Does anybody know of a software tool or package that can take in an audio recording of a fax call, and extract the image that is being faxed? Thanks
Fax software tools
Started by ●September 10, 2003
Reply by ●September 10, 20032003-09-10
Mike wrote:> > Thank you very much. > > Monteria looks like they have what I am looking for. I will have to > contact them and see if the price is reasonable. > (http://www.monteriallc.com/index.htm) > > If anybody else knows of similar products, please let me know.I never thought anything that simple would be so complicated. I should know better :-) Patience, persistence, truth, Dr. mike -- Mike Rosing www.beastrider.com BeastRider, LLC SHARC debug tools
Mike Rosing wrote:> > Mike wrote: > > Does anybody know of a software tool or package that can take in an > > audio recording of a fax call, and extract the image that is being > > faxed? > > Why not just feed it to a fax machine? Or a sound card with fax-modem > software? You already have the signal, just feed it to things that can > deal with it.That won't work. Fax transmissions start with a handshake, including a training sequence. IIRC, the training sequence is there for the answering-end to equalize the line. If the training sequence fails, the calling-end can choose another baud rate/modulation scheme. In a recording, the answering-end has no opportunity to influence the calling-end. Also, IIRC, both the tx and the rx communicate in the same band, so you'd need a four wire (2-channel) tap to separate the calling and answering ends of the conversation. If you have recorded both halves of the conversation seperately, you MIGHT be able to play some games. Basically, you have to tx some stuff and listen for the answerer to finish responding. When it finishes, you can tx the next bit of the conversation. If you blindly play the tx-end back, you will find that the timing is off, and the whole thing falls apart. Third party processing is a LOT more difficult than when your equipment is a party to the call. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 Unix IS user friendly. It's just more particular about its friends.
Jim Thomas wrote:> > > > Does anybody know of a software tool or package that can take in an > > > audio recording of a fax call, and extract the image that is being > > > faxed? > > > > Why not just feed it to a fax machine? Or a sound card with fax-modem > > software? You already have the signal, just feed it to things that can > > deal with it. > > That won't work. > Fax transmissions start with a handshake, including a > training sequence.Agreed.> > Also, IIRC, both the tx and the rx communicate in the same band, so > you'd need a four wire (2-channel) tap to separate the calling and > answering ends of the conversation.The fax protocols are communicating half-duplex. You don't have to separate the transmit and the receive sides.> Third party processing is a LOT more difficult than when your equipment > is a party to the call.I can develop such software, however it is going to be relatively big project. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
"Jim Thomas" <jthomas@bittware.com> wrote in message news:3F5F6564.F5F4FC90@bittware.com...> Mike Rosing wrote: > > > > Mike wrote: > > > Does anybody know of a software tool or package that can take in an > > > audio recording of a fax call, and extract the image that is being > > > faxed? > > > > Why not just feed it to a fax machine? Or a sound card with fax-modem > > software? You already have the signal, just feed it to things that can > > deal with it. > > That won't work. Fax transmissions start with a handshake, including a > training sequence. IIRC, the training sequence is there for the > answering-end to equalize the line. If the training sequence fails, the > calling-end can choose another baud rate/modulation scheme. In a > recording, the answering-end has no opportunity to influence the > calling-end. > > Also, IIRC, both the tx and the rx communicate in the same band, so > you'd need a four wire (2-channel) tap to separate the calling and > answering ends of the conversation. > > If you have recorded both halves of the conversation seperately, you > MIGHT be able to play some games. Basically, you have to tx some stuff > and listen for the answerer to finish responding. When it finishes, you > can tx the next bit of the conversation. If you blindly play the tx-end > back, you will find that the timing is off, and the whole thing falls > apart.I haven't looked at fax modem standards for a while, but I don't think they use the same band. The transmission rates are asymmetrical, so they either use a narrow band in the reverse direction, or half duplex, but I forget which. -- glen
Glen Herrmannsfeldt wrote:> I haven't looked at fax modem standards for a while, but I don't think they > use the same band. The transmission rates are asymmetrical, so they either > use a narrow band in the reverse direction, or half duplex, but I forget > which.Yeah, I think you're right. I last looked at this in 1988, so it has been a while. Now that I think about it, I'm pretty sure they use different FSK frequencies, and I THINK it's full-duplex. I do know we had to separate rx and tx in our recordings because the demod would get confused if it was presented with both sides of the "conversation." I guess that could be done with a filter easily enough though. We also had to demod enough of the answering signal so we'd know where we were in the handshake, and then we could pause and resume the playback of the calling signal at the right times. Luckily, the handshake is done with the least-common denominator modulation scheme. But I distinctly recall that playing the signal back blindly did NOT work, even if it was to the same fax machine that took part in the original transmission. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (703) 779-7770 Unix IS user friendly. It's just more particular about its friends.
The machines that I have seen that do this from a recording required a digital recorder. The wow and flutter of the analog recorders was too much. Dirk Dirk A. Bell DSP Consultant "Mike" <mike_dsp@hotmail.com> wrote in message news:1911c5cf.0309100717.9d02fa8@posting.google.com...> Does anybody know of a software tool or package that can take in an > audio recording of a fax call, and extract the image that is being > faxed? > > Thanks
Reply by ●September 11, 20032003-09-11
"Glen Herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message news:rtK7b.411812$uu5.75263@sccrnsc04...> > "Jim Thomas" <jthomas@bittware.com> wrote in message > news:3F5F6564.F5F4FC90@bittware.com... > > Mike Rosing wrote: > > > > > > Mike wrote: > > > > Does anybody know of a software tool or package that can take in an > > > > audio recording of a fax call, and extract the image that is being > > > > faxed? > > > > > > Why not just feed it to a fax machine? Or a sound card with fax-modem > > > software? You already have the signal, just feed it to things thatcan> > > deal with it. > > > > That won't work. Fax transmissions start with a handshake, including a > > training sequence. IIRC, the training sequence is there for the > > answering-end to equalize the line. If the training sequence fails, the > > calling-end can choose another baud rate/modulation scheme. In a > > recording, the answering-end has no opportunity to influence the > > calling-end. > > > > Also, IIRC, both the tx and the rx communicate in the same band, so > > you'd need a four wire (2-channel) tap to separate the calling and > > answering ends of the conversation. > > > > If you have recorded both halves of the conversation seperately, you > > MIGHT be able to play some games. Basically, you have to tx some stuff > > and listen for the answerer to finish responding. When it finishes, you > > can tx the next bit of the conversation. If you blindly play the tx-end > > back, you will find that the timing is off, and the whole thing falls > > apart. > > I haven't looked at fax modem standards for a while, but I don't thinkthey> use the same band. The transmission rates are asymmetrical, so theyeither> use a narrow band in the reverse direction, or half duplex, but I forget > which. > > -- glen > >The ITU's T.30 Recommendation specifies the interaction between two Group 3 fax machines (which is the great majority of fax machines deployed in the real world). For these "legacy" fax machines (V.17 14400bps modulation rates and below), the protocol is entirely half-duplex, so they do use the same band - the voice band (300Hz - 3400KHz). For the handshaking part of the protocol, V.21 Channel 2 is specified (simpy FSK modulation at 1750Hz nominal freq.), while the actual transmission of the page data is done using whatever modulation was negotiated during the initial handshaking, negotiation and training phases of the call. To answer the original poster's question: yes, there exist companies out there that market fax analysis software. The two that I am familar with are Genoa (now owned by Quality Logic - see http://qualitylogic.com/genoa_test_tools/fax/products.html for their fax offerings), and Telegra (not even sure if they're in business anymore). I believe that you can use two ChannelProbes by Genoa to build a call around the page data you have captured, but I would contact their technical support for more information. By the way, this stuff isn't cheap. You could also conceivably set up a fax modem to demodulate the data you've captured, but you would have to issue it discrete commands to put it into the correct mode, which requires that you have a good working knowledge of T.30 as well as the command set for the modem you're using. Good luck, James
Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F5F734B.96F9C9AF@abvolt.com>...> Jim Thomas wrote: > > > > > > Does anybody know of a software tool or package that can take in an > > > > audio recording of a fax call, and extract the image that is being > > > > faxed? > > > > > > Why not just feed it to a fax machine? Or a sound card with fax-modem > > > software? You already have the signal, just feed it to things that can > > > deal with it. > > > > That won't work. > > Fax transmissions start with a handshake, including a > > training sequence. > > Agreed. > > > > > Also, IIRC, both the tx and the rx communicate in the same band, so > > you'd need a four wire (2-channel) tap to separate the calling and > > answering ends of the conversation. > > The fax protocols are communicating half-duplex. You don't have to > separate the transmit and the receive sides. > > > Third party processing is a LOT more difficult than when your equipment > > is a party to the call. > > I can develop such software, however it is going to be relatively big > project. > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.comThanks for the offer but I was hoping to find an existing tool that runs under Windows and has a reasonable cost. I actually have the expertise to develop this myself but as you said it is a big project, especially if you want to support error correction mode where portions of the image can be retransmitted. Getting the bits is fairly straight forward...it's knowing what to do with them that is the challenge. Mike
