Simple convolution and fft
Started by Les Cargill ●March 20, 2012
Suppose I have
A
    10.000
    10.000
B
    10.000
    10.000
and C
   100.000
   200.000
   100.000
where C = CONVOLUTION(A,B)
Taking the FFT of each:
A'
  {   20.000,    0.000 },
  {    0.000,    0.000 },
B'
  {   20.000,    0.000 },
  {    0.000,    0.000 },
C'
  {  400.000,    0.000 },
  {    0.000, -200.000 },
  {    0.000,    0.000 },
  {    0.000,  200.000 },
Given A' and B', how do I produce C' from them directly?
Les Cargill
"Les Cargill"  wrote in message news:jkb7ma$2hl$1@dont-email.me...
Suppose I have
A
    10.000
    10.000
B
    10.000
    10.000
and C
   100.000
   200.000
   100.000
A'
  {   20.000,    0.000 },
  {    0.000,    0.000 },
B'
  {   20.000,    0.000 },
  {    0.000,    0.000 },
C'
  {  400.000,    0.000 },
  {    0.000,    0.000 },
  {    0.000,  200.000 },
Les Cargill
When you take the FFT, the time function is assumed to be repeated so you’re
A and B would give a
C
200
200
200
Which would give a C'
{400,0}
{0,0}
{0,0}
   Best wishes,
   --Phil Martel
On 3/20/2012 5:34 PM, Les Cargill wrote:
> Suppose I have > A > -------------------------------------- > 10.000 > 10.000 > B > -------------------------------------- > 10.000 > 10.000 > and C > -------------------------------------- > 100.000 > 200.000 > 100.000 > > where C = CONVOLUTION(A,B) > > Taking the FFT of each: > > A' > -------------------------------------- > { 20.000, 0.000 }, > { 0.000, 0.000 }, > B' > -------------------------------------- > { 20.000, 0.000 }, > { 0.000, 0.000 }, > C' > -------------------------------------- > { 400.000, 0.000 }, > { 0.000, -200.000 }, > { 0.000, 0.000 }, > { 0.000, 200.000 }, > > Given A' and B', how do I produce C' from them directly? > > -- > Les Cargill > >
Les, ????? The convolution of a and b that you compute is a linear, not circular, convolution. A circular convolution would be [200 200]. If you want to use circular convolution then you need to extend a and b to N + M -1 or 2+2-1=3 each at a minimum. This gives: a = [10 10 0] b = [10 10 0] c= [100 200 100] Now, you can use the FFT and multiply. af=fft(a) = fft(b) = bf 20.00000000000000 5.00000000000000 + 8.66025403784439i 5.00000000000000 - 8.66025403784438i af*bf = cf = 1.0e+002 * 4.00000000000000 -0.50000000000000 + 0.86602540378444i -0.50000000000000 - 0.86602540378444i which is has real part even and imaginary part odd so its transform will be real. ci=ifft(cf)= 1.0e+002 * 1.00000000000000 + 0.00000000000000i 2.00000000000000 + 0.00000000000000i 1.00000000000000 - 0.00000000000000i Where you got those -200 values I have no idea!! Anyway, doing circular convolution takes just a bit of care. Fred
Hoo boy! Wait till r b-j sees this :-)
On 3/21/12 10:02 PM, dvsarwate wrote:
> On Mar 20, 9:49 pm, "Phil Martel"<pomar...@comcast.net> wrote: > >> When you take the FFT, the time function is assumed to be repeated > > Hoo boy! Wait till r b-j sees this :-) >
well, i guess you wouldn't *have* to assume it. it's a free country (at least it was until January 2009 when we became a socialist dictatorship). but if you don't assume it, you might get something unexpected when convolving or shifting. if the words "convolution" and "FFT" appear together in any context, i think the safe assumption is that the data is periodically extended. but if you don't *do* anything with your FFT other than scale by a constant or add, then, i guess, it doesn't matter. but then why bother with the FFT if all you're doing is to scale and add? -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
Fred Marshall wrote:
> On 3/20/2012 5:34 PM, Les Cargill wrote: >> Suppose I have >> A >> -------------------------------------- >> 10.000 >> 10.000 >> B >> -------------------------------------- >> 10.000 >> 10.000 >> and C >> -------------------------------------- >> 100.000 >> 200.000 >> 100.000 >> >> where C = CONVOLUTION(A,B) >> >> Taking the FFT of each: >> >> A' >> -------------------------------------- >> { 20.000, 0.000 }, >> { 0.000, 0.000 }, >> B' >> -------------------------------------- >> { 20.000, 0.000 }, >> { 0.000, 0.000 }, >> C' >> -------------------------------------- >> { 400.000, 0.000 }, >> { 0.000, -200.000 }, >> { 0.000, 0.000 }, >> { 0.000, 200.000 }, >> >> Given A' and B', how do I produce C' from them directly? >> >> -- >> Les Cargill >> >> > > Les, > > ?????
Agreed! I am confused on this.
> The convolution of a and b that you compute is a linear, not circular, > convolution. A circular convolution would be [200 200]. >
Right. I want a simple, linear convolution.
> If you want to use circular convolution then you need to extend a and b > to N + M -1 or 2+2-1=3 each at a minimum. > This gives: > a = [10 10 0] > b = [10 10 0] > c= [100 200 100] > > Now, you can use the FFT and multiply. > af=fft(a) = fft(b) = bf > 20.00000000000000 > 5.00000000000000 + 8.66025403784439i > 5.00000000000000 - 8.66025403784438i > > af*bf = cf = > > 1.0e+002 * > 4.00000000000000 > -0.50000000000000 + 0.86602540378444i > -0.50000000000000 - 0.86602540378444i > which is has real part even and imaginary part odd so its transform will > be real. > > ci=ifft(cf)= > > 1.0e+002 * > 1.00000000000000 + 0.00000000000000i > 2.00000000000000 + 0.00000000000000i > 1.00000000000000 - 0.00000000000000i > > Where you got those -200 values I have no idea!!
That is what fftw calculated as the FFT of the vector { 100, 200, 100 } And indeed - the -200 values confuse me no end.
> Anyway, doing circular convolution takes just a bit of care. > > Fred
-- Les Cargill
On 3/22/2012 10:30 AM, Les Cargill wrote:
> That is what fftw calculated as the FFT of the vector { 100, 200, 100 } > And indeed - the -200 values confuse me no end.
Maybe we should consider that "it's what Les got when he used FFTW" .. :-) Fred
> On 3/22/2012 10:30 AM, Les Cargill wrote: >> That is what fftw calculated as the FFT of the vector { 100, 200, 100 } >> And indeed - the -200 values confuse me no end. > > Maybe we should consider that "it's what Les got when he used FFTW" .. :-) > > Fred
True enough - but it's eminently repeatable, I'm doing all the appropriate initializations... the reverse FFT comes out the same as the original... -- Les Cargill
Ach - found that one. It agrees with the results form Octave -- Les Cargill
On 3/23/2012 10:50 AM, Les Cargill wrote:
> Fred Marshall wrote: >> On 3/22/2012 10:30 AM, Les Cargill wrote: >>> That is what fftw calculated as the FFT of the vector { 100, 200, 100 } >>> And indeed - the -200 values confuse me no end. >> >> Maybe we should consider that "it's what Les got when he used FFTW" .. >> :-) >> >> Fred > > > Ach - found that one. It agrees with the results form Octave > > -- > Les Cargill
You mean that Octave is wrong too??? Fred
