eric.jacobsen@ieee.org (Eric Jacobsen) wrote in message news:<4154bafa.61193656@news.west.cox.net>...> On Fri, 24 Sep 2004 17:38:57 -0500, Richard Owlett > <rowlett@atlascomm.net> wrote: > > >glen herrmannsfeldt wrote: > > > >> > >> > >> Richard Owlett wrote: > >> > >>> This is intentionally "dumb" question. > >>> I suspect a good answer will illuminate a fallacy in my thinking. > >> > >> > >>> assume a real input > >>> perform FFT > >>> set all bins to 0 that are outside pass band > >>> perform suitably scaled IFFT > >> > >> > >>> What's wrong with this picture? > >> > >> > >> It is as sharp as the number of points in the transform. > >> (The frequency resolution is 1/(total length of transform).) > >> > >> You need an infinite number of points for an infinitely > >> sharp cutoff. > >> > >> -- glen > >> > > > >Caution: I'm learning DSP by asking questions on this group > > > >I had gotten the impression there was another problem other than what > >may be considered "resolution issues'. > > You can implement a filter that way, and sometimes it's a fine thing > to do. Another thread here mentioned how this was used successfully > in some data processing, but subsequent use of a FIR with a sharp (but > not infinite) cutoff worked better.Well, there are two problems with 'brick wall' filters. First, the frequency responses are determined only at a finite number of frequencies, with the magnitude response left unspecified in between. Second, the transition band is exactly one frequency bin wide, which is un-necessary sharp in most situations, and causes extensive ringing in time domain. Whaich is the reason why one started using windowed FIR filters in the first place: The filter lengths are specified in terms of the allowable transition bands, and ripple is specified over the full band. Rune
Is "brick wall" filter realizable?
Started by ●September 24, 2004
Reply by ●September 26, 20042004-09-26
Richard Owlett wrote: (snip)> In my case I'm starting with speech recorded on CD under studio > conditions. I assume the signal was suitably low pass filtered before > sampling. I will playback the filtered signal using the original sample > rate. Would that make the effect moot or not? > > I doubt I'll would do a true "brick wall" but it is a worst case limit > of what I might do.I have wondered in past discussions how long it takes to do an FFT of a whole CD. The filter can't be sharper than 1/(length of data), but for a 60 minute CD that is about 0.0003Hz, close enough to brick wall for most of us. -- glen
Reply by ●September 27, 20042004-09-27
Richard Owlett wrote:> This is intentionally "dumb" question. > I suspect a good answer will illuminate a fallacy in my thinking. > > assume a real input > perform FFT > set all bins to 0 that are outside pass band > perform suitably scaled IFFT > > What's wrong with this picture?Thank you one and all. I've learned at least one thing. If wandering lost, ask about "degenerate" (spelling?) case. Responses will point out fallacious logic.
