On Sat, 13 Oct 2012 00:01:00 +0200, Jeroen wrote:> On 2012-10-12 19:02, Tim Wescott wrote: >> On Fri, 12 Oct 2012 12:08:46 +0200, Jeroen Belleman wrote: >> >>> On 2012-10-12 11:04, Robert Baer wrote: >>>> Vladimir Vassilevsky wrote: >>>>> "Tim Wescott"<tim@seemywebsite.com> wrote: >>>>>> How commonly do you see PLL designs referred to as "type I", "type >>>>>> II", "type III", etc.? Do the terms make sense to you? >>>>> >>>>> IMO this terminology is used only in Gardner's book; there is no >>>>> universal >>>>> meaning. >>>>> It is about P, PI, or PII control loop. Remnants of old times, when >>>>> they used to mix the details of implementation with the type of the >>>>> transfer function. >>>>> >>>>>> I'm writing a report; don't want to either baffle with bullshit nor >>>>>> leave >>>>>> out handy terms... >>>>> >>>>> Since nobody is going to read it anyway, why would that matter? >>>>> >>>>> Vladimir Vassilevsky >>>>> DSP and Mixed Signal Consultant >>>>> www.abvolt.com >>>>> >>>>> >>>> Do not know but my wild uneducated guess is that "P" stands for >>>> regular feedback as in a standard op-amp circuit, "PI" stands for >>>> first derivative (eg: "P dot") and "PII" stands for second derivative >>>> (eg: "P double dot"). >>>> >>>> >>>> >>> 'I' stands for an Integral term, not a derivative one. >>> >>> I think that PLL designs should be classified by the number of >>> significant poles and zeroes of their transfer functions. This 'type' >>> business only introduces an extra layer of obscurity. >> >> Both the number of poles (order), and the number of nekkid integrators >> (type) have relevance in telling you how the loop is going to behave. > > Well yes, in essence that's what I said. We know what the poles and > zeroes do. Introducing superfluous terminology like 'type' does not make > it any clearer. I'd say: Drop the type.A type 0 loop can have a bazillion poles and still be type 0. A type 2 loop can have only two poles. Poles and type are _different_. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
PLL Terminology Question
Started by ●October 11, 2012
Reply by ●October 13, 20122012-10-13
On Sat, 13 Oct 2012 00:09:54 +0200, Jeroen wrote:> On 2012-10-12 19:05, Tim Wescott wrote: >> On Fri, 12 Oct 2012 08:39:21 -0700, John Larkin wrote: >> >>> On Fri, 12 Oct 2012 10:39:14 -0400, Randy Yates >>> <yates@digitalsignallabs.com> wrote: >>> >>>> Tim Wescott <tim@seemywebsite.com> writes: >>>> >>>>> How commonly do you see PLL designs referred to as "type I", "type >>>>> II", "type III", etc.? Do the terms make sense to you? >>>>> >>>>> I'm writing a report; don't want to either baffle with bullshit nor >>>>> leave out handy terms... >>>> >>>> Hi Tim, >>>> >>>> We used to use those terms in the 80s in our antenna control systems >>>> at GTE Government Systems. If I remember correctly, the "number" >>>> refers to the number of integrators in the loop. >>>> >>>> I don't think they are used much today. >>> >>> The question then becomes whether you count the inherent VCO phase >>> integration as one of those integrators. >> >> For any control loop you pick a point in the loop and go around, >> counting integrators, until you get back to the same point. Because >> the VCO takes a voltage and turns it into a frequency (which is the >> integral of phase), > > Harumph! Flub, phase is the integral of frequency. But you know that, of > course.Blargh. Indeedie. -- My liberal friends think I'm a conservative kook. My conservative friends think I'm a liberal kook. Why am I not happy that they have found common ground? Tim Wescott, Communications, Control, Circuits & Software http://www.wescottdesign.com
On 2012-10-12, Jim Thompson <To-Email-Use-The-Envelope-Icon@On-My-Web-Site.com> wrote:> > Poles are from Poland. What are zeroes? >Zeroes were manufactured by Mitsubishi. -- ⚂⚃ 100% natural --- news://freenews.netfront.net/ - complaints: news@netfront.net ---
On 10/12/2012 12:42 PM, Jim Thompson wrote:> On Fri, 12 Oct 2012 09:29:55 -0700 (PDT), George Herold > <gherold@teachspin.com> wrote: > >> On Oct 11, 4:36 pm, Tim Wescott<t...@seemywebsite.com> wrote: >>> How commonly do you see PLL designs referred to as "type I", "type II", >>> "type III", etc.? Do the terms make sense to you? >>> >>> I'm writing a report; don't want to either baffle with bullshit nor leave >>> out handy terms... >>> >>> -- >>> My liberal friends think I'm a conservative kook. >>> My conservative friends think I'm a liberal kook. >>> Why am I not happy that they have found common ground? >>> >>> Tim Wescott, Communications, Control, Circuits& Softwarehttp://www.wescottdesign.com >> >> Nice thread, thanks Tim. >> >> I assume "Phaselock Techniques" by Flyod M. Gardener is the right >> book. (Making my Xmas wish list.) Any advantage of the third edition >> over the second? >> >> So in a type III system the error signal is integrated twice? >> Does anyone have an example where double integration is used? >> It doesn't have to be a PLL application any type of control loop would >> be fine. >> >> George H. > > The extra filter/integrator is usually placed above the zero dB > cross-over, just to reduce noise. > > ...Jim ThompsonNo, it's another lead-lag integrator, to reduce the static phase offset due to a frequency ramp to zero. Back in the all-analogue days, that sometimes mattered. Cheers Phil Hobbs -- Dr Philip C D Hobbs Principal Consultant ElectroOptical Innovations LLC Optics, Electro-optics, Photonics, Analog Electronics 160 North State Road #203 Briarcliff Manor NY 10510 hobbs at electrooptical dot net http://electrooptical.net
Jasen Betts wrote:> > On 2012-10-12, Jim Thompson <To-Email-Use-The-Envelope-Icon@On-My-Web-Site.com> wrote: > > > > Poles are from Poland. What are zeroes? > > > > Zeroes were manufactured by Mitsubishi.And used to attack Pearl Harbor.
On Sat, 13 Oct 2012 07:23:37 -0400, Phil Hobbs <pcdhSpamMeSenseless@electrooptical.net> wrote:>On 10/12/2012 12:42 PM, Jim Thompson wrote: >> On Fri, 12 Oct 2012 09:29:55 -0700 (PDT), George Herold >> <gherold@teachspin.com> wrote: >> >>> On Oct 11, 4:36 pm, Tim Wescott<t...@seemywebsite.com> wrote: >>>> How commonly do you see PLL designs referred to as "type I", "type II", >>>> "type III", etc.? Do the terms make sense to you? >>>> >>>> I'm writing a report; don't want to either baffle with bullshit nor leave >>>> out handy terms... >>>> >>>> -- >>>> My liberal friends think I'm a conservative kook. >>>> My conservative friends think I'm a liberal kook. >>>> Why am I not happy that they have found common ground? >>>> >>>> Tim Wescott, Communications, Control, Circuits& Softwarehttp://www.wescottdesign.com >>> >>> Nice thread, thanks Tim. >>> >>> I assume "Phaselock Techniques" by Flyod M. Gardener is the right >>> book. (Making my Xmas wish list.) Any advantage of the third edition >>> over the second? >>> >>> So in a type III system the error signal is integrated twice? >>> Does anyone have an example where double integration is used? >>> It doesn't have to be a PLL application any type of control loop would >>> be fine. >>> >>> George H. >> >> The extra filter/integrator is usually placed above the zero dB >> cross-over, just to reduce noise. >> >> ...Jim Thompson > >No, it's another lead-lag integrator, to reduce the static phase offset >due to a frequency ramp to zero. Back in the all-analogue days, that >sometimes mattered. > >Cheers > >Phil Hobbs...Jim Thompson -- | James E.Thompson, CTO | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona 85048 Skype: Contacts Only | | | Voice:(480)460-2350 Fax: Available upon request | Brass Rat | | E-mail Icon at http://www.analog-innovations.com | 1962 | I love to cook with wine. Sometimes I even put it in the food.
On Sat, 13 Oct 2012 07:23:37 -0400, Phil Hobbs <pcdhSpamMeSenseless@electrooptical.net> wrote:>On 10/12/2012 12:42 PM, Jim Thompson wrote: >> On Fri, 12 Oct 2012 09:29:55 -0700 (PDT), George Herold >> <gherold@teachspin.com> wrote: >> >>> On Oct 11, 4:36 pm, Tim Wescott<t...@seemywebsite.com> wrote: >>>> How commonly do you see PLL designs referred to as "type I", "type II", >>>> "type III", etc.? Do the terms make sense to you? >>>> >>>> I'm writing a report; don't want to either baffle with bullshit nor leave >>>> out handy terms... >>>> >>>> -- >>>> My liberal friends think I'm a conservative kook. >>>> My conservative friends think I'm a liberal kook. >>>> Why am I not happy that they have found common ground? >>>> >>>> Tim Wescott, Communications, Control, Circuits& Softwarehttp://www.wescottdesign.com >>> >>> Nice thread, thanks Tim. >>> >>> I assume "Phaselock Techniques" by Flyod M. Gardener is the right >>> book. (Making my Xmas wish list.) Any advantage of the third edition >>> over the second? >>> >>> So in a type III system the error signal is integrated twice? >>> Does anyone have an example where double integration is used? >>> It doesn't have to be a PLL application any type of control loop would >>> be fine. >>> >>> George H. >> >> The extra filter/integrator is usually placed above the zero dB >> cross-over, just to reduce noise. >> >> ...Jim Thompson > >No, it's another lead-lag integrator, to reduce the static phase offset >due to a frequency ramp to zero. Back in the all-analogue days, that >sometimes mattered. > >Cheers > >Phil HobbsIn _modern_ times. I've not heard that before and I'm wa-a-a-ay older than you. Analog phase detectors locked at 90�. Although you seem actually to be implying more loop gain?? ...Jim Thompson -- | James E.Thompson, CTO | mens | | Analog Innovations, Inc. | et | | Analog/Mixed-Signal ASIC's and Discrete Systems | manus | | Phoenix, Arizona 85048 Skype: Contacts Only | | | Voice:(480)460-2350 Fax: Available upon request | Brass Rat | | E-mail Icon at http://www.analog-innovations.com | 1962 | I love to cook with wine. Sometimes I even put it in the food.
On Fri, 12 Oct 2012 09:29:55 -0700 (PDT), George Herold <gherold@teachspin.com> wrote:>On Oct 11, 4:36�pm, Tim Wescott <t...@seemywebsite.com> wrote: >> How commonly do you see PLL designs referred to as "type I", "type II", >> "type III", etc.? �Do the terms make sense to you? >> >> I'm writing a report; don't want to either baffle with bullshit nor leave >> out handy terms... >> >> -- >> My liberal friends think I'm a conservative kook. >> My conservative friends think I'm a liberal kook. >> Why am I not happy that they have found common ground? >> >> Tim Wescott, Communications, Control, Circuits & Softwarehttp://www.wescottdesign.com > >Nice thread, thanks Tim. > >I assume "Phaselock Techniques" by Flyod M. Gardener is the right >book. (Making my Xmas wish list.) Any advantage of the third edition >over the second? > >So in a type III system the error signal is integrated twice? >Does anyone have an example where double integration is used? >It doesn't have to be a PLL application any type of control loop would >be fine. > >George H.I am a fan of the D-flop bang-bang phase detector. It has, in theory, an infinite phase-error gain, which makes it interesting to analyze. That's the way to go if you want to lock an oscillator to an external input with picosecond long-term stability. -- John Larkin Highland Technology Inc www.highlandtechnology.com jlarkin at highlandtechnology dot com Precision electronic instrumentation Picosecond-resolution Digital Delay and Pulse generators Custom timing and laser controllers Photonics and fiberoptic TTL data links VME analog, thermocouple, LVDT, synchro, tachometer Multichannel arbitrary waveform generators
On Fri, 12 Oct 2012 23:28:28 -0500, Tim Wescott <tim@seemywebsite.com> wrote:>On Sat, 13 Oct 2012 00:09:54 +0200, Jeroen wrote: > >> On 2012-10-12 19:05, Tim Wescott wrote: >>> On Fri, 12 Oct 2012 08:39:21 -0700, John Larkin wrote: >>> >>>> On Fri, 12 Oct 2012 10:39:14 -0400, Randy Yates >>>> <yates@digitalsignallabs.com> wrote: >>>> >>>>> Tim Wescott <tim@seemywebsite.com> writes: >>>>> >>>>>> How commonly do you see PLL designs referred to as "type I", "type >>>>>> II", "type III", etc.? Do the terms make sense to you? >>>>>> >>>>>> I'm writing a report; don't want to either baffle with bullshit nor >>>>>> leave out handy terms... >>>>> >>>>> Hi Tim, >>>>> >>>>> We used to use those terms in the 80s in our antenna control systems >>>>> at GTE Government Systems. If I remember correctly, the "number" >>>>> refers to the number of integrators in the loop. >>>>> >>>>> I don't think they are used much today. >>>> >>>> The question then becomes whether you count the inherent VCO phase >>>> integration as one of those integrators. >>> >>> For any control loop you pick a point in the loop and go around, >>> counting integrators, until you get back to the same point. Because >>> the VCO takes a voltage and turns it into a frequency (which is the >>> integral of phase), >> >> Harumph! Flub, phase is the integral of frequency. But you know that, of >> course. > >Blargh. Indeedie. >I get that backwards all the time, too. I don't know why. Eric Jacobsen Anchor Hill Communications www.anchorhill.com
On Fri, 12 Oct 2012 09:29:55 -0700 (PDT), George Herold <gherold@teachspin.com> wrote:>So in a type III system the error signal is integrated twice? >Does anyone have an example where double integration is used? >It doesn't have to be a PLL application any type of control loop would >be fine.Different loop types exhibit different error characteristics. A Type-0 loop (no integrator) has position error. A Type-1 loop has no position error. A Type-2 loop has no position or velocity error. A Type-3 loop has no position, velocity, or acceleration error. The references to error here refer to steady-state conditions.
