Hi When a speech or audio signal is sent through a GSM or CDMA cellular phone, what is the maximum audio frequency that is encoded by the codec? For example, 4kHz is considered as the cutoff for a plain old telephone system. GSM uses a CELP based encoder (?) ,so the number may be related to the standard. Any approximate figures would be appreciated. TIA, Siddharth
signal bandwidth for cellular networks
Started by ●October 30, 2003
Reply by ●October 30, 20032003-10-30
Hello Siddharth, Actually 4kHz is a real hard cutoff for POTS lines. They usually roll off at 3.2 or 3.4 kHz. Cellular vocoders aren't very different from POTS lines in their frequency response limits Clay . "Siddharth Mathur" <smathur@removethis.softhome.net> wrote in message news:bnrf7q$l9j$1@oasis.ccit.arizona.edu...> Hi > > When a speech or audio signal is sent through a GSM or CDMA cellularphone,> what is the maximum audio frequency that is encoded by the codec? For > example, 4kHz is considered as the cutoff for a plain old telephonesystem.> GSM uses a CELP based encoder (?) ,so the number may be related to the > standard. Any approximate figures would be appreciated. > > TIA, > Siddharth > >
