Hi everybody, I am designing a decimation filter for a 16bit delta-sigma A/D. The decimator will be a CIC decimate by 16 filter, followed by two FIR filters to get the required attenuation. I have two questions as most of my experience is in analog & not digital design. 1- The filter order of the FIR filters is about 100 or 150, is this normal or too much?? 2- The multiplier seems to be the big problem area wise, is it wise to go for CSD or booth multiplier, or something else?? PS: Any hints to ready written VHDL code for FIR filters, or multipliers would be great. Kindly give your recommendations Your help is highly appreciated. Thanks
decimation filter (is this normal)??
Started by ●September 9, 2003
Reply by ●September 9, 20032003-09-09
Ahmad wrote:> > Hi everybody, > > I am designing a decimation filter for a 16bit delta-sigma A/D. The > decimator will be a CIC decimate by 16 filter, followed by two FIR > filters to get the required attenuation. I have two questions as most > of my experience is in analog & not digital design. > > 1- The filter order of the FIR filters is about 100 or 150, is this > normal or too much??It looks like too much. The reasonable order for the decimation FIR should be about several dozens. You should split the decimation into 2..3 stages. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●September 10, 20032003-09-10
Thnx, but plz take into consideration that the required stop band attenuation is 110DB. So, is this still too much? Also, kindly tell me which type of multiplier would u recommend to use. Thnx Vladimir Vassilevsky <vlv@abvolt.com> wrote in message news:<3F5DECF2.A8AA415@abvolt.com>...> Ahmad wrote: > > > > Hi everybody, > > > > I am designing a decimation filter for a 16bit delta-sigma A/D. The > > decimator will be a CIC decimate by 16 filter, followed by two FIR > > filters to get the required attenuation. I have two questions as most > > of my experience is in analog & not digital design. > > > > 1- The filter order of the FIR filters is about 100 or 150, is this > > normal or too much?? > > It looks like too much. The reasonable order for the decimation FIR > should be about several dozens. You should split the decimation into > 2..3 stages. > > Vladimir Vassilevsky > > DSP and Mixed Signal Design Consultant > > http://www.abvolt.com
