is no way to make it perfect because the slope of the gain > function at Nyquist must necessarily be 0 for a digital filter (and it > isn't for the analog prototype). >> Basically none of the Q definitions work well here.how are you defining Q? in terms of apparent BW? like this: 1/Q = 2*sinh( ln(2)/2 * BW * w0/sin(w0) ) BW in octaves or by some other definition? is scaling up bandwidth (however you're defining it) by w0/sin(w0) sufficient? maybe not so when w0 gets really, really close to Nyquist?> In 44k sampling rate, > it mostly looks ok, when the selected frequency is below say 10k. Above it > the shape starts getting "thin", maybe not as normal filter, but still a > lot. Also when Q < 0.4, it starts doing really weird stuff.consider what the corresponding BW is. what happens if the bandedge on the right exceeds Nyquist? would you expect "normal"?> For example when using Q = 0.05how wide is BW when Q = 0.05?> and moving the frequency across the spectrum, the > "thickness" of the peak filter is getting up and down, more or less waving. > It looks to me like the approximation of the requested gain in Nyquist may > not be right. Any ideas?maybe set it to be a little higher gain (assuming boost) than what Orfanidis does. jungle, you're pushing the edges a little here. expect wierdisms or change Fs to 96 kHz (from which the regular old cookbook works fine even at around 20 kHz). -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
On 11/10/11 8:23 AM, Rune Allnor wrote:> > Matlab& clones usually take a lot of beating in this > forum, so for once I will praise it: > > This is exactly the kind of thing matlab (or octave or > scilab or...) was invented for!fine, so then what's The MathWorks excuse for doing such a bad job of it?> You, the user, reads some document about some ethod > and want to try it. Instead of diving deep into C or > Fortran or assembler or whatever straight away, you > first use matlab (or octave or scilab or...) to check > that you get the computations right. >before i had access to MATLAB (i have never purchased it), i wrote a quickie little C program for my Mac that would plot the graph of whatever real function i could define in C. i would have to recompile the "f.c" file, link, and run. this worked very nicely with Lightspeed C (later to become THINK C, still later Semantec C, then death at the hands of Code Warrior), just open the project, type in an equation and run. i had FFT (it was before the FFTW days) and some audio in and out utilities (AIFF and WAV). the compile time was negligible (compared to 0 for an interpreted language like MATLAB). execution time was very fast. and the DC bin is X[0]. i do not denigrate the need or purpose of MATLAB. i am fully 100% critical of their indexing scheme; mostly that the index base is hard-wired (where even the array dimensions are not hard-wired). if MATLAB has a function called "reshape()", why can't it have a function called "reorigin()" or "rebase()"? there is no good reason why not and the fact that after decades they *still* put the DC bin into X(1) means they haven't gotten it. that cannot ever be considered "right". -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Reply by ●November 11, 20112011-11-11
On Nov 10, 6:41 pm, robert bristow-johnson <r...@audioimagination.com> wrote:> ... > > i do not denigrate the need or purpose of MATLAB. i am fully 100% > critical of their indexing scheme; mostly that the index base is > hard-wired (where even the array dimensions are not hard-wired).Actually, the dimensions are hardwired. The first dimension is 1. You've re-whined this so many times your abstractions are blurring.> if > MATLAB has a function called "reshape()", why can't it have a function > called "reorigin()" or "rebase()"?It could, but then there would be users writing C in Matlab as well as Fortan in Matlab, when the point of a language like Matlab is to avoid low level code whenever posible, not facilitate it.> there is no good reason why not and > the fact that after decades they *still* put the DC bin into X(1) means > they haven't gotten it. that cannot ever be considered "right". >It has been and always will be right for Matlab's primary marketing audience, unless you can convince all authors from Wikipedia to Golub and van Loan to teach 'Matrix Computations' in zero base index. The Mathworks also has the right idea that they wouldn't be getting any more subscription payments from whiney old C programmers on comp.dsp if they had done things differently. Dale B. Dalrymple
On 11/11/11 2:30 AM, dbd wrote:> On Nov 10, 6:41 pm, robert bristow-johnson<r...@audioimagination.com> > wrote: >> ... >> >> i do not denigrate the need or purpose of MATLAB. i am fully 100% >> critical of their indexing scheme; mostly that the index base is >> hard-wired (where even the array dimensions are not hard-wired). > > Actually, the dimensions are hardwired.actually, no they're not. that's what the reshape() function changes. your array can be changed from 2x6 to 3x4 or to 12x1. these limits are checked by MATLAB every single time that arrays (or "matrices" if you want) are added or multiplied or when individual elements are accessed. so the upper limit can be assigned, why not the lower limit (besides the fact that MATLAB deigns not to provide this functionality).> The first dimension is 1. > You've re-whined this so many times your abstractions are blurring. >it should have been obvious, when they were developing the Signal Processing Toolbox (or the fft() function) that when DC goes into X(1), when the results of the fft() or of conv() come out *wrong* (at least differently than any textbook and the published lit), *something* should have been nagging the consciousness of Cleve Moler that something wasn't quite right. and they could have fixed this and be perfectly backward compatible. Dale, if this argument was at comp.soft-sys.matlab, you might have friends, but the comp.dspers have long ago figured this out.>> if >> MATLAB has a function called "reshape()", why can't it have a function >> called "reorigin()" or "rebase()"? > > It could, but then there would be users writing C in Matlab as well as > Fortan in Matlab, when the point of a language like Matlab is to avoid > low level code whenever posible, not facilitate it.oh, so when using MATLAB, it "facilitates" us having to subtract 1 from the index when we start doing math on it, and when our math is done and we come up with another index, we have to add 1 before using it. such "facility", such "utility".> >> there is no good reason why not and >> the fact that after decades they *still* put the DC bin into X(1) means >> they haven't gotten it. that cannot ever be considered "right". >> > > It has been and always will be right for Matlab's primary marketing > audience,really? i wonder if more EEs doing signal processing use MATLAB than any other single group. the Signal Processing Toolbox was the very first toolbox that they came out with (in the early 1990s). we may not be the majority of users, but i'll bet that EEs are the plurality.> unless you can convince all authors from Wikipedia to Golub > and van Loan to teach 'Matrix Computations' in zero base index.you still haven't gotten it, Dale. can you spell "backward compatible"?> The > Mathworks also has the right idea that they wouldn't be getting any > more subscription payments from whiney old C programmers on comp.dsp > if they had done things differently.it's a losing argument if merit is the basis. but if corporate inertia is the basis, you win. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
>> Basically none of the Q definitions work well here. > >how are you defining Q? in terms of apparent BW? like this: > > 1/Q = 2*sinh( ln(2)/2 * BW * w0/sin(w0) ) BW in octaves > >or by some other definition? > >is scaling up bandwidth (however you're defining it) by w0/sin(w0) >sufficient? maybe not so when w0 gets really, really close to Nyquist?I think the definition of Q is actually the problem. To be honest, I know nothing about this, so I'm just messing with definitions other people invented. Btw. is there some paper about this? Just something to understand the basics. Anyway I tried these: const double Dw = Q * w0 / msin(w0); const double Dw = 2 * w0 * msinh( (msin(w0)/w0) * masinh (1/(2*Q))); const double Dw = masinh(0.5/Q) * (2/mln(2.0)) * w0 / msin(w0); const double Dw = msin(w0) / (2*Q); None of them work well. Changing frequency changes the bandwidth too, except for the last one, where it works more or less fine, but when the frequency gets close to nyquist, the shape gets "thin" again. But in most cases I can change the Q to make it look good again, so I think the whole trouble here is to find the good Dw definition. Any ideas?>consider what the corresponding BW is. what happens if the bandedge on >the right exceeds Nyquist? would you expect "normal"?Ideally the bandwidth would still be the same, so that in log view the shape doesn't change much when changing frequency. It is possible, several implementations use that.>> For example when using Q = 0.05 > >how wide is BW when Q = 0.05?With Q = 0.05, SR 44k, the filter affect the whole relevant range from 20 to 20k with any frequency. It's kinda extreme, but with does the same thing with lower Q as well, it's just less visible.>jungle, you're pushing the edges a little here. expect wierdisms or >change Fs to 96 kHz (from which the regular old cookbook works fine even >at around 20 kHz).I know, but the whole idea is to make it good even with lower sampling rates such as 44k. And I know it is possible, just don't know how :(. jungledmnc
On 11/11/11 3:43 PM, jungledmnc wrote: ...>> jungle, you're pushing the edges a little here. expect wierdisms or >> change Fs to 96 kHz (from which the regular old cookbook works fine even >> at around 20 kHz). > > I know, but the whole idea is to make it good even with lower sampling > rates such as 44k. And I know it is possible, just don't know how :(. >*what* is it that you know is possible, and how or why do you know that it's possible? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
> >*what* is it that you know is possible, and how or why do you know that >it's possible? > >That there are several software plugins that implement it without oversampling (for instance Ozone 5, IIEQ...). It's not exactly perfect, but it almost perfectly keeps the peak filter shape across the spectrum. jungledmnc
Reply by ●November 12, 20112011-11-12
On 11/11/11 9:26 PM, jungledmnc wrote:>> >> *what* is it that you know is possible, and how or why do you know that >> it's possible? >> >> > > That there are several software plugins that implement it without > oversampling (for instance Ozone 5, IIEQ...). It's not exactly perfect, but > it almost perfectly keeps the peak filter shape across the spectrum. >well, maybe they're using a higher order IIR, or maybe they're using an FIR (and the FIR need not be linear phase), or maybe they're using a combination like a biquad with an FIR "fixing it", but if it's a basic 2nd-order IIR (a biquad either in straight-forward Direct 1 or in the state-variable or some other topology), there are only 5 numbers you can play around with. and no matter how it's done (if it ain't oversampled), the *slope* of the gain function must be 0 at Nyquist. the curve has to start leveling off at frequencies just below Nyquist. you cannot beat that without moving Nyquist to a higher frequency, which is oversampling. so, i'm telling you, jungle, there are limits with what you can do with 5 knobs and the standard biquad. this (and the Orfanidis thingie) came up several times in different contexts at the last AES convention. and i was sorta surprized. one reason (for being surprized) is, for the 5-coefficient biquad, i thought that Knud Christianson of TC electronic has done in the previous decade a generalization of the 2nd-order peaking and shelving filters (with there are 4 degrees of freedom not counting constant gain). that's a total of 5 degrees of freedom; 5 coefficients, sounds like a totally solved mathematical problem to me. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
>well, maybe they're using a higher order IIR, or maybe they're using an >FIR (and the FIR need not be linear phase), or maybe they're using a >combination like a biquad with an FIR "fixing it", but if it's a basic >2nd-order IIR (a biquad either in straight-forward Direct 1 or in the >state-variable or some other topology), there are only 5 numbers you can >play around with. > >and no matter how it's done (if it ain't oversampled), the *slope* of >the gain function must be 0 at Nyquist. the curve has to start leveling >off at frequencies just below Nyquist. you cannot beat that without >moving Nyquist to a higher frequency, which is oversampling. >Yes, actually the filters in all the mentioned software all have "0 slope" at Nyquist and I'm ok with that. And the Orfanidis filter looks suspiciously similar! The only trouble is how the filter reacts to different frequency/Q combinations. With all frequencies (at least so far) I can find a Q (or rather Dw), which makes it look correct. So I think all it needs is a good Dw definition. Unfortunately that's exactly what I don't know anything about :(... jungledmnc
