I am starting to learn the DSP by using the Analog DSP. I am wondering which one is "best" - I do not have target application now. just for learning DSP. What I mean "best" is that the chip architecture is current, stable, widely used, easy use(?), and the support for the chip last longer - some chip might be outdated. TigerSharc? Sharc? - will be replaced by TigerSharc? Blackfin?
which is best?
Started by ●July 17, 2003
Reply by ●July 17, 20032003-07-17
Reply by ●July 24, 20032003-07-24
"yong" <yqin_99@yahoo.com> wrote in message news:be3c7875.0307170505.506cf2d3@posting.google.com...> I am starting to learn the DSP by using the Analog DSP. I am wondering > which one is "best" - I do not have target application now. just for > learning DSP. What I mean "best" is that the chip architecture is > current, stable, widely used, easy use(?), and the support for the > chip last longer - some chip might be outdated. > > TigerSharc? > Sharc? - will be replaced by TigerSharc? > Blackfin?As a fellow amateur, I found the ADSP-21065 to be a decent starting point. It is a floating point "SHARC" and it has nice C/C++ development tools and a cheap development board from ADI an also from other vendors. It seems to be positioned as a high-volume, low-end floating point chip for consumer audio. It is very active, so it is well supported and likely to stay around for a little while.
