I tried to run this experiment in MATLAB: numberOfSamples = 80; sampleBlock = randn(1,numberOfSamples); counter = 1; for numberOfZeros = numberOfSamples:2000 x = [sampleBlock zeros(1,numberOfZeros-numberOfSamples)] ; y = filter(H,1,x); G1 = abs(fft(y,2*length(x))); G2 = abs(fft(x,2*length(x))).*abs(fft(H,2*length(x))); numberOfZerosVector(counter) = numberOfZeros; varianceOfError(counter) = var(G1-G2); counter = counter + 1; end figure plot(numberOfZerosVector,varianceOfError) It looks like I have to zero pad the sampleBlock with around 2000 zeros before G2 is approximately equal to G1 ? (H has 4001 filter coefficients). My general question is: If we have two known time series x and y and we know that y is obtained by filtering x with some unknown FIR filter coefficients H of known length N, how do we best approximate the spectrum of y as a product of the spectra of x and H ?
FFT question
Started by ●January 29, 2012
Reply by ●January 29, 20122012-01-29
On Jan 29, 5:25�pm, Mauritz Jameson <mjames2...@gmail.com> wrote:> I tried to run this experiment in MATLAB: > > numberOfSamples = 80; > sampleBlock = randn(1,numberOfSamples); > counter = 1; > for numberOfZeros = numberOfSamples:2000 > x = [sampleBlock zeros(1,numberOfZeros-numberOfSamples)] ; > y = filter(H,1,x); > G1 = abs(fft(y,2*length(x))); > G2 = abs(fft(x,2*length(x))).*abs(fft(H,2*length(x))); > > numberOfZerosVector(counter) = numberOfZeros; > varianceOfError(counter) = var(G1-G2); > > counter = counter + 1; > end > figure > plot(numberOfZerosVector,varianceOfError) > > It looks like I have to zero pad the sampleBlock with > around 2000 zeros before G2 is approximately equal to > G1 ? (H has 4001 filter coefficients). > > My general question is: > > If we have two known time series x and y and we know that y is > obtained by filtering x with > some unknown FIR filter coefficients H of known length N, how > do we best approximate the spectrum of y as a product of the spectra > of x and H ?The answer is in the question is it not? Y(w)=X(w).H(w)
That's one answer. I was wondering if there is a better way of approximating Y when your FFT signal buffer is small but your unknown FIR filter might have a lot of taps?
On Sun, 29 Jan 2012 13:37:27 -0800, Mauritz Jameson wrote:> That's one answer. I was wondering if there is a better way of > approximating Y > when your FFT signal buffer is small but your unknown FIR filter might > have a lot of taps?You are playing fast and loose with terminology, probably because you are confused about the relationship between the discrete Fourier transform (the FFT is a way to _realize_ the DFT), and the discrete-_time_ Fourier transform. The discrete Fourier transform either works on sampled data vectors of finite length, or on sampled data vectors that are one cycle of an infinitely long, perfectly repeating sequence (which one it is depends on your background, and is the subject of an infinitely long flame war on this group). The discrete-time Fourier transform works on signals that are sampled in time and are infinitely long. Each of the two transforms has a spectra: the DFT (FFT) has a spectrum that is of finite length and that comes in discrete samples. The discrete time Fourier transform has a spectra that is finite length (2 pi radians), and is continuous (not discrete) over that length. When you invoke Matlab's "filter" function, it is assuming that you are asking it to filter a finite length sample of an infinite length signal, and it truncates the result in time. Taking the FFT of the resulting finite-length sample is an exact process (not an approximation), but the result is an approximation of a discrete-time Fourier transform, because the finite-length sample is but an approximation of the infinite-length signal that the 'filter' function (and your spectra) assume. So, you have three choices: Keep everything in the sampled-time, finite length domain, keep everything in the sampled-time, infinite length domain, or accept that you are making approximations when you cross from one domain to another, and take steps to understand the approximation you're making and to minimize the deleterious effects of doing so. To keep everything in the sampled-time, finite length domain, you must use a filter function that performs a circular convolution on a finite- length sample. This will make it 'fit' with the FFT, but it won't mean much in real life (unless you're wondering what your filter will do to a periodic signal with the period you've given it). You're really operating in the discrete-time domain with signals of infinite (or practically infinite) extent. So to do the analysis "properly" you should use the discrete-time Fourier transform (which pretty much means that you need to solve everything symbolically). What you're _trying_ to do is to take the third path, and use the FFT for a signal in the discrete-time (but not finite-extent) world. Fortunately, this is fairly easy to do if your signal and your filter are both of finite extent: take your signal and pad it with as many zeros as your FIR filter has taps, and take your FIR filter impulse response and pad it with as many zeros as your signal has duration (I'd pad both with extra zeros, to reassure myself that I didn't screw anything up, and maybe to bring things up to some 2^N length). Now do your whole FFT thing the way you're doing it. Because it's a _finite_ impulse response filter and a _finite_ signal, you can rest assured that the filter output will be finite, and no longer than the signal duration plus the filter length: any extra zero-padding would just get you more zeros. Doing it this way, with adequate zero padding, will give you a theoretically exact answer: any mismatch between a convolution of filter and signal, vs. the ifft of the product of the spectra, will be due to finite numerical precision in the calculation, not fundamental theoretical errors in what you are doing. Of course, if either your filter or your signal is of infinite extent, then you need to approximate them by truncation, and you're back to needing to understand what you're doing. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com
