Is there anyway to capturing the speaker-out-sound( not from microphone)? Any Library, or Win-API welcomed. Thanks.
Sound Capturing
Started by ●October 26, 2003
Reply by ●October 27, 20032003-10-27
use DirectX 9, instead of calling a method like Play(*mysoundbuffer) that will write the sound to a "soundcard buffer" ... you will call a method Write(*mysoundbuffer, filename) that will take the same sound and write it to a file .... this is essentially "capturing" the sound out. see code examples from the DirectX 9 SDK. http://msdn.microsoft.com/library/default.asp?url=/nhp/default.asp?contentid=28000410 best, sdj kiplring wrote:> Is there anyway to capturing the speaker-out-sound( not from microphone)? > > Any Library, or Win-API welcomed. > Thanks.
