Hi all, I am working on a fixed-point FFT based application. The Input to FFT is a real signal while the FFT Core is Complex (a.k.a it can take real and imaginary inputs). Normally, one would tie the real signal to real input of the core and the imaginary input to zero. In order to optimize the resources, I want to use the complex input of the FFT Core efficiently. According to articles I found on the website, you can use split the input data into two streams and combine the outputs of the FFT. http://processors.wiki.ti.com/index.php/Efficient_FFT_Computation_of_Real_Input This all seems great for floating point. I am curious as what would be the rounding issues if the FFT Core is fixed-point core. The core I am using outputs unscaled fixed-point output. Any insights or suggestions into the problem are welcome. Thanks, rakumarudu
Fixed-Point FFT
Started by ●June 11, 2012
Reply by ●June 12, 20122012-06-12
rakumarudu <kalyanramu@n_o_s_p_a_m.gmail.com> wrote:> I am working on a fixed-point FFT based application. > The Input to FFT is a real signal while the FFT Core is Complex (a.k.a it > can take real and imaginary inputs). Normally, one would tie the real > signal to real input of the core and the imaginary input to zero. In order > to optimize the resources, I want to use the complex input of the FFT Core > efficiently.> According to articles I found on the website, you can use split > the input data into two streams and combine the outputs of the FFT.Well described in "Numerical Recipes in C" (and probably others).> This all seems great for floating point. I am curious as what > would be the rounding issues if the FFT Core is fixed-point core.I believe the results should be pretty much the same. It transforms the data from N real points to N/2 complex points, applies the complex FFT, then fixes up the result. You should be able to go through the math for small N, such as 4, and see what it really does. Because of the way the FFT scales, it will work the same for larger N. -- glen
Hi Glen, From what I understand, there are some rounding issues in the final spectrum. I am no expert at this though.
rakumarudu <kalyanramu@n_o_s_p_a_m.gmail.com> wrote:>> According to articles I found on the website, you can use split the input >> data into two streams and combine the outputs of the FFT.Yes - the "2N point real FFT using an N point complex FFT" technique (sometimes called the "N point real FFT using an N/2 point complex FFT technique"). You split up the real input data into 2 half-sized arrays (r(0), r(2), r(4), ... etc., and r(1), r(3), r(5), ... etc.; then use the even (half-sized) array as your real FFT inputs, and the odd (half-sized) array as your imaginary inputs, followed by some add/ subtract/twiddle manipulations to recombine the parts properly. Note that to perform the above, you also need to know how to do a related technique: "Two N point real points using an N point complex FFT." One reference for both of the above is: http://www.fftguru.com/fftguru.com.tutorial2.pdf And a TI reference: http://www.ti.com/lit/an/spra291/spra291.pdf (beware - I've seen another, earlier version of the TI paper that had a math error - the TI version also presumes a + exponent FFT - something you have to be careful about). Although the technique has been around since 1967 (Bingham, Godfrey, Tukey paper), there are different ways of implementing it, and they can affect your accuracy. For instance, in the TI version above, the author (Robert Matusiak) uses on the order of 8N multiplies and 6N adds, plus four N sized look- up tables. I have an improved version (not shown in the first link above), which uses on the order of 2N multiplies, 5N adds, and an N/2 sized look-up table (and it took many, many months to figure out how to do it). But I'm not sure you should be overly concerned about efficiency right now - I think you should work towards understanding and getting your algorithm performing correctly. A 'standard' way of doing it, even if it's not the best, is preferable to struggling with the technique - fixed point is difficult enough as it is. As for fixed point rounding errors - in general, the fewer operations, the better. There's a large literature about fixed point error analysis for FFT - I suggest you read as much of it as you can. You'll still have to scale, of course - to prevent overflow/ underflow. But I don't know what kind of guard bits or overflow circuitry your core is using - a lot will depend on the details of your processing. Kevin McGee
Reply by ●June 13, 20122012-06-13
