Hi all. I am starting out on signal processing. Conceptionally I think I understand the advantages of pulse shaping and raised cosine. But I am not clear where this is used in practice. Is pulse shaping just used on purely digital transmission i.e. A pulse train. Or is it combined with digital to analog modulation. E.g. QPSK. Any help would be much appreciated. Thanks in advance Steve. _____________________________ Posted through www.DSPRelated.com
Pulse shaping and modulation.
Started by ●June 20, 2014
Reply by ●June 20, 20142014-06-20
On Fri, 20 Jun 2014 11:29:08 -0500, "D20gdx" <100621@dsprelated> wrote:>Hi all. I am starting out on signal processing. Conceptionally I think I >understand the advantages of pulse shaping and raised cosine. But I am not >clear where this is used in practice. Is pulse shaping just used on purely >digital transmission i.e. A pulse train. Or is it combined with digital to >analog modulation. E.g. QPSK. Any help would be much appreciated. >Thanks in advance >Steve.I'm not sure what you mean by digital to analog modulation, but QPSK is very commonly used, as are BPSK, 8PSK, and m-QAM, and all are generally applied with pulse shaping, usually with Square-Root-Raised-Cosine filters in both the modulator and demodulator. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
