Hi, I got CSS to work on an NT machine first time, but I cant seem to get it working on a Windows 2000 machine. My first problem was with the ports (LPT1). Even when I change the BIOS to EPP 378H, I was still seeing ECP under the ports section of the device manager. Anyway, I deleted this driver and installed a parallel port driver and reconfigured the port, and now I see LPT1 under the ports section. Unfortunately I still cant get CSS to work. I ran the ti port utilities ( Configure and Test ports) and I see what I see on my NT machine. I then power off and on the board and run the hardware reset, as I do when on NT. But when I run CSS, I see a message something like (which I dont see on NT) - *** C6x11 DSK (Texas Instruments)/CPU: The Startup GEL file was specified in the Startup Program for this processor, and will be used instead of the one specified on the command line. *** Then after a few seconds I get the error message - *** Failed Softwere Reset: Cannot reset the processor Exit - Retry - Cancel *** I click Retry, and I then get - *** Trouble Writing Target CPU memory: Processor accessing not ready memory at 0x1800000 Can't Initialize Target CPU This is a TI USCIF adapter library {Sourceless EPK] error. POD_ERR_MAP1 <-701> This error resulted from the first attemp to access the CPU hardware. The status from the DSK was erroneous. THe most common causes of this problem are: 1. No power to the DSK 2. THe cable is disconnected from the parallel port 3. THe DSK is locked up and requires a power cycle I/O port = 378 *** I also tried running cc_setup and importing EPP 378H, just before I ran CSS. When I ran CSS this time I again got errors, I clicked ignore and CSS opened. I then ran the GEL file "Check DSK". I saw the lights flash on the DSK, but then got the message - *** Trouble Writing to CPU memory: Timeout on Target Processor Please check cabling or multi-processor configuration It is recommended to RESET EMULATOR. This will disconnect each target, perform an emulation reset, and then reconnect each target. Reset Emulator - Cancel *** I'm using the C6711 DSK. Any suggestion as to how I figure out what the problem is? Thanks in advance, Barry.
CSS and Win2k
Started by ●July 12, 2003
Reply by ●July 13, 20032003-07-13
I've also tried setting the BIOS to AT, PS/2 and ECP, and I've selected SPP in cc_setup, and I'm still having no luck. Has anyone here managed to get CCS to work on Win2k? I'm really at the end of my tether with this, I might just format this PC tomorrow, and put Windows NT on it. bg_ie@yahoo.com (Barry) wrote in message news:<731cea69.0307121329.53e4c45d@posting.google.com>...> Hi, > > I got CSS to work on an NT machine first time, but I cant seem to get > it working on a Windows 2000 machine. > > My first problem was with the ports (LPT1). Even when I change the > BIOS to EPP 378H, I was still seeing ECP under the ports section of > the device manager. Anyway, I deleted this driver and installed a > parallel port driver and reconfigured the port, and now I see LPT1 > under the ports section. > > Unfortunately I still cant get CSS to work. I ran the ti port > utilities ( Configure and Test ports) and I see what I see on my NT > machine. I then power off and on the board and run the hardware reset, > as I do when on NT. But when I run CSS, I see a message something like > (which I dont see on NT) - > > *** > C6x11 DSK (Texas Instruments)/CPU: > The Startup GEL file was specified in the Startup Program for this > processor, and will be used instead of the one specified on the > command line. > *** > > Then after a few seconds I get the error message - > > *** > Failed Softwere Reset: > Cannot reset the processor > > Exit - Retry - Cancel > *** > > I click Retry, and I then get - > > *** > Trouble Writing Target CPU memory: > Processor accessing not ready memory at 0x1800000 > > Can't Initialize Target CPU > > This is a TI USCIF adapter library {Sourceless EPK] error. > > POD_ERR_MAP1 <-701> > > This error resulted from the first attemp to access the CPU hardware. > The status from the DSK was erroneous. THe most common causes of this > problem are: > > 1. No power to the DSK > 2. THe cable is disconnected from the parallel port > 3. THe DSK is locked up and requires a power cycle > > > I/O port = 378 > *** > > I also tried running cc_setup and importing EPP 378H, just before I > ran CSS. When I ran CSS this time I again got errors, I clicked ignore > and CSS opened. I then ran the GEL file "Check DSK". I saw the lights > flash on the DSK, but then got the message - > > *** > Trouble Writing to CPU memory: > Timeout on Target Processor > Please check cabling or multi-processor configuration > It is recommended to RESET EMULATOR. This will disconnect each target, > perform an emulation reset, and then reconnect each target. > > Reset Emulator - Cancel > *** > > I'm using the C6711 DSK. Any suggestion as to how I figure out what > the problem is? > > Thanks in advance, > > Barry.
Reply by ●July 14, 20032003-07-14
dear barry, i`m running a c6711-dsk on Win2k, without any problems. have you installed the last servicepack (sp4) ? hmmmm, you can change the settings for your parallel port interface to AT and PS/2 ?? sorry, but these are things which have nothing to do with the parallel interface..... EPP/SPP and ECP are different protocols for different devices like printer, scanner, etc..... perhabs change the bios on default settings and take a look at the settings for the lpt1-interface in the win2k-devicemanager. on my system there are "ECP-Printerconnection: IRQ 3, IO 0378-037F, 0778-077A" hope this helps........ sincerely, olaf lindner Barry wrote:> I've also tried setting the BIOS to AT, PS/2 and ECP,
