Equalizer - How to do?
Started by Karmas Lin November 13, 2003
Hi all,
I want to find a way to do the "Equalizer" (similar to equipment on audio
amplifier) using software (maybe C or others) on PC, should I use the filter
bank technique? Or can I simply use FFT and just change amplitude of
frequency components, then take inverse FFT? Is there open source or on-line
guide for implementing a equalizer?
Any suggestion are appreciated, thanks in advance!
Karmas
yer welcome ....
http://www.musicdsp.org/files/biquad.c
http://www.harmony-central.com/Computer/Programming/Audio-EQ-Cookbook.txt
http://www.harmony-central.com/Effects/Articles/Equalization/
sdj
Karmas Lin wrote:
> Hi all, > > I want to find a way to do the "Equalizer" (similar to equipment on audio > amplifier) using software (maybe C or others) on PC, should I use the filter > bank technique? Or can I simply use FFT and just change amplitude of > frequency components, then take inverse FFT? Is there open source or on-line > guide for implementing a equalizer? > > Any suggestion are appreciated, thanks in advance! > > Karmas > >
