Multiband Amplitude Compression in Freq. Domain
Started by aaab ●December 17, 2012
Dear all,
I would like to get started on Multiband Amplitude Compression in
the Frequency Domain. So basically I would like to do the processing
like Compression of the signal on frequency spectra (bins).
Can anybody suggest any links or references from where I could
get an understanding of how can I do it ?
Thanks in advance,
AV.
"aaab" <52020@dsprelated> wrote in message
news:E5OdnXuCVY7pYlPNnZ2dnUVZ_o2dnZ2d@giganews.com...
> Dear all, > > I would like to get started on Multiband Amplitude Compression in > the Frequency Domain. So basically I would like to do the processing > like Compression of the signal on frequency spectra (bins). > > Can anybody suggest any links or references from where I could > get an understanding of how can I do it ?
Dolby A noise reduction system: http://en.wikipedia.org/wiki/Dolby_noise-reduction_system Vladimir Vassilevsky DSP and Mixed Signal Consultant www.abvolt.com
http://www.proaudiodsp.com/
Hi Greg, Vladimir, et. al.,
Thanks for your replies.
I am seeking much more details in terms of
the core algorithm and sound pressure measurement to be used.
Regards,
AV.
>http://www.proaudiodsp.com/ >
>Dear all, > >I would like to get started on Multiband Amplitude Compression in >the Frequency Domain. So basically I would like to do the processing >like Compression of the signal on frequency spectra (bins). > >Can anybody suggest any links or references from where I could >get an understanding of how can I do it ? > >Thanks in advance, >AV. >
I can imagine that a book (if such a book actually exists) on designing hearing aids would be of interest. cheers
Am 17.12.12 12:18, schrieb aaab:
Postfish is an excellent audio processing software which includes a multi-band compander and is open source: http://svn.xiph.org/trunk/postfish/ Look into this file http://svn.xiph.org/trunk/postfish/multicompand.c Unfortunately, it doesn't work on modern Linux boxes. I could get it compiled and running on an Ubuntu 8.04 virtual machine, though. It would be great to see an updated port to use it on modern OSes. Christian
On Tuesday, December 18, 2012 11:35:25 PM UTC-6, aaab wrote:
> I am seeking much more details in terms of > the core algorithm and sound pressure measurement to be used.
I think you'll find that (1) there aren't very many, and (2) the few that do exist are proprietary and thus not much info is available about them. Greg
What is your motivation? (Answers to that, both personally and algorithmically may enable and motivate more useful responses.)
> > Can anybody suggest any links or references from where I could > get an understanding of how can I do it ? >
http://www.rehab.research.va.gov/jour/93/30/1/pdf/kollmeier.pdf http://www.ti.com.cn/cn/lit/an/spra657/spra657.pdf http://nemertes.lis.upatras.gr/jspui/bitstream/10889/2391/1/ThesisSESE.pdf http://ticet.iitb.ac.in/ticet/publications/Long%20Term%20Research%20Projects/kulkarni_pandey_jangamashetti_July09.pdf Dale B. Dalrymple
Dear all,
Thanks for your posts. I will refer to them and get back
in case I have more queries.
Regards,
AV.
Hi all,
When I use different number of samples to do the fft,
I get fft spectra values which are different in value.
So say I have a tone at 1500 Hz at sampling frequency of 20000 Hz
of 1 second duration.
First I take only the first 512 samples and find the fft.
Then I take only the first 1024 samples of the same input and
find the fft. The maximum absolute value of these two ffts are found to be
different.
Please let me know what can I do to ensure that fft spectra values can
be compared irrespective of the number of samples taken for fft (or window
length).
Here is the sample Matlab code for illustration.
For compression in the frequency domain I need to address this issue.
>>t= [1:20000];s = 0.999 * sin(2 * pi * 1500/20000 * t);
>> s2 = s(1:512); fft_s2 = fft(s2); plot(abs(fft_s2));
>> s3 = s(1:1024)); fft_s3 = fft(s3); plot(abs(fft_s3));
It is seen that max(abs(fft_s2)) is different from max(abs(fft_s2)) since number of samples are different. But I want to be able to compare or get a relation between these values irrespective of the number of samples used for fft. Thanks and regards, AV
