HI All, I am an engg student doing a project on FFT. Now I am in the process of learning DSP.I am stuck with a problem related to the calculation of PSD. Could anybody please help me out ?? I have got a 16 point FFT Processor.Now after FFT Processiing I do have 16 complex o/ps which are in the frequency domain.I have to calculate the PSD over these points. How do i do that ? I should not use MATLAB for this. I have to write the code in VHDL. I downloaded some material which says that After FFT processing I have to calculate the Power which is the square of the samples, then divide it by the sampling freuency. Some other documents says that If I take the squre of the o/p samples, I will get the PSD. So I am confused over this. Thanks in advance. Saumya
PSD Calculation
Started by ●December 8, 2003
Reply by ●December 8, 20032003-12-08
saumyajit_tech@yahoo.co.in (Saumyajit) wrote in message news:<9d5c33e7.0312080518.6d08d5e9@posting.google.com>...> HI All, > I am an engg student doing a project on FFT. Now I am in the process > of learning DSP.I am stuck with a problem related to the calculation > of PSD. Could anybody please help me out ?? > I have got a 16 point FFT Processor.Now after FFT Processiing I do > have 16 complex o/ps which are in the frequency domain.I have to > calculate the PSD over these points. How do i do that ? I should not > use MATLAB for this. I have to write the code in VHDL. > I downloaded some material which says that After FFT processing I have > to calculate the Power which is the square of the samples, then divide > it by the sampling freuency. > Some other documents says that If I take the squre of the o/p samples, > I will get the PSD. So I am confused over this.First, you have to find the documentation of your FFT routine. Formally, the Discrete Fourier Transform (DFT) is defined as something like 1 N-1 2pi nk X(k) = ------- sum x(n) exp(-j-------- ) sqrt(N) n=0 N and the Inverse DFT as 1 N-1 2pi nk x(n) = ------- sum X(k) exp( j-------- ). sqrt(N) k=0 N Note the 1/sqrt(N) factor that pops out in both formulas. The FFT/IFFT routines usually "simplify" the transforms by dividing by N in either the forward or inverse transform. Matlab does, for instance, not scale the sum at all in the forward transform but divides by N in the inverse transform. You have to make sure that you skale the DFT with 1/sqrt(N). As for scaling with the frequency, we usually want the PSD estimate in terms of physichal, not normalized, frequency. So when you have an N-point DFT, it spans a physical bandwidth of Fs Hz (Fs is sampling frequency) and its frequency bins are dF= Fs/N wide. You want a power spectral *density* estimate that relates to the physical world, so you want to know how much power each frequency bin represents. Remember, power spectral density relates to how much power is found inside a given bandwidt, so you need to multiply the coefficient in each bin with the bandwidth of the bin, dF. These scaling factors are often skipped (or treated very sloppy) since people often are content with finding an estimate for the shape of the spectrum, and do not necessarily care too much about the numbers. Rune
Reply by ●December 13, 20032003-12-13
Saumyajit wrote:> HI All, > I am an engg student doing a project on FFT. Now I am in the process > of learning DSP.I am stuck with a problem related to the calculation > of PSD. Could anybody please help me out ?? > I have got a 16 point FFT Processor.Now after FFT Processiing I do > have 16 complex o/ps which are in the frequency domain.I have to > calculate the PSD over these points. How do i do that ? I should not > use MATLAB for this. I have to write the code in VHDL. > I downloaded some material which says that After FFT processing I have > to calculate the Power which is the square of the samples, then divide > it by the sampling freuency. > Some other documents says that If I take the squre of the o/p samples, > I will get the PSD. So I am confused over this. > > Thanks in advance. > > SaumyaYou need the nearest approximation which is called the periodogram - found as follows. Suppose X(k) are the FFT frequency samples found in the usual way (with no division by N or sqrt(N) by the way). Then the periodogram is mag(X(k))^2/N where mag is the sqrt(real^2+imag^2) ie the usual modulus of a complex number. Here we square it and divide by N, the number of FFT points. There is another way you can do it if you know X(k). You can do this P(i)=P(i-1)*beta+(1-beta)*X(k)*X'(k) where X'(k) is the complex conjugate of X(k) at FFT frame i and beta is a forgetting factor 0<beta<1 the choice of which needs a little experimenting with. P(i) is the periodogram at FFT frame i. The forgetting fact beta should be close to unity for good smoothing and perhaps nearer to 0.6? if you need good tracking ie the data is highly non-stationary like speech. If it is staionary data then a beta close to unity will make the periodogram 'converge' to the PSD. Tom
