Hi, I'm trying to design a high-pass filter to filter out DC component (bias) from a noisy accelerometer measurement. I've tried to go with a second order Butterworth filter with coefficients from http://www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html. The filtering works just fine, but the filter has a non-linear phase shift, so I don't know if that's the right choice. I'd also like to go with a higher order filter than this. The problem is, higher order filters designed with the above site are not stable, so they generally wind up. Is there a way to design a high-pass filter with cut-off frequency of about 0,5-1Hz without phase shift (or with small negative shift) in the pass band? I'd appreciate some practical links/examples. Thanks and regards, Tom
High-pass filter without phase shift
Started by ●November 14, 2011
Reply by ●November 15, 20112011-11-15
On Nov 15, 4:27�pm, "futureignobel" <futureignobel@n_o_s_p_a_m.gmail.com> wrote:> Hi, > > I'm trying to design a high-pass filter to filter out DC component (bias) > from a noisy accelerometer measurement. I've tried to go with a second > order Butterworth filter with coefficients fromhttp://www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html. The filtering > works just fine, but the filter has a non-linear phase shift, so I don't > know if that's the right choice. I'd also like to go with a higher order > filter than this. > The problem is, higher order filters designed with the above site are not > stable, so they generally wind up. Is there a way to design a high-pass > filter with cut-off frequency of about 0,5-1Hz without phase shift (or with > small negative shift) in the pass band? I'd appreciate some practical > links/examples. > > Thanks and regards, > Tomwhy not subtract the bias? Or does it vary with time?
On Mon, 14 Nov 2011 21:27:15 -0600, "futureignobel" <futureignobel@n_o_s_p_a_m.gmail.com> wrote:>Hi, > >I'm trying to design a high-pass filter to filter out DC component (bias) >from a noisy accelerometer measurement. I've tried to go with a second >order Butterworth filter with coefficients from >http://www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html. The filtering >works just fine, but the filter has a non-linear phase shift, so I don't >know if that's the right choice. I'd also like to go with a higher order >filter than this. >The problem is, higher order filters designed with the above site are not >stable, so they generally wind up. Is there a way to design a high-pass >filter with cut-off frequency of about 0,5-1Hz without phase shift (or with >small negative shift) in the pass band? I'd appreciate some practical >links/examples. > >Thanks and regards, >Tom >Hello Tom, I'm not sure it will help you, but you might have a look at: http://www.dsprelated.com/showarticle/58.php Good Luck, [-Rick-]
futureignobel wrote:> I'm trying to design a high-pass filter to filter out DC component (bias) > from a noisy accelerometer measurement. I've tried to go with a second > order Butterworth filter with coefficients from > http://www-users.cs.york.ac.uk/~fisher/mkfilter/trad.html.First mistake: don't use some junk from the net.> The filtering works just fine,If it works fine, what else do you need?> but the filter has a non-linear phase shift,And this is a problem why?> so I don't know if that's the right choice.Then you have to decide what is the right choice.> I'd also like to go with a higher order filter than this.What for?> The problem is, higher order filters designed with the above site are not > stable, so they generally wind up.Second mistake: don't use some junk from the net.> Is there a way to design a high-pass > filter with cut-off frequency of about 0,5-1Hz without phase shift (or with > small negative shift) in the pass band?Yes. But I doubt you will like it.> I'd appreciate some practical > links/examples.A practical example? Subtract a rolling average calculated over the span of 1 second from your initial signal.> Thanks and regards, > TomI'll send you a bill. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
