Hey guys. So far, I've posted on a forum and a mailing list with no results, and only= just realized it's probably best to ask this question on a DSP-specialized= group. (Sorry that my first post is a question >_<) I'm developing a high-fidelity, high-compression format [64:17 compression]= that uses linear prediction to smooth the waves and 4bit error correction = [with a scalar per frame] to keep the sound closer to the original. It is m= ade specifically for internet-friendly transmission of sound banks (think D= LS files, but VERY much simplified). The idea is to use up to 16 linear prediction models that best describe the= original sound data What I'm doing at the moment is: -Break data up into sample frames [32 samples per frame] -Compute linear prediction coefficients for each frame and save -After I have all coefficients, merge all sets together into 16 sets by i= terating through all the original coefficients and finding the most closely= -related one in the target [16] ones. Pseudo-code: srcCoef =3D Source coefficients dstCoef =3D Target coefficients (assumed to be 0 initialized) numSrcCoef =3D Number of source coefficients (variable, depends on file) numDstCoef =3D Number of destination coefficients (16) for(i =3D 0 ; i < numSrcCoef ; i++) { bestPos =3D 0; bestRelation =3D 0; for(j =3D 0; j < numDstCoef ; j++) { // find relation // dot(x,y) returns the normalized dot product // I'm using abs instead of acos because they both // decay and have no practical difference in calculating // the highest value relation =3D abs(dot(srcCoef[i], dstCoef[j])); // find best relation if(relation > bestRelation) bestPos =3D j, bestRelation =3D relation; } // average coefficients dstCoef[bestPos] +=3D srcCoef[i]; dstCoef[bestPos] /=3D 2; } I'm not entirely sure I'm doing the last step correctly. What would you guys do to optimize the hundreds [sometimes a couple of thou= sand] coefficient pairs into a maximum of 16?
Linear prediction optimization?
Started by ●April 23, 2012
