On Wed, 14 Jan 2015 13:34:45 GMT, N0Spam@daqarta.com (Bob Masta) wrote: <snip>> >The problem is that recognizing the presence or absence of a >human voice (or even recognizing the words!) doesn't help >with removing noise. It's not like you can say "aha, human >voice... now I'll just subtract out everything that *isn't* >a human voice." > >Best regards, > > >Bob Masta ><snip> I think if our language was more like dolphins or whales we'd have a much easier time coming up with a decomposition which would stick to our "voice" and not to the noise ;-) Mark
The Human Voice has been widely characterized, correct?
Started by ●January 11, 2015
Reply by ●January 14, 20152015-01-14
Reply by ●January 15, 20152015-01-15
On Wed, 14 Jan 2015 15:46:30 -0600, Ramon F Herrera <ramon@patriot.net> wrote:>On 1/14/2015 7:34 AM, Bob Masta wrote: >> The problem is that recognizing the presence or absence of a >> human voice (or even recognizing the words!) doesn't help >> with removing noise. It's not like you can say "aha, human >> voice... now I'll just subtract out everything that *isn't* >> a human voice." >> >> Best regards, >> >> >> Bob Masta >> > > >I respectfully beg to differ, Bob. Watch this Course: > >==================================================================== > >http://www.macprovideo.com/tutorial/izotope-rx4-audio-repair-toolbox-2 >(Free registration) > >Chapter 39. Deconstructing Tone & Noise > >The instructor claims: "It is as simple as it is amazing". > >Watch the introduction as well: > >http://play.macprovideo.com/izotope-rx4-audio-repair-toolbox-2/1 > >Jeff chose the analogy of salt getting into the food that he is cooking. >That problem can *theoretically* be solved! If we can take one molecule >at a time, we can leave the NaCl molecules out, and the rest of the >delicious the gumbo in. > >==================================================================== > >In this particular musical case the problem is not too hard: a pure-note >instrument (piano) PLUS (it is indeed an arithmetic addition) some low >frequency hum. > >Still: Sinusoids are added and subtracted.An adaptive algorithm can be trained to remove persistent sinusoids, but that doesn't work with noise, or in fact with most real-world signals. The reason is that the frequencies and amplitudes are constantly changing... that's what constitutes "noise", and also what constitutes "speech". There isn't some specific waveform to be subtracted out, or frequency to be filtered out.>I am sure that in the not too distant future we will be able to take the >provided Dealey Plaza audio, inform the system: > > - There is a helicopter, which sounds like this [...] > - There is a screeching train which sounds like this [...] > - There is a crying baby who sounds like this [...] > - Finally, there is the voice in which I am interested. [...]>My initial mistake was assuming that all "noise" was garbage that could >be thrown out. That was a HUGE mistake! Any "atom" of helicopter rumble >helps to identify and subtract all its sister helicopter sounds.>Every unit of sound there was placed by some source (IOW: God did not >add some random noise, just to mess with us). All the system has to do >is pick up every "atom" -one at a time- and figure out (yes, it is not >quite easy) in which "plate" it belongs. The number of "plates" is >finite and small. At the end, the user will have a multi-channel file, >nicely separated. In my case, I would throw away the n-1 channels, >leaving the tourist guide fellow's voice.To use your example of atoms, the problem is that all matter is made of the same small set of atoms... it's their arrangement that makes all the difference. In the case of sound, it's an arrangement of frequencies and amplitudes in time. Those same frequencies and amplitudes could be part of a helicopter noise, train screech, or baby cry... or the speech you are interested in. Take the "shoop, shoop" of that helicopter. The individual "shoops" are bursts of noise with some particular spectrum (continuously changing, as the helicopter moves, but we'll ignore that for the moment). Suppose you come up with an algorithm that detects the "shoop"... this is not really all that difficult. Now what do you do about that? A "shoop" isn't a particular waveform that you can subtract, it's *noise*. It's made up of a broad range of frequencies, and if you filter them out you can't avoid taking significant portions of the speech with it. To use the salt-molecule-from-food example, there is no "okra molecule" or "chicken molecule"... each of those is a complex arrangement of various fats, proteins, and carbohydrates. So it may be a *lot* harder to remove the okra from the gumbo than the salt, if you are trying to work on a molecular basis. Best regards, Bob Masta DAQARTA v7.60 Data AcQuisition And Real-Time Analysis www.daqarta.com Scope, Spectrum, Spectrogram, Sound Level Meter Frequency Counter, Pitch Track, Pitch-to-MIDI FREE Signal Generator, DaqMusiq generator Science with your sound card!
On 1/14/2015 6:47 PM, Mac Decman wrote:> I think if our language was more like dolphins or whales we'd have a > much easier time coming up with a decomposition which would stick to > our "voice" and not to the noise ;-) > > Mark >Are you sure? I do not recall what Whalese sounds like, but let's use Dolphinese. If you fast forward to minute 4:10 you will hear a bunch of dolphins. https://www.youtube.com/watch?v=a-EAqNbpcYE What they were doing behind the stockade fence in the grassy knoll is anybody's guess. Let's just hope that an enterprising book author is not reading this NG, or this may become the latest theory in a best seller: "The Dolphins Did It!!! - THE Definite Solution to the Biggest Murder Mystery of the 20th. Century" ;-) -Ramon
On 1/15/2015 8:20 AM, Bob Masta wrote:> An adaptive algorithm can be trained to remove persistent > sinusoids, but that doesn't work with noise, or in fact with > most real-world signals.Bob: I barely recall my "Signals & Systems" class, which I have seldom needed since graduation a couple decades ago, but I believe somebody wrote a theorem (Fourier? Laplace?) in which he proved: "EVERY possible signal is just an addition of (possibly infinite, in the case of a step or square angle) sinusoids" If that is the case, let's say that we beg God to provide the noise sample -and She graciously obliges- which we feed into our sound remover module. ...then all noises can be removed. [I ask all readers:] Right? -Ramon
On 1/14/2015 1:14 PM, gyansorova@gmail.com wrote:> There are Guassian Mixture Models (GMM) based approaches to remove noise of various types from speech. They work by using a code-book of speech and noise characterisation. When they find the nearest match they apply a Wiener filter frame by frame - variations of > > > http://ieeexplore.ieee.org/xpl/login.jsp?tp=&arnumber=4518754&url=http%3A%2F%2Fieeexplore.ieee.org%2Fxpls%2Fabs_all.jsp%3Farnumber%3D4518754 >Thanks so much for your invaluable help, gyansorova. You just confirmed my finding, and would like to report a mix of good and bad news. ======================================================= [Background Info for new readers:] For those following this thread, I am in the search/development of an *optimal* (am willing to compromise!), automated sound remover. In order to make the implementation possible, let's reduce the expectations as much as possible: assume that I am a very patient person who is willing to wait a month+, until the process is finished. Assume further that I am only interested in human voice, and there is a small set of noise sources. The signal will be decomposed into a small set of "buckets" (actually, channels used by the audio professionals), and I will pick the ones that interest me (the voice, for starters). This is the example that I am using: https://www.youtube.com/watch?v=a-EAqNbpcYE [After minute 4:30 it becomes more interesting] ======================================================= As a first step, I directed my attention to the "Audacity" initiative (because it is open source) but soon I realized that I was shooting in the wrong direction. Next, I went for help from the Sphinx folks. (1) Good News: I was right!! My guess was on the spot!! [Happy dance here] The Voice Recognition may be used for the purposes of Noise Removal!! See their reply: https://sourceforge.net/p/cmusphinx/discussion/speech-recognition/thread/1177f599/ (2) Bad News "The algorithms for audio improvement are certainly related to CMU Sphinx and could help it to improve the accuracy but they are not our primary focus right now, so it is not easy to expect us to implement noise reduction" Question: gyansorova tells us about (a) "GMM based Bayesian approach to speech enhancement in signal / transform domain" while Nickolay -the Sphinx developer and spokesperson- mentioned (b) "non-negative matrix factorization which allows you to separate speech from overlapping sounds using the vocabulary of speech atoms" Are those two methods related? The same? Completely different? TIA, -Ramon
This is a multi-part message in MIME format. --------------010008020505030005060005 Content-Type: text/plain; charset=windows-1252; format=flowed Content-Transfer-Encoding: 7bit On 1/14/2015 6:47 PM, Mac Decman wrote:> I think if our language was more like dolphins or whales we'd have a > much easier time coming up with a decomposition which would stick to > our "voice" and not to the noise ;-) > > Mark >Mark: Since you are a fellow poster who clearly enjoys of humor-plus-content, there you go... http://forum.audacityteam.org/viewtopic.php?f=21&t=83110 -Ramon --------------010008020505030005060005 Content-Type: image/jpeg; name="Widening-or-Narrowing-Gap.jpg" Content-Transfer-Encoding: base64 Content-Disposition: attachment; filename="Widening-or-Narrowing-Gap.jpg" /9j/4AAQSkZJRgABAAEASABIAAD//gAfTEVBRCBUZWNobm9sb2dpZXMgSW5jLiBWMS4wMQD/ 2wCEAAgFBgcGBQgHBgcJCAgJDBQNDAsLDBgREg4UHRkeHhwZHBsgJC4nICIrIhscKDYoKy8x MzQzHyY4PDgyPC4yMzEBCAkJDAoMFw0NFzEhHCExMTExMTExMTExMTExMTExMTExMTExMTEx MTExMTExMTExMTExMTExMTExMTExMTExMf/EAaIAAAEFAQEBAQEBAAAAAAAAAAABAgMEBQYH CAkKCwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoLEAACAQMDAgQDBQUEBAAAAX0BAgMA BBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpD REVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaan qKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+foRAAIB AgQEAwQHBQQEAAECdwABAgMRBAUhMQYSQVEHYXETIjKBCBRCkaGxwQkjM1LwFWJy0QoWJDTh JfEXGBkaJicoKSo1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoKDhIWG h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uLj5OXm 5+jp6vLz9PX29/j5+v/AABEIAagC4AMBEQACEQEDEQH/2gAMAwEAAhEDEQA/APf6ACgAoAKA CgAoAy9T/wCPhf8Ad/qauOxEtyrVEhQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAG9WRqFABQAUAFABQAUA FABQAUAFABQAUAFABQAUAFABQBl6n/x8L/u/1NXHYiW5VqiQoAKACgAoAKACgAoAKACgAoAK ACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAKACgAoAKAAe1HWwIO+KNgDtnoOtK47BTEg7gdz0pXAPT8qaDyD9KACgEH+cd6 A8g//XTsAUgAe3T+VHkCD9KADp7UAHTA6H0oGgyB3xSuFg9Pfp70xB3x39O9AIP6UAGOnvQA UAHfHf070B5G9msjUTcKADIoAMigBAy+vtRsAuRQAZFABkUAGRQAhdVxk4zQAuRQAtABQAm4 etABkdM0ALQAUAFAGXqX/Hwv+7/U1cdiJblUe1USFABQAUAFAAB6UAFABQAUAFABQAUAFABQ AUAB468UAFABQAUAH/6qADtntjNABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQ AUAFABQAUAFABQAUAFABQAUAUde1OHRdFvdTuQWis4WlZRwTgZwPx4rOpPki2vL8S4R5pJHg 2laB4i+LT3Gta3rH2LT1kZYE2mRUbj5UjyAAB1bOTgdeTVKlyxTk9WOVROTSX9fq/wCvI1fC WkeL/AXjK20/TXuNW0O4O6XYNkQU8MSGOEccHAPzADryKulK/uy8vz0/Hf8A4ZkTWnMv6/rp /SMX45QHVPiXa28LYea0iVSR3LPXLG96j7a/+Sp2NnZKP9dbHXa14hfUvgjYxRsDc38cFln/ AG9wVvxwprpxKU6sYv7TT/C5jSfJCUv5U/8AJfhqYP7PMiWOs6/FnIVEQe+GaphLmw7l6fkw qR5aqj6/oaP7PlyIJvEuf4p4/wD2pVUtMNH+uiHW/wB4lb+tSX9oqUSweHGHH+kyD8PkqKT/ ANqh/XVFPShL+ujPWoL0OwUVbMo7I8y/aD8QanplhpenadcyWVtftIJ5kJU4G0bcjnaQxJA5 P0ODj8dXkei/z3v6HRFcsG1v/X9fI41Phnc2dqNX8D+K4dUvrdwqizIhIJAyBIJCAcHocZBx 7VraUH7pmmpLXQ9ctfFVzovgdNV8V20q3dpEPtccGxmLbsZABC85zjNOrOC1Xl/wSacZPr3/ AAMS7+OPhK3jgZYtRuHlQSMsUKExE9my4GcemRU81tFsUo6HS3muad4h8A6nqOkXKz20lnN8 wBUqQh4I6qc1niouNKV/kPDvmqRv3Vzyf4V/EXRPBfgw2+oGea5lvHdYbZAXVdq4YkkADI9c +1dEp2UYLtr97M4xfNKT+R7D4O8V6X4t0r7dpMjbFbZJHIu142xnaR079RxQ1pdCvrY4z4Rz eGo9S8Rf8I3/AGt5vnJ9q+3eXtzl8bNnb73X2rOi7YaLj8PTutEaVv42u+pZ/wCF1+FUsZ7i YXyPFL5It/LQySf3ioDbdo9SRQp3jGa6/wBfqDhaUonQeCfHmi+MredtJeZJbf8A1lvOgSQD +E8HBz7HjvV2fLzxIv71iHwz8Q9I1/WL7SkhvLC9sATLFeoicA4fGGbpgfnURkpU3NbIck4z Ue5J4N8d6b4vvL2HSLa+8qyOHuZY0WJzk4AIbJzjPIH61SV4KfcJe7LlOoB4pXsriPOJfjZ4 UitJpZI9QV4pjEsHkoXfH3mHzYCj3OamM+aKkuv4FuHK5Rf9f1Y7jwJ8QtB8bwytpEskc8Az JbXChJUXs2ASCPcE474ocdOboHNZ2Zg6x8a/DGjanqmn3sGoCfTZPKcLEhEzbsYT5/qfmxwK yg1Nc39f1oaOPK+Xyv8Al/mjch+Img/8IbB4qv5J9M064JES3UeJXOSOFUnOcE8duenNVU/d tRerf+VyY+83boc5ovx58HanqCWko1DTd/AnvIUEYOeASrNj6ngdzVxi5Owm7K5Z+Or+G28F 2reKG1M6e14hQ6WY/ML7Hx9/grjP6VlKyml1NIXcW1/WpsWXiLQ/DfgbTr+4uXttKitIRHJc DMhUqNoIUfM+OuO9a4huNSXNu3bTqzGjG8Fy7GF4b+OXhHXdWj08C9095eElvI0WNmyAFyrN gn1OBx1ojBy23Kk1H0Ou8YeLdH8IaSdQ1q5EURJEcarueZgM7VX1z3PA7kVk58rUerLjHmu+ iOT8NfG/wlr+rxaci31hLOQIpL2JER3JAC5VmwT74HHXpWsYOWi3M5S5Vc4T4wfEV4PiNp1h DcX0Wm6LcxSX1ugCrOyur5GG+YY24DYwR+NRhpfvHUfS6XluvxNKsbU3Fb/5r/g6ntXhTxLa eJdGttUsY5Y4LldyrMAHHOOQCR196uUeTQzjLmN0e1SUFAHmPxo+I9/4HGmWuiW1tc396zkx zozAIMDICspySePoaz53ztdlf+vuLUfdv3dv6/A2/hV4ybxp4Rg1S5WGO8EjxXEcIIRXByMA knBBU8nvW84ctrdTGMtWn0Oy3D1rO5YbgPai4BuHamB598ZPFF74R8NnVNOit5ZxIkYW4UlS CTnoQf1qZTceW3V/o/8AIFFSvcu+FNWk1jw3puo3QiSe7tkmdYwQuWXJwCScD611VIqErIxi 7o1x7VAwHtSuOwDpkdKYjmfEl94stvEGlxaDplpdaVKVF7cSuA8ILAEqN69jn7ppQ1qOL2t+ Ov8AwCpWULrfX8Ch4z8fr4f8SaNodvZ+dcanNErTOcJEjSBSQO5PzemOOvSim+epydAkuWm5 nZh1zjI9aZI7sD2PSjrYdgHtz9KBIB7dKA2Vw6cHg+/FAIKACgdg7Z6CldCDquV5+lKV0nYD lvA+o+LLoXn/AAmOmWenFGX7N9mcHeDndnDt0wOvrVq3In1/4b/MqdlNqOx1AYEZB4pEij2o AKB2MzxTrcXhzw9eavNC8yWsYbYnVjnGKznPkSsVCKlKxR8BeI38TeFrXWbiGO2e5aQ+WhyE VXYLz3OByTgZ6Ct5R5bW8n95F7ykux0I6cVABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFABQBznxLs5r/wFrdtbKWla0YqoHLYAbA/KsMQvc+cfwaNq PxLzT/Jnn3wP1a1uPCCaUk6i7tpJGeHd82wnIYDuOcZrrbThG3RfqznSak/X9Eb+s+O9K0rx VYeHY7d7+a5O2V7dgxt2JwqlTx9eQVHrWdL97JxW1rf5/d3RpNckVI4vx9bgfHLQosbgVgJH /A2qMOlKpUj6/wDpA67/AHcWvL/0oxtAmL6zo/hU8/2frc0rL32R8rx9d1VQ972c30i187f0 h1koqa7tfdsX/gwuPE3iIAY5A/8AH2rOhrhren5MK38b7/zRL8ErqG31XXrCeVI7qWZWSMnB YKX3Y9cZq6LUsPG3T9UrCrK1dv8ArctfHm5hll8O6fDIHu1laQxA/MA20KSPfBx9DU0dcTG3 T/NDlpRl5/5M9Wsv+PkCtHuZpWSRz3xP8QeFoZrLw94usLiaG+CyR3ACiOI7iu7fuBXHfAPB 9yKztGpNxvbb8f8AgmqvCPMjzvxd8MLLw3pr65ouvzW6W0fmxmZlJkb+HZIu3BI6AA59fRSb g7L+u4RtM0jrV3rvwN1C61IlrmNfK8wjHmAOvPue34U8TblhLu1+YqGk5Ltf8jZ+FEWnf8K1 hi8qB4rkS/bNwHz/ADMDu/4Dx/nNa10uWy25b3+X9f1tnTb52+v9f8Oct8JJ5YvCHi+GNibT y2MeemfLfJ/IL+lY1bvCXe//AA3/AATZWWK07r8zS+B9nbN4SvZjCjS3Fy0chZc7kCDC+45P Hua2qxTpJdLP9V+iMU/3jI/2f5Datr6R5CLNGB/4+KUHehF+v6FVUlWl/XVi/AxyuqeKz6zx /wDoUtZ0dMFD+uiKr/x38/zIfgRHEmpeILzyw06SLGj91BLk4PuQv5VpRSWHi/6dkrfmxVta 0l/Wr/4A74a4sviz4mSAeWgEo2jgAGVTge1LDfwH5NfhcK/8RW7fomZ3xwe0XxPBNozSrqz2 r/bVhGfk2n7xHOdm7P8AsgZ9axi7OSW3X+vz8zVfDG+/T+vy+Z3vwhuNNi8EWMeinhsm4J+9 53G/P04x7YrsnurbdP679/8AKxyxWrb3/r+l/wAOeiW2fKy3PFYS+FlnhnwKFtHq/iC4IRrt JFVCRyqEvuIP4D9KKCX1aL6/pZF1/wCO16/maGj+XY/tGXH9kbYopI2NwsWAu5owzZx0y2Cf epwv8OpfZbf+BL/gpDr2vB9X/wAH/hyHwGsUvx98RXMsYaSD7RLFkcqxdVyP+As351OFVsO3 5/q7jxHxw87f+k3sWPjTKL7x54StNXYjSHdS4bIQ5kAfP/AQvTpn3p4ezxL5uiVvne342v8A IVX3aF493+n/AAfmdP8AHKHTZvh1crPDDGbLZ9j2qFMbbgNqY6Db1Hp+mNVvmi763/4f+u9j Sklyvtb/AIY4XxveXV1+z/4bW9ZmkFwgBbqUAlC/+O4rbE29vH0/Gyv+JOG+Cf8AX2kRfGC4 uH8F+B4VXNubZWYMcKziOMDJ7cE857mtaivjHbvp9+v5f1qRS/3b+vMn8Z6f8SPF2k2mm3/h LSbaGyINu1pJGjRLjG0EzEBeBx04HoKzt7/tL6/1/wAOODUYOK2HePpbq58c+A7XxNHuRILd biKYh1MhkxJnBw3QZPerpcssVNrZ3t9za/F/kRJOGGSW6v8AhZf18z1nxHp3hvVtU02TW7Wx kuYWKWSXBA3kj7oU4D8dAQcEZ61nF2nzL4v6/Le/TqXvG3Q83+MXmj4teDmkGF3whc8f8t// ANVGGS+sSX939GOsv9n08/yR6/pgb7QOoA6cYH4frRe7ErbI6NfuigAJApXsB893GtaVr37Q N1fazqFnbadoUTRQm6lWNHdPlwCxAzvdmH0owyTp1Jv7V0vnp9zin9469040101/X87IqfB3 VINC+IOteHrO8insLmRntGilDq5UkrgjgnYe392rotyocst1/wAM387Jiq2VXmjs/wBdV92q +Zr/ABTm3fGfwS/YGL2/5bHt9KjC/wAefkv0YV/4Ct3/APkf8xf2mbgTReG9vG25kz/45/n8 adBf7VC/9aoJ/wACX9dGT/HTXdS1HWNC8G6VdvZx6oQLiRTjcHYIFPfbjJI78VFOmqtZp7JX /P8Ay08/vRf2dBT/AK/rU5L4q/D6DwX4XV9F1fUJ7WSRBdwTuCkjc7XAAABBBHOThuvXLqS9 6Pa+nk7P9P62tUVo31t+psapNev8JdIhstWttIia1iE9xPK6HYE+6m0EknjgckA1vibe0tJ2 i+ny/EyoXUXZbN/mzzrWLnQfDWpaddeAta1G4uoRumuJF8tM8cKMKcHByDkYI5NOk37ayXuv +v621KcVKHvbnpnxe8Q6jqWtaL4R029axi1Tb9qkUnLK7bQD/sgbsjv3rKMfa1uV7L+v008/ RWSlyUVU7/1+oQfC5/Deu6ff+ENeuLPYSLprkhy6jBChVChgSMFSfQg8VrCXLU/u9v6/Pp0u TL3oW69yr8WLgS/FHwa2eksQ7j/lsP6VGH/3l+l//Siqv+7/AH/oc58VvD1l/wALN0+ISz7d Ykjaf5hlNz7Pl444HfPP5VNCF6jhfu/zZVSX7r2n9aJF3xHpsXw98U+GtY0/zfscBFvK7kbi MnOSAByrH/vmtKc/31ntJJfhb9EyJR/dabp3+93X6/ebfxJuF8Y/ELw94YjbdaxH7Rc7T2PJ yf8AdX/x6poRvXlJ7R0/X87Ic5Wo+79r/hv838j1yG6VmCIMAdMdqpk2sjxr42Jdy/Evw5Dp 9y1pdTwLHHOvWItIV3D3H4e2OtZUo81ZxWmn+ZpKXLRT7N/hYy/G/hVvh1HZeI/C2r3ouVm8 uczspLkgk9AAVO0gqc5yKpTVKajFe6+nl2/pf8BcvtIty3X9f1/V7vx41g6n4f8AC2oRAxPN umA/ukqh/rRKDjilFb/8EKb56D5vL8nc3LLQrH4daPqPikXN1qOs/YyJHuHBQyMRkjAB5bHJ JOO9FV+yhy0+rS/T9fwJh++kpT9f+B93y8jA8LeAh470U+I/FmtahJe3jN5BR1xGoZgM7geM 5wq7QAPeqlTUIq3xP+l6/f8AkCqXk9NEb3wg8TarFqureFdeu5L2TTiTDPIxZtobawyeccgj ngE+gAmUvaYdz2f+d/ysxTXs6iS2ZzfwS1EaVoviu+YbxbKsu3P3sLIf1xVSbjhlJb6/kjWc VLFNf1uc5p8/h3xRDfan458VXtvqrsy20ccLyJEOoJ+Ujbkn5FI+vNQoqEFyv3v6/r9Bcz5r W907TwT8SNSg+G+uyXlwby+0oKsE0h3Fg/yoWz97ac9eox6VVVt0otbvT+vk393mKnBKq103 +7+kUPD/AMOE8ZeFW8RaxrV5LrN8GeJncFFKnYofIJI+XsRgYAHFEqfsork3/r+r336Exqc0 tdv6/r9dTX8deH7v/hVIj8R6rJqOoaUfPjmXoSSBtYsCWABPPB6cVFdrmjNb7fe1/Xy6l0Vv Hpv9yYz4J6Da6fo0GvwyT/ar6N45EZgYwFkIBAwD/COprpkuRcnez/D/AIJjfmk32/4B7HaP uiBrMZNQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQA Hpih6ppj2+R5F40+C+l6hqD3mj3T6X5rlpIhF5kfP90ZG3ntnHpjpWag46XLlPm1aLfgL4da X4RuRftLJf6koxHK6bEjz3VecHHGSTx0x31T5VZf1/XX/h0Zy95/1/Xp/wAMW9W8DPq3jex8 UG/8v7GiKLYwbt2Nx+9u4+96VNJezk5d7/lYqb5opdrf5lOx+H62fjq58TLdhxLuZbbysbWZ cE7s/Xt3opL2aku9/wA7hN87Xlb8rEvg7wO3hvVdT1A332r7e27Z5Pl+X8xbruOetKmvZ0/Z +n5MJvnnz+v6Gf4t+EFhrt4+o2N22nXEzFplEXmRsfUDIIJ5zyR7d6mMOXRf1/wP68inO+5F 4Q+E2naHqUeoahey6jNAweFBEIkVh0JGSWwcEcjp3rWL5dev9fj/AF2ZnJOX9f1p/XkelafC zS7zxUjKnjvwbpnjLS0ttRDpJCd0NxFgPGe/1B7j6fURKF3zLz/plRnyq3T+vzPK7f4GQxXS m912SWEH5litRG7DvhizAH8DVKOuoOVlodF490q10f4Y6hYabEYra3hVVB5ON4OT7knJ9yaj ES5rPs1+ZVBWdvX8jkPCvgCTWPB9jc2GvXemC+RxdQLl4pcMQPlDDsOc59q2qQtp9nR287a/ 1369s4y39T0fSfCVjpPhWXQtM3RrPG6yTOMs7MuNxxjOM9PQCpqr2keTpt/wR03yS5/Qi8Ee EG8I6OdO+1/bN8xl3+X5fXAxjJ/u05e9FLy/Vk9WyHwT4Ibwj/aDC/8Atv2+RX/1Pl7Mbv8A aOfvUR92kqfb/JFT96o5/wBbi+CPBB8KTapcC/8Atf8AaLq+3ydnl4LH+8c/e/SpjHkoql2/ yQTfNU5/X8yPwP4JPhM6g3277b9tkD/6ny9mN3+0c/eqo+7TVPt/kgl71Rz/AK3H6H4HbRvE +qeIEv8AzTqAbEJg2iPc2772eenoKmnHkpumu/8AmOb55qXl+iI/CPgOPR9W1HWNUvjq17eq ybng8sIrfeGNx68D6cdzTUYxpumlvv5+X6vvoKUnKSfYZ4K8ES+E9WvLi01EyWFyTi0aI/u+ cqQ+7qOmcc0Ruocstbfn3CTvJS/r+ux6TavvhHGOKUvhYj5w+HvhY+IJdbntNSutMv7WcCG4 t2PAYtuBAIyOOxH49KmlG9CEvv8AuX9f1prWlavKPr+Z698PfAFl4T+03j3cup6rd5El3KuC FJywUZOCT1JJyeeKrmtHkS/rp92/n91oavLmf9f8Hf5bebdB+Hj6L401TxKNR84agrj7MINu zcyt97dz930FRT/d03T8/wDMqp78k+1v8jd8T+B9K8baMtnq0ciyQsXhniYK8ZPXBIIwccgg /oCJcdbrcqMraPY4ez+DMkl1bR+J/FOo6xp1qQY7Mho14xxku2BjI4AOD1FaXSfM1d/1/X46 7ENWVkZH7QWt6P8A2PB4bsZVW7sriNmtkjYCKMRsF5xjGGXAzmsburUUl5/oaxSpwa7/APDn aS+D7PxD4J0zRtajkRoraEhozteNwgBIz+Ix6VviFzVXKL6v8zCg+WFjn7P4P3yXdmNU8Zar dWlmwaGFN0ZjIGF2MXbZj2HTjI60KXvc73/r8ymtOWOn9f10+R1/jXwBpnjTSorS6eaGa2B+ z3Cnc0ZPXO77wJwSM5PqDzWcl73Mt/6/ry/B3F2XL/Whylj8GzLqlvN4r8S3+uW9rzFbyAqM 5HBZmbCkDkADPHIxWsZKMue2v9f12M2rx5L6f1935nTfEb4fw+OJdPu7XUZdJvdPOIpoo9w2 8HGAVIIYAggjHPB4xik4z5099P6+80uuXlt/XX8jb8F6bdaHpttY32oS6jPCCGupFw0mSTzk k9+5NaTlzP8Arp/mZxVjsFOV4qSjI8XXtzp3hrUbvT7aW6u4rdzBDDGXd3x8uFAJPNY1k+Rx XXT7+pdNLmVzxH4ZfC3T7zw1NfeNNFuTqE1ywjjuGlgdUAHO0EE5OetdTjGMYqPz/RfcvxMu eUpSb+Xr3KnjfwLL4T8RaFrXgrRbyaCKQNNDbLJPtKkHuWPzAkfh71FKo41bPb+k/wANi6kO alZb/wBNfianxd0bXLjWPD/inQdPnv2sNu+BIy0gIfcuUHzEHnPFKDdGs29U1/nf8Nhu1Wio 9bv8dvusc14/fxf4zXTb2Twre2FpbTFI7cI8krMTl2KhQQoAA5Ude/a6MFCvGT62+5P+vuJm /wB3JL+tGdf8XPDGr317pniLw3EZ7/STuMCjLMFbcCB/FgjBHUg1kpezq869P69b2HZTp8vb +v0OT8dap4y8a6H5LeErzT4rco8waNzJO2cAIpUHGST0PTr6uUE3zef+YouysO8a+GdZvPA3 hh7Oxnnk0+3X7RaFDvBKrj5OpIIIx15rarLlrqW6/wCGv95FPWm49b/qzL8ZweIfEmjWb2fg 6TSLKxcotrBETIztyzBAoIXj06t1PaV7tSM5f1qVHSLidP8AELw/quoz6T4k0GBpL3T1Vzbs MPtB3rweSRzkdTmh3pVuZbP9L/miadp0uR9P6/QW28T+Pdd1iyg0nw7LpCxtuuWvY2MbrwOS yqQBnop3e9VGKctfh/r+l07g9I6bln4naRqF38RfClzY2Fzc28EkRmmhhZkj/fD7xAwPxqaO mIk+lrf+lf5odTWhZef5IqfFrSdVPiPRNc0vTbi/Wyf5kgQs2VcMBgAnB55qabdOq5pdP8/0 HJKVLl9fyRpeK7WXxZ8Mbm4utPfTbyOM3K28/DRtGTkZIU8qG6j+KlXXJaa6frv+d/kOi+Zu L6/0vyMD4IWdzdXGoeIb8tLKwS0ikfrwBu/QKPzrdWUG+sn/AMP97f4GT1duiX9f5fM9n0uL PzGoGeQfHNbz/hZPhwaYVF55SGDecDeJDjPtms6Lkq0nHe36M1lZ0Vfu/wBCh4jbxb48ltNC bw9NpESS7rmeTJjJHG4NgDABPALZ4xVKCnPm6f1/SJ5uSNkXfjNoF9JpehWekWF1eR2m6MiC Fn2gKo5wOOlUpOWJU/63QU0oUmvT8md/q2jpr2iXmlysE+0wmMMR908YP4EA/hUVY8609fxJ oPkt6fpqedaNqfjTwHYtoF14XudTEJZraa3DMgDE91U5BPIHBHfti3Nziu9v+G+4FBRk2jf+ G3hPU9LbUPEHiEKmp6mSTGDny13biWI4GeuB2A96UoqlQdNfP+vnqJyc6in934HLfBWzjv8A S/EtlN/q7nbG2PRg4/xpyjzYdJd3+hpOXLiW1/WpT03TtW8Hrc6ZqPgWHXyzmSC7W28zjGPv bGO3j7vB5NTzuUFdWf8AX9eguVJ3T0O00fw5ca74GvbS+0HT9Bu76MDFqipv5yjOoGVAPYkn rwKqtC8eVbrX+vX8iac/fv02+85rR9Z8Z+D9Fk8Pf8Itd3MlvuEFzCjOibvmB+VSG5JPUdaT k6iSWjsilCMZPrqdo2leJda+FuoWXiBLZtYniIijTaCcYI3EHaGOO2ByKnEL3Fy91+a/r8BU XaTvtr+TMj4RXWq21jFoWp6BfaelnG8i3VxGyB9z524K8fePQ9q3b5437WX4f8MZtckvX/gH r9rjyhioGS0AFABQAUAFABQAUAA9qADpjtQAUAHb29aAAYPQg/SgAyPUUAFAAKAAUAFABQAU AFABQAUAFABQAUAFABQAUAFADXQPwaAIvssec4oGSCJAu0UCGfZo8HigYfZoxwBQA8RKF20C Izax5zigZJHGsf3RigQ7HagCOS3RzkigCC60y0u7aS2u7aK5gkGGilQMjY55U8dqTS2He2xn JpEFoqQWNtFbW6fdiiQIq554Ucd6b1Fa2xqW9qiKDigZI1ujHkdKBAbdCMY6UDAwJgDHFAhP s0eOnFAzDg8T6LceLZvDEMkj6hBCJW2x7kHqNw6EAg88fN60XHY2xaxgYAAHWgQv2dOm0UCJ EjEYwvSi3QDFOg6fYmQ6Zp1rZ+ccyeRCse/64A9+uaWystl/X+Q93qdTY2Sqg3CszQuNAhGM ACgBY4VjGFGBQA2S2jc5IoAyLrwvor339pNo2nvqAZXF01shlDDgNvIzkY4OfShe7sD10H29 k5uN7DvR5h5I02tY2AyKAFjt0j6CgAktY3OSKAFW3ROFFACfZkDZxQBKBgYFACEHGOlAFK5s vOk3Y4/z9KAJhaKItuBnpnrx+NHmHkVk08KzEcA+g/OjzDyQxtMO4lSRn0NHkHkEOm7Gyefr /nrQBQ1bTx9oG0dVAyewyc1UdiZblFdNw5J/kOf8+tXYn0BtN5ytFvwC46HTgjZpA/MWTT+c r26fr2Pem+wEkdmVByeowKLdAfcbHZBGPQH8j/8AqoD0OO8e+AL/AMUSJ9l8Q3WmWpi2S26I zxzZJOSA6gj6jtWap+9d7af16lqdkkjR0TQbTQtMttK05G8iAHBfG5ickk8dSa1burdv+G/4 JmlY6iziEcYA4pAcf4z8C/274s0nxANR+z/2YFxbiDd5m1y33tw2/lSpr2dR1F2/Rjm+amoe f+Rr2tu7ynHGe38qPJAaMNgFyT19uOtO3QXkEVj5cm6gGS3FoJB8oxjsPb+vWj0A5zxj4Wvt e0tLSw1mbSHEgdpoUJZlAPHDKe/rWcoXt5XLjJRTMvwZ4LtvBmmSWdvcPdTzPvmnZAu7jCgL 2A989TWzeij0/wCGI+05HWwWQeEcY9cf4evWoGPSyZWznv8A5P1ot1Almsg446jofTtTt1QE aWTKw5osAs1iHwR2P+cdKPICzbRmNAKBE1ABQAUAFABQAUAA5xtBOeBx1oHYy9X8TaJo0Usm o6lawmFCzxGUb+nTb1z7YzU8yva4WZRs7zVtZgNzZ3Vnp9q+REFQXMhx1LOrBM+oG7HrXBVx 6g7JG8aHMPC+JoEKxXelXZ7PPBJE347SQfoAM+o61Ecwi90X9Xa2LcVlexyRSSazdS7R86+X CqOTz2TcB7bs9OeucJ4+o3oaRoLqXXZ3GA5U+oH8s5rP67W7lfV4FC4s9SPzW+s3EbjkLJBE 6fiAAx/BhVRx9RP3tSHQj0RHb68lvdvZa6YLG4WJp0kEmIJowwXcpPKsCRlTk+hNenRxMasW 77HLKm4uxNa+I9Iu5oooLwEztsidonSORs4wrkBWJPQA89q3jUhLZkuLSuanYnkAck/3fr6f jVXsSKAdu4AlcZyOR+dFwEyPUdv16UxhQIKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoATAoAXjp0oAKADHtigA/A/lQGxzPxJ8Vw+DfC81+drXUv7u1j/AL8mCQfoOp+l JtIpK5xfw0gtfDWmTXV5I+o+JNUbzrtIFEjxAkkI7dEPOTkjnHpUpjep2TaprNnZLqt3b2lt YwSR+fF5heQRscO7MMKAu4EgA9DzSUtQa7HUd8elaEBQBNbRq8wVwCvpSemw0a49KzNBaACg AoAMdqAEx7UALQAUAFABQAUAFABQAUAFABQAUAH0oAzNT/4+F/3R/M1cdiJblVuvFUSJQAdO lAC8+n6UAZuua/pegxQTavdpaw3EvlI7Ald2M8kDgYHU8dPUUr2GkJqtuuveHrm3sLxkW8gZ Ybm2lIwSMhlKnnB60w2OD+DXiWZ9DuPD2snbqWizNbuHOWKZOPrghh9APWpQ2ux6PHFEwDjv VCJwABx0oENZQy4NADUgRGyoxQBL9KACgBKAA9KAITboWyRQBKq7RgcCgBaADigAoAWgBDig AoAKACgAoAO4Hc8Ci4CoCwyoJHHQZ6/19qAOO1R5fFGrXOkwXc9pY2c3lztA2Gn27S4LddvO zaD13MSdoB4MTiuR2R004XN230bTLWIRW2nWsUfZVhXjAHbHP19a8aVWctW7HUorsWILeK2T ZBFHEmc7Y12j6AdB3zxyTWbdyrW2JSxI6CgqwmMd+KEMMc8UAKc+vPrSWgjN1PRLDU9Qsby8 hMk+nOz27Z6Fhg5HQg8ds8da0jNwVl1JcEyxqljFqWnzWd0X8qdCjEH5ue/PcE5z2PaiFSVO XNGyE4rYzbfw6rSbdRvrrU7RVXyra8feiNtAZmP8ZYjOCCBk4AroqYyrU8iI0lEsP4b0j70V jDbyg5Sa3HlOh9QVwR9R+lZLEVIu/MynCLGaXqF1Z6jHpeozm6SfcbS5Y4kbbhijAcE4JYMO qg5x39rDYhVEcNSny6m7712GQdKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoGH6UA FAgoAKAAZyAO+MUAVb7VbDTp4La8u44ri5bbFByzue52jJAHcngd6V0OzI9Y1rS9FhSTVtQt 7NJDhfNkxvP+yOrfhmi9lcDJPiPUL+N20LSGW1QFnv8AVM20CgdWEf32H4KP9qpcuxSR5t4Z t7v4meM59d8QTfb9C0ZjHap5PlRSycHhAcgdGOSSfkBz2hlWseladZw70htIIre2i+7HEgVR g+gwOaVx2Ogmsre5sZLO4j3wTxPFIgHVWBBAHuOKAMTwddTCxl0i93m80Z0tHkY5MybAYpR7 OoBOe6tWqehm1Y3vaqJJ7T/Xr9aT2GjWFZmgtABQAUAFABQAUAFABQAUAFABQAUAFABQAUAF ABQBl6l/x8L/ALv9TVx2IkVe/FUSFABQAYz0zz6GgZ51dWqeOPEOpxXF/qGnRQA22nPb48uW PnzTIhB3ozL0b5SEIBzxWUnqXFaFK38N+IPCc5l0/NnvPzPYwtc6fORz+8tj+8hYnGWj3D2F JMdkcr4lvbvw/wCPtP8AFUlgtnZamogvJbWb7RbSNwCyOMEHAU7GAIK981SeoraHtOg3sd1a o8UiSIyhkZTuDA9wR1q7kWNPjt09qYg7Z7etAB0oAKACgAoAKACgAoAKACgAoAKACgAoAKAC gA7Z7UAUtX1IadbBkja4nmcRQ28RG6ZyDgZPHQE5PAAOazqTUIlxVzKHh+fUZ5LrxLOtyeVi tIXbyIB7Hgu5/vHoMY2458mtipv4TrjSSLWi6LY6HG0Wnw+VHk4UdFBYsQM+7HmuCdSU9Wze MeVGkD+tZ3uXbsHbgGjyEJ0HIIoAQkKcE4PPB9uv5UdbBdWuOHTPYDNCDYDwM9BnGTwKAuJn oSMZ6A8U0na4xS3Hp+H+fWkIQce1MBS3OKL2A5fW7u4tvE2l3Fxp8radbTBFliYvLLJIjLuE agkooLZzgljnoBn0sHKEdb6nNWTsdPY3tvfWy3FrKJI2LDcAVIIJBBB5GMHAPNe0mmro4rWL GcjK89uPX0oASgQUAFABQAUAFABQAUAFABQAUAHSgAoAKACgAoAKAOKtfix4NmvJbR9V+yyw yMn76JlViDjIYAjH1NK6HZnVabqunapH5mm39tdp/eglVwPyNMLFseg47+lAg4ClmbaFGScg bR6nPQUroaRw/ivXNav9a02z8IQnUrFJv+JpNZyhflJGY/OPCnBz8rZqGykjVbStQkR557y3 8N2vymUWO15nUf8APS4kGAuO2Dznkg1JRixeK/h5olzJLHdi6ukOZ70RS3TDnOXm2njPPBA7 You9h2RxHjzxvq3jPxI/gzwo0S2NzIIWlA3PMuNzu7EZVQM5A5wDzzggtjW0d9Z8KX0ngnTY 7TV0htvtVtIF+zsgLc+bjPrnPse2KBnp3hq3urfSoW1MW63ZGZfs5bywe2MnsP8AGkBZ1PU4 bDT766SNrqSxhaWS2hIMpwM7cdRntmgRztrrNpezaJ4msXC6fqkX2S53kDYSS0Rc9iHDp6Zc Y4q4sTWh1HbNaGZPaf69PrSY1ubArM0CgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAz 9RxvHTgYq4kSKP0qiQoAPagDK8T3U9vpRhsMm9vnW0tiDyrSEjf/AMBG5vwpPQpEmlaS9rZ2 1hcCN47JFS1uYh5cgUYBBX+E/Lzt+U9cCsWaLQ1QDHgMWBKkfMcMQOp/CgDlvHng2z8SeHNV tYLeOO8u18xZUXhpl5RiOgPYnGcMeexEB5r8I5LuXRiui3x03UrFzFdWtwvmW8pGcMydUJH8 Skcqciqv2FY7TWvGOsQ2Nu4hstNjYvnU2Y3tjIV4WIMpDLuOQSwGMcZp84uUm0n4gIun2k/i rS7nRvtQXyrlV+0W0xPQB0ztY4PytTUkhOPY7KGWO4gWW3cSwt910OQfoRVkD6ACgAoAKACg AoAKACgAoAKACgAoAKAD8aAKuo38Gnwq8xZmdtsUcfLyt2VB3+vQVMpKCvIpJvY5fW9S1e41 XSZLXR1d4Z2lFubgNIYmUoZM42KAWzyxzggZ5rzK2Ip1E10OmnTcDqLd5jCn2nykl7rGxKj2 BOCR+AP515LdtjqSH85qSjE8VarcaRFprWiIz3V9HbtvX+Fgx49yVAzW1KEZPUicuVaGV4W/ 4SrVtM0vVptesDBcpHO9ummjlWwSobdnPbNaVHTg5QSf3kxTetzT0vVyb3xIb+aNLTSrlUVi gURx+Qrk8YzyzGlOCtFx6iU2r6mfBrOtHTJteuljtLCWLNjpwiJncv8ALEXYnaGY4O0DgEeh puFNP2aWqDmlvczrLxlqNveeHotS8sK/n22rkBf3M6yrEsmcZC7yO2MOK1dGD5nHtdfi/wBC ed9yzrHifU1ht2sptN08vq1zZNPeqTGqRB+uCD82znnNRGnC6bV/dT+8rnH+DfEurazqOqW1 3FZiO0t4zDNbxSiO5Zmba434JT5fcHnBoqUKcOVq+vmEZSdxdL8W3sngnUtbuEgea2IWNAhV c+XETnH+07H8qU6UFKyBSdrnZuAOeCCevb/P+IrmnFJuxopDRyB6H14qSg5GR6++PrRZdAt0 MkaDDB5rWd7qNrLJK83mJdOwDsdzfI2UxnttrshjKkbIxdGLJbTVLmC+jsNZRPNm+W3u4v8A VzsOSpU5KPxwMkNjgjpXrYfExradTkqU+Q2PXnOK6zIKBBQAUAFABQAUAFABQAUAL2oGBoAS gQUAFABQAUAc34k8I6Fqys15olnPKed/kjzD/wACHPvSsO55lr3w68J2Mu+K7u9LuRzHHaym WTrjhMMx+oIqbFXF07R/iNpvz6J4nlaBV3JHqYy5HptO/b+OKnmKsPPiXx1YT+Z4s8KL4iiV gVEbkoPcRJuTPuUzSbC1g1D4xjVdVtdMmN74V0tVzdzRRB7kHqUUgDaOnIGfpQ0BS8Uvp2uy 2+i+CPFt/fC+hc3qX940kIVBuT/WAEOTwAM9s4oQEmq+LtYufhXYmLS7ex0GEJbXrC4SKS8c Y3RoiglAcckcnnpzkAT4ceGNRjgvfEmoXt/oF3cqXDJDEqvAwD/IWyygYGTgcYHPNAFrT/FV joNrJqXh7Rr/AFRLidI7jV9QYxxvITgb3OTge2BikM3vEPjrXtNsr7SNTFrpmsW8sB+12x3R taysFaSPfkgqSBycZOadhHHeNrLVPB/xWtJn8RXFrHfqPK1hlUlk5A83GBIFO0MT1GDQB0vg u31Gy1PXfh/4os/s8Ooo93ayWwJhQkfM0eT8gyNyjjDCnsB6J4U1R9U0hftI23lpI1rdj/pq nysf91uGH+8K0T0Ia7G7Z4+0KDxg0MS3NcVmaC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQ AUAFAGZqLAyYHarjsRIqCqJCgAxxkD/9dA0c/oLf25r1zrKkSafY+ZZWAHIkbOJpQR1yQI1P op7mspFxOc+KGuXF3r1t4csL+bT7Szj/ALS1i+hfaYYVyVUH+83GB3JTtmlYo2fAfit9R8I2 +s+IbqC0/tO9kS1V8R5BciNOCAzZB5xzkUhHSWmpWF9Jcx2l3BcvaP5c6RSB2ifn5WHY8H8q Bnzdr95C/wAQp7lY9U0TQdfkxK0qGHzhwC3OAEL8+oDHNMR0um+N7rwf8NfDtroNqkt9ctNc zIybsQrIxctzxu4GeMbc+mHYZ0nxF1LwU72tpqMd/atfQLqJnsI9yRc/JJLH909T1BPvyKkD ptC1mWDTYJWhttS0sII4b/SFLqiLwA8Jy64/2S30FaJkNHR2txDeWq3VpNHPbsMiWM5UfU9v fPSquibMZeX9nYruvbqC1A5zNIE45557cGmIxL3x94SssibxDp5K9VimEh/JcntSuh2Z0EE0 c8Mc0LB45FDow7gjINMQ+gAoAKACgAoAKACgAoAKAEZ1RSzsqKoyxY4Cj1PoKAMSyE1/qt1q M8A+yOiR2RkJ37MfOxQ/d3MRjJyQBnGMHxMbW5naLO6lCyuy8tpEl49yoYSSRrG3ORhSSAP+ +jzXnX6HRYsdOnHrz1pDANtoA5jxPJY6i2mxQarpkb2GpQXMqyXSKyiMkuoA/i9jXRSU4X91 6rsZ1HfS5l+DPCWgQWEV3cCxvLuzuHf7RDeNJFGPMLR8Btq/LjjHetatao5tK/3eRMErblrW PDmpyaT4hgspLaeXVL+K4iieRkBjHl7oy2MgssZ5Gcg9qVOrD3G1sn/loLl0ZQv/AATf63r2 nXmtayxntGad0sZfLEDcFEhjx8vOWMjDd06VccQoRkqa+fy6/wBW3J5W9Lk1v4CsoPEWozS6 k97p19ZNDdWt1L5k29ip3hsjHCr19B2xjOWIbhFWs77rbRa6b+XzKjTSb1K3h7w3Oltb2Wp3 1leJp+tPerLJMsjXUZQgE8/K25+h6/iKupWjK8o9Vb7mhJL8Tc8Q6Pq39qzX/h27slnvLT7J cw3OQu0Fisi7e43NweCO9RCpBR5ZrZlOLvoYWreBtZm0fV9Ps9TjTT2Kva2sYKGRwiIolf8A hQbMhBnqMmtI1oXi3H+tSeV7JnSaVpOrSahHqmv6oJp0VvJtLPMdtBuHzE85lPJ5bjg4HNYV K0LNQWj6vcuETf8A/Hcenp/jXPqai9KEMAMcdqYjK8VxFvDmpEElordpo3X+F0UsrZ7YKjn/ ABreg3TqJIidnHU17aXz7eKbABeNZCuMbSw3cenUflX0ux5rJKCQoAKACgAoAKACgAoAKADt QMKACgQUAFABQAUAVdWs21DS7qyhuJbV7iJo0niba0bEdQe3+GaAPPfhfqVjH4p1nQ4bUWpn AudjD5kmVVWdNxySCTuBPvWDNUz0aXTYZP4QO54/znv270DKb6KvWP1wcd6AOe8YeDF8Q6JL YXOzLf6qVlyYnHII7+x9s0XEcXF8NtCfTLG21/ToNP1aZTGotbtsysvUqCcHsSMcUwPO4vC8 msajqtr4Wup5dK0vMkb3EgZJZBxxgBecNg45A96ANmHxP43uFtoZLqLWItSSS3SzZQvIX5lK gLtK5/yKAIPB3j7+wbOfw34i0+5vNBmjMVzblsyQN3aPOABnkqe4yCKALq+IdL1zQ4rN9QU3 2kSG0tZLpxB9usJMq0bE/KrJ1ySeeRyKAPTdO8GnX5bJtV8RWuu6XY20trbLbRqssiOoX95I rEErgEFccjNFwNe88W6H4bittCsJLrVr+2UW8VlZgz3A24Hzt0U4A6kHtjuHFAHhaDWv7c1K +vdNXSrG6iixbyTrLI8yjhzs+Vfk+UjOflFaIhnVRtiRT0IPFMS0NtelYo0FpgFABQAUAFAB QAUAFABQAUAFABQAUAFABQAUAFAGTe/69vSrjsZsrjpVCCgCrqltLeadcQW929lNMhVLhFBa PPGQGBB4OPxyOlDQGLoM9z4V02303UdJjNlZxhUu9NRpI9oH3nj++h65I3AHkmsnFmikcL43 8MRyeGNSl0nWotRtr55L67kW4jM15PkCFM9BGoJbHqDxyKBnHvqP9i3unzarrdldPomlmS0s rZ0eCG4I2RRjBIZwW8xzzyO4xSAoaJ43HhTw3rVlpN9LLqupzxFr1QQY1CEuQx5J3sVB47mg Zv8AxD+IWkeNvDh0XTtJ1a6ltxG8F46qW81flJYDJwVPXPJPTpQtBHLeDNU1W5W4t7LRf7Vm k086fHul2iGJshiB7luv1pga1nP4/wDDtjcaybKKCS4ih0xZLlAZ9ijYqIhPGduScclT2pAJ b+GfGPhC/sdM03xAtrd6w+1raylf5FGMvIMAcZPTJ4ODQB1f/Crpp7iS51bxpqd3LL/rHjBU sen3izZ4zjp17dKLjsZMXwutNJvXlv7e48QWDHJa3lEM8f1QnD/gwPXincn0Ol0Pwx4EmZk0 7R7eSaLmSK5d2kj6feRzx+WPzq9Banf6ZJIixwrH5UUahETpgDjA9qok2R0oEFABQAUAFABQ AUAFABQBn+JMf2FdK/CNsRuOimRMn3wMn0OKyq35HYqO5af77YBGD+X+fyPHSvmG9z1FoIKR QEigBOcccUAcX4o0bRH8YeGo5dI08td3F3JK32ZMy7YGYluPm5IPfn866acp+ym09Wu5hL4k cvf39hp/g3xXZ2uk3QZtSnDNaWbCGLEihMuMKAAB939OtdfJKVSD0/zM+a17FhtYuX1XVNG0 +01F4ZtTu7q8a0zGzIGUCPzWIWJSVO9sg4CgYJFCpxSUm9bbP1Yky9pOsDTvBer63p/hyy0O PckNvPDIJfPzJsEjHb8yqzE5JwefY1lOnzVEpzcu+6/J2NE9Gyn4+0nQv7Gk0zRIoL3Wwr3E t6reZII0G6WWeQE7gwGNrcEkAD5aulOqpNz0X9bESta6INWs9Gk8PadKngKeOIy2ge4+zwIX BZAeA24hunbOe2apc6m/3mrv1elt/Idla6R2fhmPSbKSaa38OS+HnmaO3VrqNEe4JJIQAMx4 xnnHHbg1yVZSejlfr+XkXHl7HN694b0bUdF8aatcWkc99DPdBZS7Zj8uNeNoIHGD26VvCpKM oL+upKUWm2dp4c0HRtJha40SyS2S7RHYoxO8Yyp5zj7x6cVy1Jzm7SexrBJLRmxisjQSkAA9 qAOW+INzJbWEUkt9Alg7LE1m8TNJfSMcLFvDZVG78ducgnPbg1HmSsYVbqLOvGOAoAAGAgPC Y4IA6cYHQDpXvryPPYtMQUAFABQArAdQOKAEoAKACgAoAKACgAoAKADgdKACgAoAOBjjPt2P 1oGeT+NbZ/CvxLt/EFoo2ajGZVzwDNEvzof+ukW4Af3iKzki0esw3VtJaRXSTxi3lCvE7tgO GxtwT65H51BRl6P4n0vXodQGgXKXs1gzRSRZKkOoO0c44JXAbofWiwHmI+Nsv23SbybT4/7L mUwX8MYPnW8wJwQf7u3BA74b0NOwjznXtWa3e+8M2E8V/Ym/E+l3rS4a23Ech88Kytzk8Hk4 INAGv4PGpafotzo91b65brb3rGZ9ICPJvIVSsg68bMqR6mgC94J+H+panqv2xotTisheSwGe SQ2txFkZE6g9eOGHJ/PgA9KtPD+m+DtDliuNQzDLI0k0t0wJlZ+WGBweMcc/jkU0g2OdvvC9 t4gizaeE7OGA5AubyI2zEDuqJiQj/e2/hVcpN+xln4Q2MCM9rqeoWd02fnhIEY9gp+bH1Y0c oXG6VoHj3wlb/Z/DOv2k1mp3eRNEE3E+xU4+u6jYLnQ+HfG3jZdatNO8R+FovKnkEbXdsSFj GfvHG4YA7cVSdhOx6fayJK67eeaYrG6BjA9qyNBaACgAoAKACgAoAKACgAoAKACgAoAKACgA oAKACgDGuzm4fHStI7GbIulMQUAedeJ9B+Id9rN3JY+K7bT9KZ8wRpH+8VcDgkICef8AaNTY pNGC/wAPdVuiDrHj3V7rByEUsAvrjLkc/Siw7ohb4Q+GWjfzL3V5Z3z+8MiHB+m3n9KTQXF0 rwPoOjQFde8Pw3SwvuW/tjMylfWWMuSPw+Wpsx3RZfwHpzRR33hyG2kie/S+lwFfKLkiGMgA Bc4ODjtnpS2KOb0qyvorbU9L1y6t7aWJ1vJNNubwWkd4ZRud3fJ3AAKAM4BFMRytv5MHikQS tDpOm6lLlzDKGQIjsCFkHO0up5/3fQUgO507xhbadZ3kN9LNrtilzFFpbSqPMuHHJGSADsO3 58DqOmeAZvaJa6Hr3ibUU12afTNbuLZbU6bdN5bwLjkwyZw4JAORg8mgDt/DnhX+xrRrOfUp 9QAYmJrkhpI0IHyZHLDI4yKQGymnQKchfu5HHagEcB8bGs7HRbSaCMxamJN8d7CStxBEuN21 hyNxKIAcjLHjimmI7Hwol6PDemnVQw1D7Mhud2NwfA3ZC8DnPbtWq2M2ag4piDvQAUAFABQA UAFABQAfjQBmeLIpJ/CurxwozSGzcqqMRkhdwAx34qJK6aKjuP0u6F9plndhVj8+FJAoYNt3 KrYyOD1xXzE48s5LsenF3RbxxnOKmztcY0Y7fh70WGB4wTwAaWgzC1CfTj4u0m2vbOQ3qwTz WVzngNgCRAO7bSTzkcVvBSVJtPb+vzMpNcyMzS9W8P6j4biutPsWuLDXr9kuYZWxiR9xlMmT wAEzjPTpWrpzjU5W9v6/zJTXQqXXiPwVFYS2C2k9xp15chyUspDb3U7OCAHOFYkjOfunHGat 0K1lLmt+YueJs67rNjbanH4evdOSeG6SGMKdoTbK7JyjdFBX346c9MYQly86dv6/Md1exTvL nRvDk02h6f4VvLiO4txPcLptkjIUJZfnywyeDge4OacYzqxu5deo7pXSEuPEfh648JXW3Tbq W10xoIH02WBopUfevlLtbHIO3vzQ6M1NbJu+vy1FzJKxWv8AxhZReJLCDUvDmsxagqv9kQLC 5y4wTsV+CQpwTjo2O9X7B8jcZJp7vuuguZJ2sbWgmG8h1ISaBeabb3UhklS92g3BdcNlQzYG FUHPHPAFY1FytNSvY0js9C34d1Oy1O2uI9OjMcOnXD2IBQAZjwMrg/d5GOnSpqQcGr9Rxl2N PPpWRYUAA60AV9R0+z1K3MGoWkN3CeqTIGH69/f8qak46xJavoVPC8skIvtJmkklOmzBYnck sYXXfHkknOBlST129ua+iwtX2lNPr+B59WPLI2uldRiFABQAUABPagAoAKACgAoAKACgAoAO 1ABQAUAFABQM5j4l6E+ueFJltkY3thIl7bnbnLx8kfiuR9cVMloNM5HwUZPFnwv1Pwuz7bm1 hDWTBuse4vCQeuA8bR59APUVm9CzmIo7+48R6J4r8O3y6fqOsK9tcLIpEZ1BMbopOQQJcA/7 x/JgczNoV6PCOo69DB9gu9N1R4byAkp5YOGRlBPBViy8dmoA7L4U+CbXULK98WeJLK1+z6ik iW9kYAsaIWBMgGfk9Fx0HNIDqbnxl4V8PFXll858BBBYReYxAO3G7p6Dk0Acl4l+OF/qObTw zAmnQthWu7gb3RfXb90evcmhIDvvhNc2uu+HLXWLmN5tWUmGaadzI4YZOVB/1YYYOFwOoHSt IpENnbMARzg9sY4474/pVCuRPBG/VQfpQBXl02F/4QKLAVJNGXP7s47enFFgNLRLRoZVDEnn ilsNHSVmWFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFAAaAMzUiBKOg4q47ES3KhHoM/1q hBQIjniEqEGgCmNKizzSGSrp0CDIA9qAJY7SKPGxSCOVxxx6cYP4Zo0AwfEVjZaRZ3GtWP2i yuoypC2RVftMjsFVWQgq5ZiADjP+1Q0UjiZ/FNvrKw6Z8SfDaaZeW0obzpIDIjqDlhH/ABAE cbkZsdSCOKzsWQeN/h7oGr+B9Q8Q+E0LF0iuoEiUBI40UgxqAMjIJODzux1pCscXo+ojU7HT LjULK4knu9QtbZbv5fs8cSSAmED+Dsx9cc+pALnivxFBrmuT3cdl/aE2paossQCZYRRZjgjU n7vmMGLAHoKdhna6/wDEbxN4FFvaeKLfTr65vbcTQC03J5TbwCjjpgDcAV/uj3osB6bDq1hJ rJ0pbhTfLAtz5I6rHu2qc9M5Hc96kVzzjT54/HHxIkDKDYaPKJixP+sWMssCAdwZDJIfbYO1 XBCbPTfTjHQj2Pt/n+taGYvagAoAKACgAoAKACgAoAKAFQkNlQCc5waGho84u/EVz4H1xvDS WBv7NiLmycTL5kdu5O6IhiBlW3BTnkbRx28nEYaHxX3OqnPodPHqesXggaDTJLbY5kkEsqss yYOFUg8N359CK4rRSsmb63NnJKqxBUkBirEcHv8A5HFc70NEw4AJ7UhnL/Eq2uj4fXU9OQyX ejzC8RR/y0UKyyKD6lGb8q6MM0pcjejM6i0utzz/AFXRNTt7HQbXT7We60/UrW2uruOBSZDJ FCUkUdlMkbd+pXjJNdsZxu5PdX+5v+vvMWnpbqdV4qt9c13SIJNO0ySw0/SpYbiHT5Ngmu/L dTjaDtjRVBwCSSxAOO+Ea1KO8rtp37L79Ryg+iKurnWr/VbTxNFoOorFb3kEUGnsqifywJHe RhnC5Z1GCeME9KpckYulzb3+Ww7y10JftHi//hJ1vm0S3tpL7TxbwYkMsVmBJuLTvwCQGJCr nnpgZznah7JPmuk/mHvc2xY8a6FdaZ8Pbm30eSaW6NxHc3M4h8ya5cyqzybRwW3bSB0woHTk FKopVlKatv6bf1ccoNQcUzkbnS9a0W8sNalvNYtrK4vwzmaFLq6nmMbgSNGoIXOQioS2M84r pUoTi4u17brRehD5lqdhDfa1aaHdm3tdem1O8lFtZjVTECjFCfNxGAI0UHnPsOtcjp05TtJJ L5r/AIc0TdnYg8LLqPhzxPHYahpkFhYarEqRNb3JmQ3MS4LE4GCyAZz1ZOtOq6c4pwd3+j/y evzFC6djvxyfQY9O/wDnFcZuGPSgAAxQMU/pQIw/DVx9p13XZZoprW4aSKMW04AYRop2yZ6E Md54yOMdc17+CioxtE8+re50X0ruMAoAKACgAoAO9ABQAUAFABQAUAFABQAUAFABQAUAAwrA kquD1PHfv+tAbHh0t9dfD34x2dpNKYdCuHdokCgLHFO2SPokozjtt96zaNEzvfGXh3wrYWGq S61fyaWNUuIrrKS/Otwn8cSAZLHPOBznt2kZwniHVrz4ueKYtB0yGWw0TTG827lul+ZmGQC4 B69QF68sT04pIHodxNocGoSQ2t3LPewQbVSCRtsKBRgYiXCgDpyDgVVkRc6qLTbb+zTp5hjF vJG0TRqAvynIYdOM47Y4wQKdlYLnzY3h8aX41XSbqOKSS0naFQ5ARyPmgYr3D5APGKzfkWex eELmOw8UpHbLt0/XrbzIQq9Jo/mxx3Mb7vqpqokM7W51CytrVruS5iEIBIkDgg4BJxjrwCeP SrJIrTWLG8u3toJwZ42dPLbhm2FQ+B32llB9CcdeKB2Lw6ZHI9qBBxzyOKBk9ocSrnjH6UmC NYEdqzNBaACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKAENAGDr+q2NheWsNzcLFLcsFjXH/ AI8fb36Cqi7CaMzQtesNas4Lm1Zo/tLSCGKcBZXCNgkL+IPH96quSanQ498frj+fFMkDx1GM evGKAG718zy967/7mefyoAd6YwPc0DKmn6nbaglwbSUEQTvCxDAkMhx+HOaNBGS91Hq3jKO1 4NnoxLt6Pesp2qP9xGZsdmde+KiTNEjhPi94sivNOGiWbhvtpMks3BMNrGMMy+hchh17EfxZ qExmz8NfCmk2vha2hjW6S+KtNNfW8jxDe3HlhwcSBANp4ZevTcRV8pNzidJibwB8Q7vw7cWz X9hesl1YkqmQQDgqp4z1U4wTtGOoFJq2w0zurfwnoesxx33hKWDStVtJ4plIi3eSyqVCNC2C q4Y5GBzk81Fyji/F3g3Ur3Wtf1TxLdSakdN0dp1ufJ8qEyMpEcca54VeT/vDJ65LTDY1dD1C +0T4a6t4z1SVE1nXBHb27vwIo8eXF17YDNgdgDQI634Q6KNJ8F2su1lmvf3zbsBhH/ApIA/h IP1Y+1apWREjsifb1xTJEoAKACgAoAKACgAoAKACgAP4/h1oA57xRoVzc6haa3pRxqFnFJbt GjKhngf7yhm4Vwx3Lu+XIwcAk1jWpe0jY0hLlZnaB4i1GTWptO12G3sTbIhMkjrEZy/3SE3N nIU8g4JB9OPFr4f2aTR2QnzHWlhtHPYdR/n0rkexvohAeOByBUodjmPFd5rsOt6NaaDc2EK3 wnBa8gMg3Iu7qCD03flXVSVNwc5rYwk5X0Zy134i1xvEl9per+KtO0aDTrXzJp7C3Db3ZgBG VkJO8AjhQeuODW8aNPlU4Ru33J5nzWK8fiLxDBqJtvEnittCtJIvPs57jToluLhd2350IIT1 AAzjBOKqVOnyfu4t282S5S2bNnUdc1NfD+ntoOoyaxcIH1Ga4+z+S0lrG2WTbjCl/ujgcA1n CnHnleNu2t7Pvo9SnLTRk3h/xU0vi7XPtV1u0Y2y3VhKR8qxxxoZCD16SA57VNSioxi0lzK1 /O5Sm7mn4F1651rSr691LEEkV7Mu11CmCMBWXfz1CnPOKyr01GUYLW/f8SoS0bMjS/Gk0F9q d5qscyWt1BDPpFsigSTRFzEFHAO92KHBPAcHjmtvYKVlBrzf+XQz5tbFp5PGNuSz6l4fSaWI z/YpYZMwhR8yoVYGQAEZJ7k4xms37HonZdVrf17D95alvwfqetX9hZanrlzpItr+BHt47aOR JfMf5gpLMcnGeB3+lKso021Tvp6Fxb3ZuWep2N7bwXFndwyw3O7yXVxiTbndt9cYP5VhKLi2 uxaaLYzUlCmgBOihux6HtTSEYsMqSeOF+zkuE0+SK6HTbiZDHkdjky49vxr2MvT5Wzjrux0P Un2616hyBQAUAFABQAUAFABQAUAFABQAdKACgAoAKADI9aAD04PPTjrQAblPcfQkfqKBnPeM fBekeL47VdYWcGzLbHicAgOMMpyDxwOOOe/JpNAmYuueDzo+gXV34Ts2vvEQh2RX19P5two4 GVkbgEL06YPc9Knl7FJkXgnw0ng3wxFY8NqFx+9u5VHLSEdM9wvQdO5xzTWgmzrNLsiITuZo 3YYDAYIJ7/hj6UxFTTdcuE1Q6dqyKkhCKjKMKXxwM/3XwWQ/7yH5lpD0PJviZp+3xGbq8unO r287QJuwq3URDPA+R04DRexVT65l2KR3NjG3iXwdp2u6D5KXzItzDGoUbbqHdwB23ASIR6OD 0GaV7BY4O/1m1W1uWtriRrH7VZSQRsMGJG8/eoU9xjafp702+grW2MpfEd1BqWoWkVx5U13F FaXV1nIRGLSzAEcj5nfp/dPXPExF0PXPAWvx3WmS3tyos7ORCbOLecwWsJVFyvIBJOdw65Ax 8oxpF3C3Y2tJ1pLvUXszIv2gh3MQGRCAcBPqMMCem4MBnacUIyvD3xH0/VPHsnhuxglm2mRF uEBKjYDkt7Z4z9KltWKSPS15qCh1ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFADWxjrigD yf4/m3gtdIvpb86c8BnMcyoWZ32ArFgD+JgvXjigDzOfxHPcKj6Zem3TyzHNexZBtxI5YxI+ N2eNowNzZLHjApXYtDq9H114YbXWPEGp37WNmwNvbttweoBdnIQEjoFZ24PK4xS5mTY6Pw98 TdJ8Q3L2lhb3KSl8IQm8hQSDI4UbUHTqe/Paqc2tgtY1NZ16z0KwlupPKU+XI8KsuWuWRdzZ PYDpx6iiGm5JS8Q+O7LTtFu7j7THDLJcNa2ak5Z9qgGQKOSAwfGOpAHJxV3RSR5zofifU/DG kww3FuqQRTtfzxgkycEBQ4H3QX65J5HscZqQ7I6+K8i0rw0v2mfHmQFricgKzSsPMmk/3gc4 PbbGRnpQUcB4Rnl13Wrm71iCCHSbaJHSKVdkCqXxEkhGWZcqCIwMuVUDAGapITPYNN8UC5v4 bSJ4IYkRSWkRvNlxkYEa5EeSeASWA6r3q0Qzn/jr4fmu/D9vr+nKy6hoj+crqOfKz8xPrg7T n2ak9ho1PDElp4i0uxvr60MU8sIdH5jmhOOQj8MOfwp2vsP0NLVP7YtrSW2vLZPE2kzriSPC x3Sxnr8uNs2R6bCfeocew7nB+JYV+IfiXRvDmiwXNr4d0fcLqSSBo/KIT/VlWwQQq7QSOrGk kF0euxosUaxxKERAFVB/ABgY/wA/0rVbENjulAgoAKACgAoAKACgAoAKACgAoAXjocc+vT8a BnKaxNbWvjq1n1RFEJstthI4AVZTKfNbJ6MQYR3yPbJrzMdGVtDootLc6NMH5ugbkY/Dn+XP v7V4vWx3Cjr3PfgU0F0c14t0TUtY1DR59Lvo7I2ckvmzlQzqjxhTsBBG7sCenXtit6U4U1Ln VzKcG3oV/wDhANHbVRJNZ29xp6WH2VIZQXfeZCzSFjn5jnlvvZ6HiqWJny2e9737+XoHsyjb eDPENtqguoPFSqsUAtYZHsFlmEQcsoZmPJHQt1IxzVe3g1bl693b8PyJVJ30di7B4Cs7i4uL zxHfXWuXdwoR2mYxRbB/D5cZAx1POep+tT9Y5Uo01ZItU0ZsPwyitrC0s4L8tBBqT3D+YnL2 0gVXgOPvAhF5P+FX9ak3zPtb5olU+U17/wAIy3Ftf2cOoPHY6vftdXwxiTyyqhooyOm4qMns M1EK0U02tUv1/wCHB07XSMrXvhx5s2l3uhancQajp8gaOTUJ5LtCvHG1iQMEDoMcdK0ji9HG a08vL/MJUtrHQaT4aTTlubq4uZdU1e5iaOW9ueuMHCovSNMnOF9vSueVTmSilZLotn6+Y1Cy ZRsvDF1P4M0DTb2RbS+0preUSR/OEeI9B9V4z71pKso1ZSWqd/zDkbSTJrLwhFZXVrNBeSA2 moT3sK+WoCLMCHh46rljyeff0Uq9+nRL7g9n5nTHjavUnoO+a5lGxr1EyO2OuB9fSgexyviv xhBoojiFvdLLcu0KN9ldmcjtGAMSMQSBlgMkduK6aFDnehhOdjR8FabfW9rPqOsDZfX7b/J3 b/s0Q+5Hnu3LFjwCTxxXvUaapRsjhnJtnQdMD0rYgKACgAoAKACgAoAKACgAoABxQApoASgA +mfpQAemO/AxQOwE4UsXCKoyWZsAD6/gfypXsBip4ltrzzBoUEmqGPO+RCsVumOuZX+9/wAA zUynYaizJbxfdGQos2gxPH95ZL2YofXEojCnHfHSp9oaeyKkHxEWZ2htotHnuFywMOq+YrfT bGW7dACaPaeQKn5kr/ECPTLeWfxBp80EEcixNLbROfIJAO2ZHAdCBhgejZ4JqlNCdNo0f7d8 PXVpBqI1ezFvcMEjd5NuZCCQuDggkYPToc1V0RYZc+KTb6mtrYaabq0a381bsSGFCwOCvKYz jB696lyihbHJeN7zxFrlzGdO061t7e2Quri4JkmzkmFj9cMDjhlDZBrN1V0GrHn3iqK/uEsP EGpbb22vGEl3DGpj3sCA25RgIxAO4jjcpPGaFNN2KTNzwDd6v4asliswDZJqqSqZ12losGLc vpkkbh649aTaTC5ieJGkuPFMNv5McUesTWk7RqMLEcsZAB2XezE55APNJPS4EXiWC21DxDbx 2yx2OlIj3LSRJhghOBx1YkbR9Xb3oT0EtjoLx/FBWK40SzESSKqW1uEUpCg3FTkngqdnJ6sO M7RRGoo7iQ7w/Za5ot+Lq91VrJFWSOSVELSTSlQMRBsFto4BHyjHfJp+0vsO56V8LNOs9PkS OytkiAt8MxVfMJyMh2xyT1J9/TFZwk3OwJ62PSkGBgVuUOoAKACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAay5HQUAcN8VNN0+XRRd3ujSatMjiOKOPlxnOcHOF44z14HXtMnYTPH9ctbyMW z6lpiafAGR0gghLxwhhtVI1QbXkIHLk4HOApxUp9hGgdctprvT1/su2kNtiOGJoGuLjaTlkC BQoLKCAeSOTk81KugEh8PaJczKPDxufD1+kbvLcSXpVowW6MgT51BHTIXIxmnz23D1Nuew1H XL21uINds9Vlhtdkd6YAqxIwGVESN+8Y4B+Y7eRgHPL59AuiCTwXH9pxDqs80ryZE16FbyAz Zd0QYAkJ/iOcemQMxz3dg5jhtY0E6zFPqVhfLBEUcpC8bGVYUVipyvJDhlPI5Mg9KtSSdh7F TVtTu9Z0R3SPyLaziitxbtIEkkOVZwoJySSFJxk4WMZ9b0GX/Dlp4mv0k1aPT7eWIs32eOWX yFUsAokKdcbcKBuHAwMjOZc0hXSPSNEl1fStNEcd1YQ6iyAtO0BnaRuO5ZNigcAKABlRyeaX tiXIrT3HjqW5eFtWiFrg/vhbxIzk8EBQpKqORzk8nmk6tloF+xZhk8QQ+SYLq2uJEkBbchaW dBksoYkLk8YyAMGnGrcDd034jeEr+ZLSPWYYbgsVMVwrRMHB5BJAUnPHXAroTQWNzTNW03Up 5l0y5iuSmRM8BDKuMZBYcd+B1zTuugrF/oMnt8rein+g570CEYhThvlPo3B6Z6UAA9ufpQAH 5Rk4AHOTwB+NABigA6UAFABQAUAFABQAUAHT2/D/AD/n2oAw/G3h0eJtCls1m+zXKnzLWcDP lvgjn2IJHHYg9RUuKasyk7M5zwRretSadb2F9p5mubMtBOzMBygwQxxhXGQDzkgg4GefBxFK MJXO6ErrQ6ue9a1t4pbyAxCWdIT84YLk4BJxXLGPNsa8yRdG0rngjH8Pp6f59ahFCjgcfyqr gJ9OlSMKAD8eKBC+1AAMYyO1ABxjPA/GmAgBUeg9DSGA+9wce1AjI8Q69HpP2a3jt5LzUL9y ltZxnDS4GWJzwFVeWJFbUqXtPeeiIlKxT1oa5puj3mqf2nEZrWB7g2ptgICFBZlB++AcEbt3 vgdKdNQlPkSJle1y5baVfX15b3utXUDR2zrLbW9srqofbgyOz/MT8x2rgAe55HtUMLClscc6 jlsbvcYxx046V2GTFoEFABQAUAFABQAUAFABQAUAFABg+hoAOgBPAPTNAFTUtUsNKiEmpXkF qhOFEz7SxzjAHUn6CjYaMDXfFU0FzbW9lbfZ4po3llur6Jv3UKkDd5Od/wAzMAN+0dTjAJrN yLUbnLw6rc+Jr530u5uZlLkWd1qiJ9mLZx8keFVjk4OA54PK8ZzcmaxijptN8O21tbhPFOsP rF03zypeTqIg3cBOOM9NxPvjjENs0UUkR+KhZXkltcW0c00cCshmsNON6rDOPLGw4BBGSCp6 0kErdDirnxlZ3lv9lh1nxDpsNocMBbW9mm/IAVwhXOP7mVOOauxF4o5vx3ql5dWelX4v0vRc QNZvdQ4R5kOGAlgYfK23nJ3BsggjAqoqwpM0dPGqSX7apa6VbwXcp2vOu3zMgYJ5L+X6YU4H 0xUN2MWWLoeMMOZbU3USfN5R81GycDJZcFu3r0rO0RWRJZS62yusulXEW49Ibm5Kg854bHX6 0NR6C06GzpRu4oPst7Yv5EpPO8OMN1DgsWYdvU5I96zemqYB4jtSLA28EcUMbRsIsDaqSbTj OMDBAHb7yr7CtE77hch1i1Q+INLuFWJo7oqGXZwMYdsdzkMRzjgUJ9AIbjRFi1CKRIF2ySTO 6wwjIQBdq5wMHb8oHq7H2M82gLY2NNhubaxuPtMu6Vizhc4WLH3V47DjpjsO2StxFeTTrXWF tdR3ukrxId0TY+U8kKedpJ/iHPHbggvYDsvhtpaWXneUI0gjHlwpHnO3g7nJ6knP8+pramtb lRO66VsWLQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAc940ZRpkYbnMq8fn3rOpsTI5 xru4trSaW1jaSYvtRA2ADg5JPHy8Hpzxjvms4vS4kcZNaNPqJF3KLCOFTPcyxS7EQN1UiMgb jgbu7YwML96roLmNp8Om2evpPpoubHT41CIGkc+cu043hj8xwSQAwUAnJx1V0wZ3i39sdHI0 57aNymzEfHlqf4sBcM2OQMYz3AIpOQjm7Dw/cR3E93DqFxdPMSRJcuSXyf49uDtCjhAAM8E7 c1N76juakhtNONsjQjy5ECGUAL1PCkdPwz+lRJtsnU47xDoi3U7+IDqknl5EVrE9v8shIPyR YIB4HLMQDjnIGDspXWpSY2w02/0vTY9SilgluZpB8t47Fo5jxkL93IHPK5GBxxwcyYXRekj1 rT4zcXjTlDmKeGQbvKGBtyi5ILHlUyWb+JlXOXo9h6Fq2fVXuYWvFeNXUSeWwVmxgBc4+XzD 2T7ideo5zaJsaOzUIrqWXMc0CDaGizJGT97aCOpHfqf7xGcUpRsInTZdPsltEEmNrJJAHBxz wwOB9Ov0qbsDndU8LOurPFpt09v9ohNxJb+c8cMjA7SSIypzgjBx/F+NawqOKKTMSfTtX8KR R6i2lqEjAZrnTr52uYTnAJJJGex+QgjA461tGomO6NJ/jNcfZbhWyLj7L5dvKlt5IhlYk7m+ ZgcKCRgcknjArS4WKdv8Vm8oSEeIdRl2LuH20xIvbIEYA+8T1Hei47Bd/EPXpbuWw+zXGhNE R5k11fTHy+OMknjPY8+2aQWR7pol297othdzRmKW4topHjYYZWKAkYrQzehdJx7d6VwE+lMA 74oAKACgAoAKACgAHFAGXrGgWepuJ2M1reIB5d3bSmOVCvCk9nwCfvhuCazlTjPdFKTRg6lo fiiTTrmwa+s9UhmiMatIvkyqw+ZZOAATkAYOBxnHY8bwNO90bqux/gzxDc6pp6G8tJ/OEauz 7c8tngnvg7hnqCpBA5z5laChJnVB3R06kYyFx7Ecj6+lcpoL2z0FOwxAR257YHX/ADz+FLyC 4KQ2NpDZOBg55o7CuhcjGcgAd89KAEDxksqupK43DPK59fTofyNC0QrodjP3RnnHSiwXRkze JdEi1c6TLqEK36pvaEk7hwD+eCDjrjmtY0p8t7E86vYnl1eyijLi4hICGQ5kACqOCxPYA8En oalU59h8yOZtjf3/AImi8T22jTXNmbQ2UAjkWOdsMGEvlyEAKRnABzggkYNeksLOVOyfU5nV tIh12413VtYt9JtbG1t1QLdSQXL+YkY3fu3nKcE8fLEpOSMs2ABSVKOGXNN3HzOo9NjoNLm1 W08RxWN7qf8Aacc1nJPKDapE0BVkXOV7Nl+GyflODXZhcQ6ybaMKsFT2OhHoewB+gPSu0xCg AoAKACgAoAKACgA7UAFABQApBGMgjJwOOp9KAIbu4t7K1e5vZY7eCMEtJKQirj1JPFK6Ged6 98W7RBMnhi3F6VOJL+5fyLVGHoSQ0h9qV+xVjL0PxLqlrZ6j401Sxm1QW0Cra3Nxtt7eFDjd sbaGy7bVAAOCOTzU3KskR3ni3QRbW+v+KpZdb1bUIopbfSIR+5tVyxVXGduQWY5fJ6HFZtXL TUVcgju9T1C6m168vDpkl2gQ21mAvlxgAKgkGXJOACFxncQOvEOVtiJTuYkXgzStR1A3GowS QLeTskaQyBW3dWPdRgnnGQPujJBNLnfchvzOytvCNrp1r5lqZZ7uM5hnMwjkDbcA+YoHU5yS DkdQehjmbe4czRVutCv/ABIVl1w3KSyW7+aroqJJIDtiRtrHzCo3EuFXK4UcE1pzcq0NHJGO vhrV9MvI7i9aS8dVKiVAhZRtVQmSrZjCg4XaoB9c5ocrqxm5dDZj+zvbhdQzbwMMBpNKiCDj geaN649CCM4qHoBPBo8tvOWtHXyD1MEzwOBx2XKH8QKnmEasKGOERGR5ADwZMMT9T0z+FQ2I dIyoRlgpYgDLHJPJwOfQH8qLAW7qFBDD5m0rIAPnwVJzx+v5nFV6AQxDZMmQCOAM8kcYB9iQ D/KkAt1tVtqhV5yCBjt1+vH60PQDmbbVWXxdquk3bFoEhEsXbEexSw9sYf8ASqa91WHYseFr 22k0iMxTD7OMGMt8vDMVx7fMrce9El0Bo9L8DLi1mP0rWlsOOx09bFhQAUAFABQAUAFABQAU AFABQAUAFABQAUAFABQAUAYHjOFn0+N1GVjfJGOvBrKptYmWx5nqGqy2Pi/RbEIzQ39rOp2t 91lIfP5D9azXwkpaGrfWts7RpJDGxVxKcKMF9uN2MdcdAeOKgXoV77SbLV4I45FDGPCpKgG+ PBwQpIOBkD6Y7YFC0DUbHbW1rPst4ngUAxpGSwG0BdzgdgSTg9WwTnoKctgLsbExOnmtFuUj cjHI/wA/yzSWiArxBbi2eGaJGkV/MGRjMi9efcYI+lKLQEtylujQ4WMxSYkRcDhhgBgD/EO5 wPUYxmnewyG7soJt9wFPnqdwYAEq453DPTcODyO3c5oQtCaVYr+GFp9zNC2CqyOgkX0YKVzj kY6HPPrTvYYmn2UCWToxMtxGvDuQMxnqigABRyeAO/JPJJe+wXHWsdtb2UkYWOCJBuJztVcd wOiL9OB+eVe4ireanZ2axwSo0UkO3e6x/IgYkKzd8E5Ge3frT5b7Ac1PqU1v4oeSUHbHeRxy YbIaGePYrKfQtFHntk8Vf2S7aFu+8XWVvrk+lLG0pt49zy5+VTkfJ/tdf19qnk925C2uZ3im AeItSt9LsrSzSdkW6e9ncO0KqwBDRDJbhuA3Bz+I1p3W5cbjrabSbDT4FdT4i1a83qiDyxYp s6kqi7to3AsPvnOD0rexRi6PNZ6S11AjQPNfvtmj2bYol43CODcBIcjswbAxjjlIC/afEPWd G1L+y/Ds39pWkRCrDqCkSMxYgJEgxIAf7rbuDnpVXJaO68OfEiKe6u7TxNZx6BJbSonnPIWt 2c4Yp5gUKpGRwSBzRzIOV2uYtv8AGexttdkj1SOIaTNIyWl1buJHVEO0GVfQ4zwM807oLHpm nX9nqllHeabcxXdtJ9ySJtwNCZNiyPYE49B0piD/ACKACgAoAKACgAoAAACD29BQNaHJa1oW r6fcTX/hhkZ3LP8AZWIQgscsEfGNrH5trDhskMASDx1sLGeptCq46FaH4gWEESRa7a3mi3oX 95DdW8gUMP7rqpDDj19K8+eBqX02OhV1Ym1TxDq1zpa3XhPRZruRlLmS6jeFAmOCAQrMf9kY PIyeadLANv3iZV49EF7qGpz6ZDDpsGo3Fw00T3k32Zrdo0DDzBEsm07sKcLzgE55pRw0uf3k N1VYqXd34i0a4vLw2EstnezNJFCIvNEWRysoj+ZCcZ3AOMHGARk6SwT5Y+go1FcnTxLr1yEj svD7+eSBvbzdg99zIv6n8K544W7NHMktfCusr5mpJrf2XWL1SLvMXnQsnIRFUlShQHAZTySS Qa9SOFi4JNHL7WSehOfDmq3VrFYatqEc8EciyG6hlljnO1s4Az8uRkE56HgCoWCjGXMhuu2j TTwxow0+WxlsI7i3nfzJUuGMvmP/AHmZsnp0/KuyMIxVrGLk27lXT/A/hjT5RJa6NboQVb5i 79DxwWx6Yz6Zqrdg5joD09Tj6D/D6cdaLdiTnG0bVrXW7660yfTjFfSCUvdK/mQkIFxwPnXj O3KgZPWuSthVUle5vGryrQxdY1C90HVxpeiSR3OqXMP2m6urhfMllb5hFCkf8K5BPZVQEnk8 uMVRVohfm3O1sLqC7tUmt7m3uUPBkt5A6FxgHBHXnv3x2rqWuxg9HYsZx3xTAM844H40AA6A 9j0NABQAUAFABQAEgDnigAyPUDAz+HrRYCK8ubextJLq8mjgt4lLPLIwVVA5yT2oA4PxT8Ur Owkms9As5L+8VMtLIpigiBAPzE7SRgjv3HNK5VjyLWZvEPi+5SbXdXL2zElFUbYAM4BRBjuT yw5weTipZSSNLT9Ms5JbfSdCjaS/vXWGFmYGVVK5fDNgZC5OB5fXHPWkM9C+PF8o8Naf4fMa 2cDxC7ulTH7mOMBUiUZwSXO0f7vsTU3A8ts5bTR9HS9uWMiyYlWEZAJA2oATzyAfmPRd2MFh Uy1ZNx9l4wuGig1bVGP2aA+TBbW7bCzbcO/X7wQlQW6A8YOKnkQWOz8JXF1qN1pFxfWsUBuY XuY0U8RQIQqDn1LEgeijrnNRKFhWOk8S3SWUcfkO0TrcW5O1sHYZAMEemM0opEjtI1KPVbaO 5jJG9VdlPJXIyoPrwSOPaoYWLaPtLylwgY/MxbGKSWoEWjXNvqmmrd2oUQ3ALEIo+9u54Hfj OTnPoKt3QxyBhlVxhePQD6egrNaCGsu1ck/0osBzvxAu59O0a11G12iS2vY3DP8AdXcrKCfb LDPtmtILWxSNrUJP7Y8BxzRlozLaJMjKMFDw+R9COPpQ7JAVdLuvtV/DOW2/bLOOXyyfusrl WH/jwqWJqxpzFS5KNkH1PIqWxHm3iC6Ft8W4N0i7JbZI2z6MCuPyYmuiKvApbC+D5ml0+/s3 yJ4Xm8tS3HDCVce+VkpS2TA9x8AXRngkC4MbKJFPfnpn8/1p0tmgiddWxYUAFABQAUAFABQA UAFABQAUAFABQAUAFABQAUAFAHD/ABm1i40HwJd6hZLE80MkeFlUsuGYKeP+BUmriZ5zNepf +IfBmoKq4mM5A+sGT/KueK3RJ1RlTzWmlO2MEfMR05GPzyBWfVEpEehyRywuY3jkRZ5ULJ3P mN/iM/U1bsN7mhdLtiVQOASOBgfQfnSlsBzviBmtoY7mEEvbljt5w4++Af8AvjH404oQmiXp 1O0i1CDGJPmKrn5WBZSPyGahx5XoFg8STS2thDqUZLrpkpmkRQMyQkYcfgpJ/CqitbDLljq1 vLeCBJAZTGs8Y/57RH+NfXBPPpwelJJg1YsEbJ5Yl/iG6Mj+L2/Ok9xGZo2twXyRTwAI4cxT Qk/Pby90Yds4fB6HFNxa1QbF+KWC9gkeLLx7mikV15Ug7SpB9BwQeuaT0GZ93pchtC0E0hEA P2fnDhMZaM+v3VKsehVfTm4uwjl/Eeh6+1wt7pQtyIv+WRTBYxyeYgAPAQtlgCeMsvQCtFJF XOe8O6Jr17fs0lpJGWJaWW5AjV3Y5cnb80gznCjj6Vbkth6FbxPpmraReRaXLfJBAw85Xt1Y LIeegABJGerYxn2ojKIJroWtM0271S7iMlydPP30ultSrSY+7IQG6gH75A+8Rlgc0Sk0Nux0 M+g3lxeSN4yvTqFuqjyrqOyjkVD/ABb1yH4H91hxznrSVa+wuYqeMvDllodlbGe1a5srgh4b u3Zpo5FBX5VYrvjyM5BJ4AwxxWo7on0KDTbC7k0vRvGa6bFc2hmn82QPDM0iYKIDgLgZJJbP 3euOIn5GkH0TscX4m0C807U30GS7jkNjHva4EgMZDruXaP4c98Z3E59qaegmiPw7qt34UmaW xv7mG73hAltJwDz1QgpKnHI46iq2JseleHPjvbuY4PEulNEwOGurUcfUxnJH4E/SqT7kuPY9 Y0bWdM1u0F3o99BdwE4LRt0Pow6qfancmxe6cdz0Hr9PWmIKACgAoAKACgAwBxgflQMUEjGG Iwex9KAuIfvbiAT36/nzntTAMfKBxx0/z7+velougCjIP3j0/wA/pQLcQgeg4/X607hoHHGB S0WlgsFABQAUAFAB7YHIPX6UAUNc01NW0y7sxN9mN4gjknSMF9pOWB9cj5fpmk7dh3sYHivX 7H4c+FvOJFxdTSnyY3bY0zscluP4V9AMYCrkE1KXKtB2vqeb3PxC8ea9okVz4esru3EC+WZr Wx8wTEZLvnaQvbhffOeCIc7OxahpcueFPi7PZSOmv38F/EpCMFVo5gMjLoojVWXn/VkhhgkE 9DakiWj2DS9Rs9WsI9Q02dLq2nG5JY/4h6HuOeMHnPFWSWqBB2oACMdjjse1ABjDbe47UAY3 iLxZoPhmPdreqQWzYz5X3pD9FGT+lK5VjgNR+ONrPut/DGlyXEwJw982wP7LEhLMTjgk8d8d Km5SRwureJ/Emu3lxd6xcG3gvTtgs4yHXajcbU/iIYD5icHbznbgFwsiiyBnaa6J3Z3PcSuJ MMM5YdFwAPRiMAHrQBBPrcBSaVFkmaIBeckop6c5wABwAMHlzU3GJpXifW9F1W5vNAeD7e8A iM0cSuYg5UlUyME7iB0OAMDNK4CeI9UuJNWuLnUhdSTpgyGa6eZkZV2qu8kDl9zEdsEDGKWj 2EYtpM+pwG3mjEhixIJ958xUC4KKCcHPy/kadtR2KtxOk8kcNusi2kX3VkPTJGST05J9OmKd gPVvheki6ZrOuySu0ksAVHcqMbIyxA9FDEDt0FYy+JIllTxBr1w3hiKW6cvcTpp6B3bGWw0z nPtlfzFCVmwSOg8CSLaiW0lkjR44MSDO3yzHKw5B6HbIv5VEkS7E7azJceHNSbafMt9QktmD nI2h1bn22Gi3vWQWK3wmfZa37RyH7PdD7TCjEbl5Ktx2GcfrVTG0dKlzi9e3OAPJV1Pry2f5 GsSSS5WP7GxlcKjAqSTjAPFAHJeMA118O2W5BZ4HjW4Dd9koRv5E/jWkNJDW4ngjUJZNO0vS yxeKXTZVZS3KlJdg/DDEfhTqK1x2sQaNqb/2Bo+tsgQWn2mK4UPwQSRnP+8AaJJc9hM661la 5hE6y+ZFMBJCw6BWQMP69aykrCeh5b8UoZG8WQ3tgziYwxKGVeB8vHJ/L6muin8Jcdiz4U1a 3fxfeoXWMTSx3Cnn94Gwu3rxhZX/AC5omtAa7HtXwoJ+wqrZykfl9em1ip/lU09GKO539blh QAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAh6cUAcB8fED/CnWeOVEJ9P+WqUAeJWGtmCz +H04YeYk7xsD0C7xH/I1lazZJ6XqbeUkYLMsSsd4AyWUAbc/SsoIlEXgi9gvtBiuLVdkbqjA AYwfLAP/AI8rU5KzB7lbV9cuFuNdslKj7EnnROOWUARAjH4mm1oBPrl6kk+o2pBj+zLDLn+8 rsRn6dRUrTYLdjB8DSJZalqOmPtj3MZ4l7nGNwHuAyUS1V0NrQ7DajrJDKN0cmVfAz8pHzAf UZz9fSoT2aJPFmvryytYpbZ/MufC94VzuHz25b5fqMgrx2celdSitf61NLHsGnanaarpdtfW RUwTJlAzDcn95T7qTzXPJcpmcF42SXR/Fx1G1jKxXtmVl2/30wQ59cHYST02k1pC0o2LSOm8 Nawl7dSOFYC/tEvI16Hco8uZPYghDjv61DRL0OlsWQuVdtquOGbg+1ShFSDULe+e4SCfzWtG EbnnCntn6849cGk1YNiKSN7qwjKRjfCXznG7GckD0IORj3o1C5HqKu8UU1uVScoUWQqDjI/Q Zx9aadgKXheK31+b+1kRIZHXE1u+f3c4ZlkYYPDZ5BGMgjp2uaGzZhj3Dynxuzt57nqM98HP PP8AhWa0EYfw78WNoup33hy7eKXS4JHaGeDg2yk/MJEz/qxn7w4HXocjtpvTUux3x0jQ9Ftn vrDw7aOAC5+x2kRcqeSQSBnjnGelaO1hJvofNdrLbtbwTBwodSzN5arhyW57AHrggdB6jFRs Wy0+mpIjyQSIy9WWIkhhk9s7sde+flzQBz+sWTx3Txqpk2Kr7ixZiuAOeeAMHg8jnng0gDT9 TvNI1AXmkm50y7j2keUxx68j0Pocg+9MD1nw38dZhLHD4i0yNoSoD3NkSGP+15ecHrggH6U0 xNHrmi61puu2K3mj3sN5AOC0TZIPoR1B9iKq5FmXx0yPXFMQDpQADigBaAA47UAJQAdKACgA oAKACgAoAKACgAoAKAEZ1jQySP5aJlmYkgAAZ9aAPBPFlneePfibYW4sbi3sL23T7OZkHyx7 SS52n5cbi23IOSAQM4GTZslY7a6+LGhaFrDaNf6ZqGnWduPKt7hoSUdVOOFPO33GfoKxcW9U bc6TsauveEvDfjTT0uITFBcSqs0V9aBUlAYZXOOSCpPBwKlSaLajLY5r4Q6Nqmj63qltp98t /oNrcvbTMwKfvQow0ac4IJwTnBA5AwCeqLOSSSPVl+bp82eOPX0+tWZkVxdQWsDz3E0cMMY3 O7uFVR6knpSuM4jxH8WPDmkW3mWLSatM5Kotuu1WI9XbBP4Ci9tgsec698VfEWqQS232yLRF JOIbGIvNtz0LlsL39DU3KsjiotFubqFprlJo7h9zl7mYb3UDhtvUAdSzHAA9wDLZSRPbxW2m wrJDHNby7P3k/mEMwPXGAAFOOFyScnJI4oA67wx4E8R+IJlZLdNK090BF3doQW45ZI+GOOg4 HrkdKqzFdI17nwxoiSSWPhm0l8Va6SVkv7tv9CsTgAscfJkY4XLdO/SnYVzgNc0bT7O1D2fn XKMxt7OVchtQmB+edR2iXIVR3PGeDibWGRaj4cl0+4htVwj20Mk13cqc7GQAsq4OPlb5AcD5 93pSaAo61qM4sbZBF5Md0HmDM2XkTPlpu9wI2577ie9CQ7FPSJXS1uUt5xAzFNzsvAXeO/bn B/TuaTA0P7Itora+KySNmISWwwQ8gB5BHou1yf8AcpgdjbeI7Wx+FmoWGnsFuIYo4pGUcEzk l8H/AHcj6isrXnckzPEupSpouiQ2BWb7VJNtVo8hsQxW44Pf5X9OTmtEtyrFS71pptZ124Xc EvdOjV9nUNtjZvx+Vhn3qbKwmkbtldyXPw88Qsrgu17MS/U7fKB7e3FJr3lYTVmanwoa2U3E ummRrVreWFd4wflmVgCOn3ZO3cVFTQUjdW9I8eS2XQfYVfBPH3m6f99c/hWenLcnoaeqI8ul XcKA7mhl2+u4KSp/BgPypK1wR59Hqdzqfwt1O5JCzmczsEPy7TKC3uOQfwNbuNpF21MfwVqt xb3+qyoWYW2nyCIA52h5A3/oT5/AU5rYJGr4Lf7d8KdZtSQWi88DJ7bQ3P4ipmrVEJ6M27TW zafC7SdRilZPINvG7KOdiy7GH5Ck4pzaHbU5HxpdwxXdvcxF2jktZY4XUcZ84tGSD6Bh+lXB WQR0RzOh3r2muwzGPH7tlf1IKEFuenBzVtXQ2fUPwvIDXiDkLNJ05xltw/Qg/wD66xgrMmO5 3y9OK3LFoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoARunFAHk/wC0vcSw+BYoUklSOa4A kCNtDAdA3tk5+oFAHzst5cJFo0c0ZSK0YzRsRjepkySPxU0rbjse6eKLpYdOY527opHPrgKG /wAPzrmhuZIwfg5fBvD8ljIpSW2LKc8Z5LD/ANDI/CtKncqSNW+WLUfE2sGwicxnSLiCY44M wkIOT0yQB+ApPZEnNeLNTkuLXUZLSNjLHptlIxxncPODDHsMkc00kMwvGtzJa+I7S40x181A txHychgxO0Ac8qyk57DPTFVGOjuPoeinV4NT0WK/tZhGbdY7wxtkNGqMfMRsd+HB/CsOXlZN rHmXiRIfD/jm6ib57W7hZZ1RNoEcm4qQPULsbPqK6I6otbFXwn4tbStEvtKlmuYkmkSSCSFt ojYH5uhz8wAB/WhxTYmjvNWlHiPwDFrSKHnt4/NdAB/DlJO3QrvHPGPSsY+5NroCMPwjqJ0q wtcoZms75GjGST5cylZl45wrL+ue9aSWo2jtmvEfS9SaEeZ/ZUsiPgg7owoOc4/uN/47WKja VjM4DSfGH9m+IoL66WOS3usx3jqc5cAByPXkLIvHViB1NbuF1oW1oeiWUp0zxdepM7iDUY4X iJzgSDMb/QnMZ/EZ5rHSyRKXQsSRCI39ruO63mDLk/8ALOQZQfQMrCk46XCxyj3Euh+Lb97N mIvbdb9I1OAZASkgH6n8BV9AOqj1V5PD8WqmJpJGtS8katht6cOoPrkNzUta6CZm6T4eW68U RXOmEtaXpW8haMiOW3UkZkhY8YVm5jOQySEDPbppbWL6HpuqWJfw/e6fpiR28kltLFAB8qox UgcD7oyc4HQZxjoNrE+h5aPgveQWUf2DxBC7so8xLqzym8AHIIOcZwBx6+tTYq5zer/DXxhZ Rzj+xrfUEVsLNYz7ZMZ5ITPII4wVP6UrBdHHahqFxD/ol0by0lgYssV2vzRE5JGflODn0H60 iieKIziKaW1iuIEjaV5LZgzRrzkjkMCpyxHYY7UAUNUsnSfzLd/lOBscfNJ1O48BSCMMM9Q2 egNIBNI1O/0zURdaNdvZzLyphPls465wcgggA4J9MdssD13wF8ZS8raf4yBVtx236QkA+okQ fdx3K4xxx3qkyWux67ZXlrf2yXVjcxXNvIMrLE4ZT+Ip3JsTYpiCgAPBxQAuAaAAr70DEoEF ABQAUAFABQAUAFAB0Ge1AGb4olEHhrVZDtwLSQfPwMFSMn6Ak/hSew1uYngxtCutW1aXQ7h7 yVJEVpfJKxoRGFJTPVmABZhw2VJ6DPJJM7KbWjI/HWo6XLcWOl6tZxTafNdol3czxEwwHG9U LDHzE477QM5BzgzFaDZz+o6HqGtanP4u8Ba/GBI62ptQoWGWKPCHG47TjlhkAc5ByOdFKzsy HHsUvhv4+8KeGPBkVpqepS/2hG8ktwn2d2aR3YkEHofl2nOe4x1Odk7Iwa1M/XfjbPfKw8P2 4sYFXaZbiITTOxPCoo+UD3bPTpTuCVjzzVPFWt+Idra7qzSyxN+584HbHnksqKuATn73UY+m FcaSIGsZPkf7UfJJEcrFPKIDHgnOTgnnJHc/iBoa2nWa6dhLDTmvbosCyxjf5P1I56gEciiw ju/D3wsvtUnW+8QHyQR8qzKFYLnOBCvHUdXPp8venyiuekaR4L8P6VNFcwaZbvdxHK3MqBpc +oOAF9AAMAZwBk5qyJuzf5wQM88nnqfX60wKuo2tpLpk9tcjyrN42EqodgCY+fBAGBgfXqOO tAHk3gnw9P4413UPFM6yWNikRtNEVEBMKgFVdFPTYOR23MTzioRV7Ffxl4Vu4NQ1Yafa74bb ToYLGIZJePKxDPqWkZ5O+SgOfV2Fc82+JUSxeLLu0th/oumiKwjz/wBMo1Q/mVJ/H3qXoWYN taS+esDwzLJOilFxt3biCpweqnjmkB0l0+dKmm+0q0yL80jcFyWCsq/gQ3HUh6lDGawUi8K6 Vblgpu7hnkxtztjRVQ8HnO9z+nanazFYoX2tuLjSLi04ksYyy7k48wyu5OP+BCmBSiNxDqLR zAkr+7kXONyjgj8gaSA6mxuhpfw+voJGcG5lYIMcFiqg49sZPPqB1qeonuWfg3PJa68iTSHy bxJYkjyeJF2MePpxU1UTLY6fxJeLB428OatA6vZyq0Tyr0YMwTB+hYflWcF7rQLY2YNcuB4l 1rS3jX/RbZZbbIOS3ljeD7/MKlK0UxWscF4DxP4L16Hz23m1KBZG+RMnjHcdRn8K3no0U9yH wvD5GruoPEtpHHKAMAlZVRsevKZolsNlz4bq9vaeKtIkZQfLMYyeA3zR/wAyKU1syWQpFP8A 8KkubIsBJa3+w7Tkfezj+Z/Wl/y8H9ok8U6WG8P6PcQqFaNfLG7O0gB+friNTTi/eaBPc4LU ZFe83R9hsPPBxx+WK0KPo34AuWm1SFnVmhMav0yWCbM/kgqEtSVuewj9K0KFoAKACgAoAKAC gAoAKACgAoAKACgAoAKACgAoAKAPJv2jbJb/AMLQRNK0KwebdEjoxRQAp9ssKAPni71BpdGt bSa2xHbRrF5hOGALu+B7fPj8KSGeqeJbw3Pw/j1JcFJLEqxyBtLqoB9fvYH/AOqsIL3mZx3Z g/By+VdU+wXJ3GVJmyH+bK+WcfkDWlVe6OWx2lq0reJvEMMlzktbRhY9vJUr8gB78iUY6kHm s/sonocz45kl0u8MdlBHLHf2LWksQXO1ECyDA9QC34e9VDYpHD6je29xctAWytrFHCXZCokM Y2BiO3yqB8wzjPBOK1WiLSN7wXqsll4vh0ycKIJ4HhkjIAG4gE5GACSU9Oc56E1E0rEyRL41 gmuNT0uZRJ5yWk8TnbwfLU7SO5YjGR9MUofCOK0OIW0t/I1IsT5tuqyQnOQRvCsOOOhH5GtQ PT/DmrRaV4AaOC2863gvWs7uOV8syP1Kns2GXjpwaxt7xHU4i0jij1qJ9MdlBeFFbaXjDEjc eOcEqTjrgn0rX1NGdj4X1uXS7XXdQlXzEMMVyI4xk7Tuhbr1PAzzjGazktVYho80/etpO0h/ LVjgKBtJBOc9xjecHvn2rRdSj0sa4dQ+HtpqZcC7sVa1kbHzb1UPGx9CfLTnvWPL7xn1Oq1b VR/aWl3duiNDrlkFwTyrxgyqB9Q7D64pW0B9jzLxnPeWfiKSxt1+RbiXyHf5QBMgLpzxjJz1 6kmtYaopLQ3/AAQ7aj4On0uSf5JowURjgqzF04OfVV/Os5K0k0S99CTwB4kfRtQt9Ovpfm0t xNbyNkNJbtxIn4KxYD/Y9q1WmqGz6B4zgENjuP8AP+ea3uIMDoOg6f5/KgQYB4YAjp0H9aAM /XdB0vxBafZdYsortGGAXB3Jnur9VP0pWGmfPni74c+IfB189zp8D6hpOTIlxHHvKA5+WQAE jg4JGQc5z2qbWLuY8V+sTWoaIiCRdqRTHCHnghiSCA7EZzkc8Y6IYkVvZXd1JZX1rcK6yEW0 x+V3UHIQ9skhgM56+goAzJ9LMVyi2F6jEzGGJvmRmz0+UA4yMA46E496NtgJvCfibWfB+ox3 2nSshX5mtpCyxTr0+6CM8++ePrQFj6B8B/E3RfFSLBMV03UiB/o07BQ/Gfkcj5hj1wfrVrzI a7HcHgkYORzjH60yQ7DHOfz/ACoAOnTFACk0DEoAKBBQAUABIBx39KA2AD8u3vQMU4zgUCEP yj0Hvx3x/OgAA9jtoA4bxh8T9E8N6hqWkXCNLe29r5iKQDFJMw4iYjPsT2xnvxUtq2hSRQ+E V1ZzPfRJJ9onViPOB3RT4fLuhPbJU84z+PHNM6oW2Q9tXsrLxLd6LpmrXllqLSnbaaoftNtd MxyCpGXUHOeCMdSo5BVuw9E7MgvfFNj4Z8O+JIZ7GLRdSbcYtPhcOskjRgebGFH+rJySxwMg g4INXyk83Kmjwu4kl1rVZLhkdk2RoojIDYVFWNAT1IVB9ME81okkjFmnZ6TaSKJ794VgiO0N ESPN/wBxRj5Bjlz1PenoA+GaJF83TLJMocJLGpaQ+i45J7/NjHB4zyDQDsvB/wAOdb1VI71r c2FvP8/2i9cmUkjPCA5fHbcR24FVYR6z4P8ACGmeFIXNkrTXs3M99NgzTHvnrgeg6euapIhs 6AcAe3v0+lACUCHKuRkGgClq+nW+q6ZPp91vNvcrslCNtLLnkZ7A9D7UDJ7eCK2gjt7eNIYY lCxxpwqAdAB0A6dAMe56JKwDwF3Bivp29P8APA7UwPmTx94d1C2k02CeDbqOt391ceR3UM6J GD+GT+NQ0Wmbfxl0ptM1vw7YWtkWWx0lVWaP/WShCdxHuoBb8fQUWsCOOnvI9TtWIdWlmXBH Ro8ODwAeSzEtzj7z9hWdrFGReI+oanHawRBJgzRbm6yHccZ98YXj0FUIYlo8QLSyMvk7kYbe jZxtHqep/CgC9IqTSX807PMxmKnIKhQDkMe454/GkBe1OSK08L3enpeJOVvdseOpTAPf3A6e tJbg1robngRYre80K4b90IrwKwBxjfC+4ke4UfTFJ6g0Ylvrf27RotNcO6QTt97r5ch4APUY ODj1NHLYSVjsbi/trfx34d1O7uHhTU7Ax3DOuFXKlckf7w59MDBOKzivda8wSOL0+N9NsNSh VmOCY3PRRtlUZ/JRVy1asNodpunzrqbW7nyUEBjkVscgsuTntkupqmFizrVz9nutVexmWH7V KzFYmLEDaJB05+8gOfel1QWEk1Vx4U1S1jJMk99BJEAOWyrE4A9wP5UnbnFbUteKNXuDpml6 TaAFYYXui+cnDKQSfYKT0oirXYLc4m6ZpBGSgVsEFh1kO4nOO3WtBnuv7MBlk1PxCbj5ZEMZ Kk85+bOB36fy9aVtdBHvgpjFoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoADQB5d+0CUXw qxkLBfIlU7evLRj+tAHzRqc806l22qibIyARnKrgHHXn5j+NCA7nVtSjj8CRabBuAS+MTxSY yqK7uqn6YArJL3roSWpyWjahLovi20vmkRzFMpcx8K6HAPTHVSa0augZ6d4ylKeIb63hV1kv rCJ43U4+ZDKGOR9eD0rCPw6krY5/xlcPJqcmpQzRwE3Zt2kbgIiwKgBXoN2Xyc9xWsbItLsc zrtrJBq880NrNb232kxqJ/vR8KdrHPbf1+lUMn0y2aTVb+8tZCFhD3UTYC/ulkG1iAAFGcH6 LjjupWsFjR1GaOfUJ5mWDY+6ZDM7E/PGpwvoQcAn3GRSSshLYwb9ZbZ7h8pJ5ge1II2BQAG3 AZ46Hg88e9UBv6Rfm9+H+t2zlhcxSwXAfbtDBmUAD1IwfzqGrSuibamfasY7lfObj7RGxMtw wIJaMsxI/wBWDjIzyPXKGrZbL8mrPY6AYZhJItxa3MOww8Ll0dWGcnaSCTnoSezKaTRLOZsD LcSSxxQRxrciV1dogT8o3EBj0AwD7EVQzrPA95HeeFvEullIzMsH2uJcfK7IG3n05BHYYqJL UTRXn8SvH4E0Qwyj7Zpd+piD44Hl5/EdBRbUEtToZLA+N/CeuXbFUuLO3ttQTb1JWOVZF+hw v5VUVbQS0Of8CRTzaO7Qn51kmERHJ81ES4TH18lx/wACqZJAzo5/BeoeKfEUV7pEQe1cTRNK CP3G9PNjJ57+cMfTFVFXWgdD2Xwa93J4U0ttRhkhu1t1SZHUhlZBtOR6cZGfUe9arYk16Ygo AMfXB6mgA5DZBww/i4yT9cf0/CgZxniz4caVrRe70/Gl6ickyxJmGUnGfMiJweg5GCOOpAqX EpM8e8ReH77w3MtpqlqLfIPzpmS3uFyciL0IBORkHBOBkAlWY0zKWNZrhYQwtpgGZ42JCxsC TvDY+VSRyRwCd3AHCGTomm6zDOdSkNrfTTMJpMKw38F88EYJ+fcMEDeORgkAyfEXh6805EmW Q3NsrsoI4ePGfvAfQ8jI+UjijUDa8G/FLxBoGI5Lj7fZxgERXMhLAZ/hbscdqEyWj2Pw58U9 E1WZba+Emm3LYIWcDY4Po44PQ9x0PpVXCx3EMsc0avC25G+6V5z7j296omw/Hy7u3r2oEHQ4 6HOMUAFABQAHA6kYoA5fx34vh8L2apFGlxeOc+S7lUjQYZ2fHKjHAPqRUy0KRJ4R8c6L4pDJ ZzC3vl4ksrgqJV7/ACjOHX3XrxRzBZ9DpmVgPuMfYKad0KxxOq/FXwnpkt9Cl+bi7tAcJDE2 yaQDiNZMYz2/+vRcqx5VefGLxTaCWeG8tZVuc+UrWAVI+vKE4PynGAxbpk9xUXY7I5nTdB1H xI6yNCftF5IxOoX9wIY5WzyA7fePJzjJOfakUk3sb1n4T1LSZFeyuNJlvd7B4pboxTdTgjlf ++hgnI/vCi8RuMlqTa/4h1OS6ltL2+v5ZNyRtFMzMsLA5VlG1SSRggHkgfM2OaELme5nXdjY 2kQt79pFndFeZSrM0Z6Zcj7zjdgKRtz6ZzVC6jY0mmuUtLJZImVhBFZ2YIllBPzoCBw399t2 BnHPNFg2O68PfBe4vpFm8V3kcKomyOys13bF6hS/YD6NnnmnYm/Y9M8N+E9C8Ng/2Tp8cUh+ 9M5LzNjsXYk47D8vcuxNzZ/3uSAAST1OOvv29OlP0C4hz7UCCgAoAP5UAHHpxQAUALz7/QUD OK8Q6FNqfxP8NX+zNtpttNK7jkAliE69ef5UnuNaIufEDR2u7K21myQtqeiS/a7dV58xOPNi 57Mg49+O9NoFoee+Ofh1aafrEOv6PGV0q8kRpYNmBAWOcY/gVgSMn7r4Bwp4zaGmecGzGmO6 MGDlRsk3DZKi7GMansUYg7gece9SUQNIGt7maWdG82SUiZegYliAAehOQc+hNAxrTL5F80kq pvuN5MYC+YcZwoI59x6laQFfxIjR3022AwpOwZ0HISTHzKD34Yf99CmhGvod9DFBFaLcMHmC J5uc+TlJV3Ed1VXBOO3eiwFKKylit3EdyVWFNzsH2xuhKhGK4+6XAIJznAyAcZBG94rtkv7D RoY5kNza2DM0TnMivvzhl7HGWII6ZNRHS4IxbOZrqCzjfzjE7yLJ5IyzIzLvOPTjHfHH41oi jd1GeWKSLUE3ztd2SqiDouFRePXLhKQ/QwI4xLG8u0kmzkCqvG3Aflj9RwOp6UySmI50uLQQ K7kyAwkj75XAHA+mPwx6mi1h2NYiGb7ZPumnme3E6sowWlOzKkf3Blh2yTgZyKQWKGm2sdwy Q3TSfZ4HeZvLI4BjHOP9kgBuwH51TEeo/s5CZvFTXswGbvT7hiyjAciePnp1ySPpimB9Dj2o AWgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBDQB5N+0bMP+EW8lTh3hY8dWHnQcD8cGgD wHUCz22qP9mtkka9YzZPzISwwo9sg/gaEBRtVv7mAxOw8maZ5C8jfxqhLZ/A5z9KAG6xYm3v WjhjODIwQEENxjj8+OPQ0IDu9EuptV13SYbq8FzeyabOqZOGZmHmIpHb72B9KzasnYlKxR1e +aeXUEXyEWHUyOflC4AXJAPIOCKpLRFIZq0cd1DqQjeQmUqD5xDNuXO2F3z94FMAg/Nk56cs ZWsVt4b/AM3TRI9rNsjgaSLIQ/u93mADgYVhzncozj1GgNK/lliMUSfat8SRogd1jGHQYQsM 9RkD1AB71IGfbWKah5UczwW1yzho2uBsV9zEAPxwcH7wwOnPBpgLohngs9Qimi3lNPmgK7Mm N02sN4xxtwfm/XuBhYfcy7BLF5rb4Z4woBdWl/eEsQRwX+XJ475GOc0A2eMR3UcSrlRbSfOo dSVZIwQQO4BK4OARxkAilcRl6puh02cQxR3CxtFE90eqMN2FHuQOSADhACOMkA1PDtvDZePV 0y6ZootSg+zzEAAq08Q9uBvYfgBSlsJmV4v0KXw9ItjOVM0EhDlW65VSDjt3H/AaItMEes/B vR7xxctJbN9lvNH+yu4HyCQYKj8Y3Q/XNaxQmUbfSLPww1hc27SG0ngs9TlEpJyQ7Qz84yPl nB6dqzmrAdR8H459Nvtb0W7y8ln5R3HnMY8wKQe/AVc9OKqmI9H/AB+h6/8A6+w/CtBCHduy DgY5HvQIX8aAFJPTOaAEoAPagCprGl2OtWEthqtsl1bSgBkk9B056gjsRz37YIO9jyHxn8K9 T02P7V4Udr2CEFo7eRglxbEnkowwHBHB3c4HtUtdikzg/tl7bX8mn3NpJaXKqvMxWN9q8gOW yGAAwGPKjuRmpRRraXfLJARI008sm6KS3+6VIONvXqPlwT7f3mBYGN4k0e3LXN3b4gnRY8Lt G2UsWUED+HOBg9CR2yKLAYUtszRtcw25gt0cRFHcvuPB25+nIHGRnBOKkDZ8JeN9Y8J7hpU7 HMgxbyEvE4B6MhHfPVSrfWndhY9Q0r47WUqMdT0C6t5IyBI1tIrAA5zwwDdj61SZPKdxoHj7 wxrtskljrFvG5BJhuJBC6jOPunr2p3Qrdjo1KsoaNlZT0YMCD+NMQZAGTwPfigRHeXUVlay3 Ny5SKFGdzydqgZJwBnpQ9APBvFfjEeK/FgSBha2awyRWjRxLLJcAPyxz0zt4HJwKg0SMe+0a Ge0IiaK4nVWIwhU5IOSFY8ZxxsI9SO1FrbDMJBf/AGRrWG/1K3O1yLWZpPKb12lT1Puo/wAU FiG2C3JdwgECgSkZwilvlHsMEdSOTnOeMAHS+HPD0PiDWLWwukkSO8dmllcbWCKrOzDOeoBA JHXGM0mOK1sM0nxHqXgm2t7SR4r7Qr0LKLaYmQ2yOScMOACRlgMYJyRjmoa5johN0tVsdDc6 t4a1aC9uW0RYdEilFq9/Dc7WG4/eWIgAr90kAZHpnmoasaupCSvbQ0NW0KS18IarLFr4vFsY I7i1y+24SAjDDI5CEEEAfLkZHBKnSMjCtSVJ+6zJ+HHgSfxPeebq4ez0u1TLQxnDszYZVLdQ SpOe4UjnLEjRHO9D2Pwx4V0jwvaiHR7URtgK0rsWkcDA5Y9Bj+EYXvirSIubOBjA7f7P+R+l AgxQAUAFABQAUAFABQAUAKOo60DE6ADsB09f84oABweMjByMfp/T8qAKup28lxpd3bWzJDLN A8UbcjazIVzkHPU5/wDr4oaA8O8R+FZ7DR7++0840uDU5Y4omyVsXQhPN9fLYblYADHyN2wI aLTOS1e0tJL5Xso3FjdSeZGrRnCFvvxlVx8y/e+nToCc9iijOLmH+0ItSVUukJ+UqrDJTJKH OBkHqOxB+rArrbltQQs0ZKSO5LSFYztUHaCv3Seg5HOAcHoxE6P5kETW8lzFNaSLwxKkBmfO WGME5xkZBB/hxglwJVnZ4GtCY43yzIzDCb+7jupG3GeASScDFTcdiXEsV/LFHI6xRLuLSPgJ hsA8EADAUYBCnaCPuii4WE0b7VpzXl3GSwYSxHAHy4USkgdhlRn2pMEacV59imtLW2iUJEGk jBbgFxC4xnnAZRx6fQ1IyvdWKS609tHxautxJuOB2YtnI9McdgDjk1YjLgijbbJN+9DFI2Ac KShClSpIyAu0jdnrgngGi4Fy2BubneLaQ3EkUXKAIfMZlUFQAOGXhR6kt2zRcEVbfbC0M/lr OC8ilHQsHbavy574DbiB1I9CMsR6v+z9bSWOvQ21w0hn+xT7lIyFBaF8ZPI++DgdSxyTgUwP ex1oAWgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgBG6UAeDftOXKQ3mjxSuQs8TqVIyCok jLe4Pyr+ANAHmOqWDR6JHd20kRVJZJEMjfMV3n+qZwf7w+tIDPlnm/tRre1kkuLe33O5kwpI KASZ7D5Rt+uKANHVraOPX4ru1a82xXbCKQxZzHkeXtB+9g5z+NCAu+D7KSzlec6iALO5thtU ZBR2MZJXr0b2x+FS9mJmTqEjwa1dsysxS/dXlkRiJGy2OQPUdPb601shmg6eXZXkkMkhjlVI VBw2GKOFRwfrlTz8vqSMgyO3higsZrlY1S0N49uXkm2qAodkRgDkn5QQQeSADxjLYFvWyf8A Rmt/MlY3kSqrMSQQGyrDqDxx19R7paAW0+y6nBJabi3kQCGHYAxgdnaV92eSMLsx0OTg0AUI ZH064QXUTw2063RiaF9rOS5iJweoLg5XpgU7Aas1mskN+Jolltlee4jMI2NI4E7oyN6cxnYc sccZAxU3AwbOyS7vdLnvZI7c3DhVkjwUcABcAdmUjBHTnpg0Adh4L8Myaz4R0No40WCS4uZJ XK8PPI4hjHqdqhmz2x71rFaE3sWpvCkutfF7xT9lEaS2Cwz2wcYAb90UB/BcfjSavoS2aHxk 8Jz69q+lRWawrPLFEJJAcEqHZGbnr99Klx5QTN34JvO/h21ufKK28tpFGzZ4E0Ejx8j18vy+ enFaIbJPGHhzz/8AhHtKjkVFn+26eHIPyrJE7oPbBQAVM0SaXw+SDULRNf2ul7PE1lMuMAmO VyePUMzDNWlYbOr/AEFMkKACgAoAKACgAoAORjHbp2xQBka/4X0bxBDs1WxjkYYKSqNkqH1D DHP+JFFh3PKvEHwk1XRkk1PQNSXUGt0YrBNHtkKA/c7hwVJBUjB9hwJsVdHnt1ezTW/niQyS pES8bs29cPvDBuowx5B6855IIRRbjmgvLCHU7NGSaL/j4hR9pZd249PTrznqcgUgLt7p0GsW pN1HvkRvkaNdrYPOD17nBP0zj5aAMNvCss7SSWM4kY52pyHY5PBz3yOR19snAAKNxp93Zqy6 hpzxQhxunSPcpBXP3x2OARjrg0rAaGmeJ9X0O+WTwzq0trDLg+THJlOMZGxuCc5OMd6abFY6 H/hcvi2QpFFf267BlJmtFR2bHKkAleenSncLIyYPGHi2Wxmsm8Q3KCUNbyWsjFtySD0bICnI XIxjcKQWRNbMra/p0soWOKNooJf3wU5K5Ayc52lTn6jPWgNtjX1i1hvb2zRrqYQOr4/fAtvw CBkYzkAgjj2p7DMuCNNOb91b7lspwzSRMQGhkyBxwcjPr29qQGbFBb2mq24kYARM0abXC8fe THHGRkdzu70AdD4Pmb/hIdlndRyX9/Z3NrYxoxVYpnjwp3MfmPUFjnkjk0Anax1mofD820f2 bSLi0FhGW86CSNpfLfyvLd1AJ3nC5Ckdefrz82up6SoaKz/qx5hcaTqWhwfbDpt1/Zk5YPFc RFWiyTnbnkHYo+fA64rS6kcnJKnrbQ7fw5Db65bXlxZyq8t/p8VrdTKmd91cXSYUr3CKp+Xs FHODTiiasou1vn8z23R9Mt9H06KxtS7JFkl3+87Eklj6k9T+nTFbpHM2XKBBigAoAKACgAHF ACnHagBKACgAoAKACgAoAD0/lQMoW+nRxjUYpkSW3vZ2kMbDgqyKHBHcEgkj3oA8h+IXgWDw tNHqGkq39kSyoRASW+z3CjEWWbJ2Ocqc8AkZOKiUSkziJ7eNIbyP7RjdAGQNl2cCMnGc8gEt H+CVmUVLN44CtzKXUwgSeSZCG2tGg3qwxjOQcjnpuBAoGUJ0Xas8LOXGUEseFJ++CGyeCeBy TkD8KAF0+dQTaSgblO1nRdzyDJ4XPb2P145ppAXrW+eya21ExmUAqRs5zkhggJ4XGMBSpGST jvUgaPw+hj8/e6qbiEm62lT++WPLPEc9G2rn9eQThuwIa8s0MFjNLGZDcWkkVq5YMzsHTYPw 28d8fSla4yFYZpJLeeaF47RmnkkRHGVbDE8kH7qgZ7+4PNAC+J7WDTzEyQsBOkLrJklDG0al oRjoOScjt9Ka2EWdLgW2Vry/EcnkwWgcAfNIhk+XHIw3yhc9sfnPoCM+d5o9NigkELhJJDvk cOFdVicZx0UhQoHfLHtVCPS/gSbc+PZ4oZpJBHpRaPf/AAKXjyh75UjaQewFNbDZ78OtMQtA BQAUAFABQAUAFABQAUAFABQAUAFABQAUAFADWHH40AeLftFWuI7C6uEhbJjjtnk4CP5mZAfZ gUx9DQB5ZLDbnSbfap814G3yPkpH8z7yO27BTj/YqX5DKyXMEmoXUzM4e5niD26R5dwFHcep JBX/AGh6UwLl7MiarMkM0qLveFDwplQFjHx3XIwTwcMe+KS2AydajNtetcQynyvtCp8sZTPJ ZWcHjIx09qBM6G1tkv4S0m0w3epbmKqSyFpJwGA749BQMz5LUT2j/vvJZlDQzj7shG1SCMdc N19MjuRQBe0yJ4RexQxHzLW7JZ5WZlCm2mGwoDgj5cZHTuRnFD3As67piRaolszJaxw4M145 GS/mFVLEkZ4JOSe/HcEAztNc2Wq2/khoRIqxthSVAODk4HA5zu43A5+XkEYEumzNc6nAJQri 0u/s8UL4EbBpy5STj7p3NyT1K01sBtW1ul1pxzNv22EcZWQAsrLG6mNiB2wT/eHY4qdgOehc rqmnJMoL/aF5BOWYSLjOSc446c4+9k0wPVvgPMlx4VvLJn8wadqkqxA9EBwQR75LVrHYiW53 VppVta6vfanCoW4v1iWVuufLBC5/P9KpKzJMrxdCBd6be4yImaMnpwWjP5fuzWc0BnfB60uL HwvLBcLIFa5M0TEYDh4kJIH13D61UdEN7HQ65p0moPpckDhZbG/iuMngFQGVx+Kuce4FVYSD QNJ/siK+jEivHc3010gC4KCQhip9Tu3H8RSQM06YgoAKACgAoAKACgAoAKAD9KAOY8T+A9E8 Qu1zLAbTUW5+22+FkLD+/wBnH+8D6cdaVh3PHPEHws8V+F5Zb7SBHq1t1Y28e1h6Ziz09MZ/ Kp5exV0Yek6rCJBbTO1g8fQupHlHvG3coTkA/wAOcHg5VDOlWVNQQI7rbXkSjDbtwK4Awx53 LjnI5UEfeQAqwsVIIpvPht7m3xPEpZ/lBVTjcGCjKsDwQ3GcZyCN9AFBbSyYJ5KQTHb5aK0Y J39eh+/8p45JPfPGEMz9T0vTtPvEgESRpJEvzyDPzHIzggkgNtzt7d2zmgDOvdGWKGGO2Id5 nYBZPvRlQdw4Y5HBxx6epoAcXWTTLWeAGOa2Ul4wMbiuG3DPcjBOMcfWhgdleGO9tI543hjV 2Ekc0ThGUgcHZIignHHLHrTYjKu5pVkeae4W4M1t5Mkclv5JkXJOEYF0JBJGcjikMoXl8L62 ju7W1Z7y2jUO0Y3DcvIfg5BzntggnOcUAac15Bf21vffbHtgGWRHhyHjZTnO7g5Bz83GAD14 oA3tLS+vQ3iK81aXQprpkE9zPEY7e4kXAMiOg2qWCjKsMZ5HoIcbm0Ktnds7J7u3t9AuLq81 qHxLaRW0k0kNpbIXZQuSWYHaox13DPtUqGt2bzxCta7ZwHh/Qtesp4PFfhOyhS2a72tpXnM6 oNoCksTycSNz1Un0zjSJxzi4Oz/q575p14LmFSw2yYGQOmcf5/zmtTIuc+uKBC5OOTQAnegA oAKACgA7UAFABQAUAHagAwccA/lQGwenvQAUAHPtQBDe2lve2ctreQJPBKCrxv0Yeh/zx9RS YzwTxd4NuvC2sDT4lEmj3jMljPMwCx5Vi0LtjhiSMHOOhz1xm42LTONu9llEkc0ckgjeKSSN iQWO3BJIIILDjAOfX7tJaDJITDLYTyB2N0VCrLtXdCvA+YAZYkHaNvXqw4pDM0KnmEMiFZGU BOhHzdmHfPfng4zT2AlmtZ7NbiWAIBY3BVTLuEqHf8pIHH5YpAdToC/2fdaXIIPMcxxRPkrE QsisRg9N/dJDwfut6UtwKlhJ/aEm4wurWUYa3gJ27ZN8MY+VcEklASMcFs9s1VrbATeHWmfU tMEMvmvHNuuI1beWVidyEfxDaMZz82OM1Iy1qdqkmnLaTzBp7aJJIgpwrILbcjEcDPY8E8de RkALRIZBKYpUmaO0svKgbkY3NuQ/7rHd6kCgRmaNpsVrAbu6jkeNE3eUdpM0bLIpPr8uCcEf zGKYHpXwRgdfiJqsszxG4FgI2SIYX/lid47/ADE59jnrQgZ7oOtMQtABQAUAFABQAUAFABQA UAFABQAUAFABQAUAFACHp6UAeY/tFR27+AAJ0y4u42jbGdhG4sf++AwoA8Hm1vzrZ7SNUz5Y WNsBjI6FhhlI6EMxx0HFLbYZU1k3enatKJZ+IrtX82BehwPm9Mnap64yKAHXl0jTXc8qwSq7 mH922FjyrbDuHTkkn/dFAE13c3It7tjcPJMqP9qt+AqNgoXX1+Yjn/apCOl8DbotK0KQ5Jku oTkE5z503Xn+VD3GYX9kyJZwXEsqiCexVzGJDmVWnKEqPXco6dcUAWrm3jh0tUW4aMS38SiX IDKHEu7JzyORnNAEkl7Ld+J3l+3ko2qSNZgMEH+sXa7Fuqn+HOQCOcA0aLYBmngzX0rgbcQN 9pjGNi5xv3jPERJ/ed0J9uQCbw7CiJuWBNz3Tw7c5Scb4ykEgxwDyVk5HBHUUAaUl39kllWJ d0cSmHy2GFTAmARgOsigfK3Rhxk8EJgUtiyNbXWDt+2Oy5GGwXXt2J24PvxSGjqvgHdNbeIv EGlgr5bwQXWPR8AN/wCh/pW0NjOe57J04/KrIKmq20d1bBZIxII3WQL24P8A+uiwC6PCtrpV rCqeX5cYwmOhP/66SGWyMLlgAfc45piEOQec59xjNABQAUAFABQAUAFABQAUAFABQAUAAABy OD0oAyNd8K6D4gUrq+lW1ySCokKYkAPo457/AIe9Kw0zktV+FFtLbwrous3dh5ChYo5UWdEG cnn5W6kkEscZIHHFFl0Hcxr34ceIbZE8trK/8tgySWkxtZkccqy7gRjOcruwckgA8lW7D5jG 1TRdZ023abWdIeDZIigqq+W0jY6vGNuOR94bDnGVbOVYd0cxqKR6jDJprOlvPAzJkrlkckg9 BkDJ2sdvI684pDMK4u7qBi0KWlrNbSh/JjGdsinaSqnJGeARxnj3oAt6PqOn3MfkXWLCRMgs H2kgsdh57puIxxlSfQUAM07V7zQraSy1O0mSJw3l7Ts7dAccrznPPbtQFhfKs9QO6x1I243D NtPIRn1xxx17g0MCOX7K5CaZC8UkWVkzOjIQN3XcATyT1yccAjjBcCtp7M001pJNDZxSSbzc gEquATtGCc7sDGOT0z1oA+i/h54OTRtItJNRn+1XLgTIhjURxM3zFsY+aTpljkg5xtFWlYh+ QvxavBb+EDpyYT+0plhKg7cIuZHP5LjJ9amdkjShBzqKJH8LJI7rQLmDBBEkc+0np5sKE/8A jwaoou6NsWrVE+9n+COpt7AQSFlOB6VqchdHSmIKACgAoAKACgAoAKACgA9qACgDnPH3ieTw vpVvdW9nHdS3NykCiWTYi5DEueDwAp6etBSLvhvXrfXre5kgwJLaZoJArb1Yj7rqx+8rD5lb 86QjWpiFPSgBBxz6UDMjxnBa3HhLVP7QjWWKKB5SroZFyoOCU7gYz+FTMqJ8xaPazRmzaQN5 k43hGViJF7Buu5eGzwSAMY5rPQs172JZIbiDehVzuZpHDJK/yg4OcADbxzx3Y85QGRqkYSNo 50ZX8oS7ZgTg43A84B4PpjnGDmkBHqLMLXULi2ysU8ivJuHKEMdoxxt7/lximB0Wlj7TdLaR OHTa0UflQ5BXyQzbUbrydzx568gA9R6AQaV9qi1ex1BEIigNvMyrKC0SYjRWUsOVJOByMgYb pmn0AXSZZra+0zVYLmLYJWubgE8fKVK4yc4YbUx2J296QGhblr3RxOiqJY1Ko2Mbk+xglOOd 2ME9gcVIxAUU2t1axR4mtLOVZTyUkWSRR7EEDB75ND0AxLS58uxiNuY/MCl7Vim4xqRMHQ+5 6447U/MSPRvgzdRW3xINrYg/ZZbWZVY8nGInVCeuRhhz2GO1OIM9/HpVCFoAKACgAoAKACgA oAKACgAoAKACgAoAKACgAoAQ9OaAPM/j4ZW8KRxBgkRdjISO4RmUfiVwfY+9AHz3OLzSJUCw wNDCWWOVjn5lPVvfjH+GaQwuna5voxZbhAssPlGQHa4LEqzZ64GB+BpCKwQxTyQz7IYFG1VC bl3bWK5/vEZI+pzTA3tEtrm5a7t444pIbi3aKSUPnG9lU7R1UZ2nHr354Qzd8PGO1i8P2aPv VZoWErcLtaSYL/P9aQHO6f5wNiLv5lsbSRmVuBsEhbAPbDAlfdcUwI5UkvJraOxkKWk0wkLt hsO2WUY+oI9OaFoBGrxR3dveSpvuprpjJHjIjDMjK23+LKswIP04waQFiCeW11VwjuWW3iKF X35GxQvQgYw3fjHytyd1NaIC5oknm6dOAAE/egh4+FUsmQ5ON0HTIHKcHjOQMEWXI8+RJnKN FGY8zPu+X5isZ9QS2VlHHTHIxUjKb3DxyvbAOHMhOxjls7z1I4ydnb73UdaAR0fwXVoPijeb uFudNZoyOjLlAP8A0GtYbETPePXsR2rQzEA44zjpxRsMaskZkMYdWcKDtB+YL2OPQ4P5H0pX C1jx3xfNrHhDx9BO11dyWN5dJPazG4kOwE4ktyM42nJwCPT0NLUeh7IVVSQqhQCRhfb8BVCC gQUAFABQAUAFABQAUAFABQAUAFABQAcDpQAo9/5UDGlVK7Co29NuOBzxjP4/oPegDM1fw1oe sknVdIsrt253yQgNwc/eHzdevJzRZBc5nWfhH4U1C28u1tG0+cPuFxC7ljzkghmOd2SM8Ecc 9qVh3IE+EOiC4huH1HVJJomMm+R4mLM33s5jOckk85xyfalyhccnwo0+MOqa7rCxsc+WDF5Y Pf8Ad7NvPpj37mjlC5Qb4F+GXO577VOAOBJGPqOEHrRyhc1dA+EnhPRLxriOza9ymzy74pMn rnG0Y6fqaOULnSad4Y0HTZxNp+i6fbSbt29LdAwI6HOM/wCH507IV2aoHBAOMjByOvHf1J96 YdTyP4qXT6v4next3zHYQCzTgnFxcHDE+u2Pbn0zXPVd5KJ6OFh7OnUqvpdL+vQ0vhE5jvGi QPsn0i2dS3qjFR+IEg/P3qaD1aNMyil7Nr+VHpX9K6jyQoAKACgAoAKACgAoAKACgA7jBI+l AAPrQBjeMvD8XiXQ59OkkMEu9ZYJQMmGQfdOO45II7gmkxo574Z6Jqmh6prMeoWzRw3SwsG4 2+YMqQCPvZXBzx745oWg2d0Og98fr0piAc9KBBQBzHxVvxp3w41uTcQ80P2eMKcFmkIUAepw Tn2zUy2KSPEFjisbieJCJI5ZVjjKRlLcxAupOTzE24Z+pOfWsmaFnXJYfLc7pIdttG8iTY3A 7VGVOCsg56kbvU5pAcvKsqoyeWsaQQlNuWPl5wercgE8hu2OvFMB91CJdH1GWXaGjcHY0YV4 2LjOSOeRyfw9eAC/olxI11GY2W5FzIiGW4cKm5rf5cgfdZCCd49Oc0MA0sW19I5Riks8NtEp kUAucoHxkhRyrKC3DDIODQBZ8MwWcl/pdzMX8k3G+VGZ1KCPy+IyT0LYwOSOMg4U0Ai482lQ aK4Yy291PcLEY0j35Hkss20443yMEBHYDtzSAo29xHaE2zxSeU9tCkxD8BvNZsjsMjH489Oa bQIyLeSOPSYUjdEkSMCXLFWVhI+1wPx+b2pDPQ/hLcxr8RoiFWNmu/LeNTgK7W8uSO5BMf8A nNERM+jF6VYh1ABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFACHpQB5D8er26i+zJCnm20Fs 800JGd+6WJEwPUEg0mB4tcyRlJH0+2lgjX5flyzoVOeU6dGxjqC3tSGMjljjU2lvCrLJgMkZ Y5wZCWiOeBgt1xgj3JIBXtiIXu4490sEiiMBCA3mcYIz0weB/vDrQBZ8NXLW8iOI9lvcXL27 SkkSFCVJXA9Mhs9gT6UAaujQXU1pZITvZVs9pPHymWbaQPRXIBPt70r2Ao/bbq8tJoTHDFJJ Y3BfeDu8ozGTaO24NvAz70wKVsoEkUkTbjaTxlQEK/aFKngL/eUoFwOcsfQ0AXYYYby8iNk0 8rM0mJg+CFCrJGAM44ZWUg8dcEHGEtgJ7NoBf3TqibPKBxCA2wGNOeR8yncQUPXJzz0GCG6K v2a2t9jbmVssVC/KWmUZG44IwvfoCc8EEDGSLOCbqSMJtEeJCjDYAWQYY9RFyRt6qaAM+xdm FqWKjDtksT8gCyErjuO4bseDQxI9F+BWnNq+u3viZ/MSCyiWwgRuAxKguD9M5HuRWkETI9n7 DqcevXr1+vArQzM/xFe3OnaPc3Nhay3l2AEgijj3sZGO1SR6AnJ+lJjWhz3w88KXPhyC81HW rx7rVdQG66feXEe052hjknrnJPfA6ZpIb12Oj0zUNP1yxS5sXjuYCQwDR4wSMgFWGVJBXnHQ 56U7iL2c5/M/iaYBQIKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAKACgAoAOlAEd ys7W0q2bKlwUbymcZAbHy5/HFA1o7nkfhfR28R6lFZXInSBUa7vZycSea+R1/vGQsfogHQgD ipxcptvoe3iatOFCFOmrf5/1uWvCk8ukeNdJ02eBftA83TZ0UkBPkDqyj+6RGDn0b2p0YuE2 uhljKsa+GpyW6Wp6sOVBAPIzXYeSFAg6UAFABQAUAFABQAUAFAB0oAjeaGOaKGRwrzMyxgfx EDJH1xQAy2nM6sHt3tiHZVSTaMgdWUAnKnIx6ZoAlkkSFHkZtqoCzEj7oAzx6YFAzm4fFNxf y50rTYWttu5XuroQtIpGVIXaSu4HI3EEjBOARQOxtaPqUGsabFe2u4I5dCkn3kZW2spxx1FA i4M9uD60CPLvjHP/AGjrOmaAxzAlpc6jKmSNzIjCIH1AIPFRPQuJy+pFNN1DUpWlYSTQ3geV kBWVzI2d46c7cZ4PAGTxjG5oc5q6wSR3Vo8gge0IhZApkCsu0Foz94ZKnjPRTxTERSwj+yxH OH8uC0AH77LRKxb7pGN8RyNw/hyo7UMDHnYR2MhkjTzDlHCjAVlP8XQJ0BXB5APcUdQLmkXk mnfYNRDRz+VGkzxlCV+SRoisi+4frz245quoFnSrC4s9VgS2WQG2kURB4x5gEqqEOOjL5j59 xz6YAKn224sb3zYozNFHDFLGyNlSUCksGPPBAIx06dOiAmH26y1FIbjzJZkuDDsC5EuQWDb/ AO8WbOO2BQ2CKce2e3vmSQRwwW0WUlk3MzDbuX/gTsTn0GBQMRbyXy4lUAXMPnRyMpwH8zOG 6dPmwBS0Edd8CoJf+Fiac053bZnUE852xTD+dUrBY+pF6UxDqACgAoAKACgAoAKACgAoAKAC gAoAKACgAoAKAENAHknx7LounrHDLItza3MLNEQDHtMUgfJ67fLJ47ZNJgeHpcXD3FvNJcRq S8ifaQe6gMFOck8gMOfTp0oGSeVGyxWctubboZijARTEMzDOORwzc8Yx9CEgHbLyCXztm4xp CQrcMQzoysuPvrlB78ikBq6ZFaWKQxyXDNGNYTFwvMfzIOSucAlWY9MfJimBU0u3vIH0+O2X 71r5CvG2Rn7ScsM/9NAM+m7ilpYZT1W8unsIAbTd58Zy2NrhZLguAPQ5DL+J9RTVhECGaKO5 jsYpzCJYg7PGFZZApZMg9HDAgf3hgdTQA7T/AN/BBE9wAqq/mAv8pbBZGGcDGVAPPUHuKNgJ PNjS5kljMiwSyGVYbc/MQQmXX0yR146DpxkaAba6jLA9uIYlZ1dWhCK3ykS53JjJY5ByCOmc DGaAQlq6iOeVHUsiKxYqoVPnjxg57ZPAUkcA7geACB7wxafb/ZsNNNJJHGscfIDIq7Q3cfMR s6qTnuKelwPpbwB4fXwr4RsNLwBLGpa4b1lPL4/HAz6AVtaxkzf/AKdR6fWgQdxnOPbr780D DnGCR09MZ7jI9On60g22Kun6bZ6YkiWFusCSPvYL3OMDHpgcADAHGAOcuwFld3O4g+mP60CF +tACL3yMelAC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAA4oAU0AAOKAM3RtE s9GkvpLQPuvbl7mQk5OWP3R7ADj6mpjFRbLc3LRmZrfho3njPQfEFqsSy2TSxXRZyN8TRlVI 9SCTj2OO1O1tUK+ljowOMgDGPTpTEKOKBCmgBKACgAoAKACgAoAKAA4Ix0FAB35J56/j1GfT igBvlxmUSlEMgGA5UZAOOPUdB37CgCrrNh/amk3lh58tt9phaIzRfeTdxkZ/zigaPN5vBvi7 TYo47eSx1K1iJYiJ2jlI9TvPLE992eTUco7nY/D7S7zS/DwXUkMd3dXElzLFuDCLeRheCRwA PxJ980hM6P8AOmI8b+LMrw/E6xbPytoc4PvkTHt9M1nMuJTkmtL+91sxyw3EUltchAOqsxLK CD0I4OOuayNDISKH+0p7WBA6XF2mFdDuaNZpGZFfOedgJHXBB7CnswWxzk8scelIvmLErwHy 1JYohYkkYxwQV5ByRnKnHBBFfV7WK3gVlieNMunkE5WIFhja3V1OeOTggdjTAq6FZ/a7h7S2 kWCOeY27Tzfcw3KK3905Q/N64oYGjCt1carp6wLJFdrbx7CzM7eZEx6L3+ZOOwHHY0wLWnWC 3iRJcGIG8WZ5GJIh2tEkoUMPutuU8f0zSAsJ5kjA2pWSdrm1keZuS5kgChhjgfMzH8BUvcZi aasMdlOUXfJLBcIrOflUgfLn3CK5HvimIrxS4gVQEL/60sDwMoCB9f0HFNrUDvfgYzf8LB0d X3bilzIeOM7H/wDiqaQM+nB7UxC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUANcgLntQB 4r8ctYLa1baRLenTFhWKWO4EYJ2y+bHJz6KCmfb04NFho8du7tJZftTokUvnKxydyuNgVyV7 njd7hu/OZAvaWZrLWJIIFiiIimjVH+dJJFDMFjY8gsr4HTORigC5rccD6ZnTQ8Ey6fHJ5MvG 5UYBXVj0wpjbjg7TSArGeOK5NzZus0B1GJ5IZD+9yYyWO0cOo/eKGH68U1oA3Thtlspku5Ik KbFkQ8FlnbJA7AkRscY5o6AiiLWa4ksYv7QdbW3t4WadjmG0aT5wpAGcZLDvyR9KdgFvklt7 hbRI2Qu6QtbSTbTztKNJjA4LHa2O/POcoCvoarJeJBEjs0vyR3KoxKEBmXaowSSR16cdcZoY CQNHJaym3iGEG92dvk/5Z53H+PBzwcj5uAOwBsy2VtpMMNzrPmlZFZtg/wBbOVnwVH/PLp2O TxknpQBy2oSXFzAJpItkCOUjj4KISoJwO7YAJ4GMDPpVJCPS/gx4Pm1rVbLXL+zFppOm8Wwd QDdSDIzkjkBup6ZAA5BqlElux74OuRgg8/WrIKun2klksqSXtzdLJK0oa5YMY92PkBAGFHbN AycSx+Z5YkTzCNwTcNxGcZx1xnigQ8dM9qACgAoAKAAdKACgAoAKACgAoAKACgAoAKACgAoA KACgAoAKACgAoAKACgAoAKACgAoAD7Y/GgA6cCgAoAKACgAoAKACgAoAKACgAoAKADp0oAqQ 6pp0969lDf20l3GMvAsymRev8Oc9jSugLfvwR6jvTAX69ev5/wCT+dACd8YyTxxQM8R1Sc+J vH+r6mXeWDTxJZWQTH3UG2QL2JLSZ/GspFx2Mi9unutev7nTFT7VcW0nmQ8lJomj5YA8gnAB HUMD1qCzL0x4/IcRl5Y5Jdw7O20T8luiyAY+XOCPrkjAzrvTQYA8yxIklvII7hSdkr+bjLcj ZjJwTnggH1BdCKKyyxu1rczNNEryGNiwOW3YZgucZIUA5z6g8DLAS6aXTZpZoICsLuChZsqh BEigj35Iz1U9ab2A6KJRJeWt5bXgigLw3NvCi+ZLEryN5gA/jKYYkY6H0GKVwKkqwmRZEjje 1Ezbd7hY5wArIBg/K20hfofyTAk08+bYlo/MIt5LNXLk7g6khfwHzfoaHuMp6axmtLuEOyxi aWNeRtbKdu+AFHH+0aBFDTYLZrPcyoR5GSWJ3Fy4zwOnAx+RpyA9E+Dp3fFCwQRGMJHcFf8A v2uPyDfnTQM+kh7UxC0AFABQAUAFABQAUAFABQAUAFABQAUAFABQAUAI3TpQB82ftDXqwfEa wSSOUxpZxh8H5thZwyr6ZBbOfb0oA4wwWk4ubS2vHa0jiYpcJHkuSBtd4z04cIWXpjnFTsMq 21/d2F1FdWJjSKLZIW3b4yxj5BY9HIXGD3B6cUAaT2yy6ZHbSzSWstxZM0RucurIAHjxJn5S f3iY6fdGOeEBm2NtNbzwiAEyvcxGOFVCziParKykDGSP5H1qmArrBEsN7mD7Msb7AFKlwrbO Qf4sFG/Gp6AtClpcV3NDCIVS1WKOWRZtp
Reply by ●January 15, 20152015-01-15
On 1/15/2015 12:34 PM, Tim Wescott wrote:> Wait! Since when has this group allowed binary attachments??? >I was surprised myself, and trust me, I have been around for a while. -Ramon The Internet and Usenet Pioneer and Co-Founder while at MIT
On Thu, 15 Jan 2015 12:15:26 -0600, Ramon F Herrera wrote:> On 1/14/2015 6:47 PM, Mac Decman wrote: >> I think if our language was more like dolphins or whales we'd have a >> much easier time coming up with a decomposition which would stick to >> our "voice" and not to the noise ;-) >> >> Mark >> >> > > Mark: > > Since you are a fellow poster who clearly enjoys of humor-plus-content, > there you go... > > http://forum.audacityteam.org/viewtopic.php?f=21&t=83110 > > -RamonWait! Since when has this group allowed binary attachments??? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
On 1/15/2015 12:34 PM, Tim Wescott wrote:> Wait! Since when has this group allowed binary attachments??? >Hi, Tim: In these days of dirt-cheap hard disks and fiberoptic Internet, folks are posting video attachments. See Instagram and Disqus: http://www.politico.com/ http://instagram.com/ This reminds of the ensuing raucous reaction when I implemented the first audio server that ran at MIT. It was pretty much an on-demand rock-ola. Since the contents was only Venezuelan (plus some Latin American, tangos, etc.) music, I just knew that the owners of the copyrights would either (a) Be thrilled or (b) Blissfully ignorant for my blatant, shameless violation of their rights. I won a juicy steak on a bet that we would never be either sued (from South of the Rio Grande) or reprimanded (from North of the Charles River). Ah.... Good times... -Ramon
On Friday, January 16, 2015 at 3:18:11 AM UTC+13, Bob Masta wrote:> On Wed, 14 Jan 2015 15:46:30 -0600, Ramon F Herrera > <ramon@patriot.net> wrote: > > >On 1/14/2015 7:34 AM, Bob Masta wrote: > >> The problem is that recognizing the presence or absence of a > >> human voice (or even recognizing the words!) doesn't help > >> with removing noise. It's not like you can say "aha, human > >> voice... now I'll just subtract out everything that *isn't* > >> a human voice." > >> > >> Best regards, > >> > >> > >> Bob Masta > >> > > > > > >I respectfully beg to differ, Bob. Watch this Course: > > > >==================================================================== > > > >http://www.macprovideo.com/tutorial/izotope-rx4-audio-repair-toolbox-2 > >(Free registration) > > > >Chapter 39. Deconstructing Tone & Noise > > > >The instructor claims: "It is as simple as it is amazing". > > > >Watch the introduction as well: > > > >http://play.macprovideo.com/izotope-rx4-audio-repair-toolbox-2/1 > > > >Jeff chose the analogy of salt getting into the food that he is cooking. > >That problem can *theoretically* be solved! If we can take one molecule > >at a time, we can leave the NaCl molecules out, and the rest of the > >delicious the gumbo in. > > > >==================================================================== > > > >In this particular musical case the problem is not too hard: a pure-note > >instrument (piano) PLUS (it is indeed an arithmetic addition) some low > >frequency hum. > > > >Still: Sinusoids are added and subtracted. > > An adaptive algorithm can be trained to remove persistent > sinusoids, but that doesn't work with noise, or in fact with > most real-world signals. The reason is that the frequencies > and amplitudes are constantly changing... that's what > constitutes "noise", and also what constitutes "speech". > There isn't some specific waveform to be subtracted out, or > frequency to be filtered out. > > >I am sure that in the not too distant future we will be able to take the > >provided Dealey Plaza audio, inform the system: > > > > - There is a helicopter, which sounds like this [...] > > - There is a screeching train which sounds like this [...] > > - There is a crying baby who sounds like this [...] > > - Finally, there is the voice in which I am interested. [...] > > >My initial mistake was assuming that all "noise" was garbage that could > >be thrown out. That was a HUGE mistake! Any "atom" of helicopter rumble > >helps to identify and subtract all its sister helicopter sounds. > > >Every unit of sound there was placed by some source (IOW: God did not > >add some random noise, just to mess with us). All the system has to do > >is pick up every "atom" -one at a time- and figure out (yes, it is not > >quite easy) in which "plate" it belongs. The number of "plates" is > >finite and small. At the end, the user will have a multi-channel file, > >nicely separated. In my case, I would throw away the n-1 channels, > >leaving the tourist guide fellow's voice. > > To use your example of atoms, the problem is that all matter > is made of the same small set of atoms... it's their > arrangement that makes all the difference. In the case of > sound, it's an arrangement of frequencies and amplitudes in > time. Those same frequencies and amplitudes could be part > of a helicopter noise, train screech, or baby cry... or the > speech you are interested in. > > Take the "shoop, shoop" of that helicopter. The individual > "shoops" are bursts of noise with some particular spectrum > (continuously changing, as the helicopter moves, but we'll > ignore that for the moment). Suppose you come up with an > algorithm that detects the "shoop"... this is not really all > that difficult. Now what do you do about that? A "shoop" > isn't a particular waveform that you can subtract, it's > *noise*. It's made up of a broad range of frequencies, and > if you filter them out you can't avoid taking significant > portions of the speech with it. > > To use the salt-molecule-from-food example, there is no > "okra molecule" or "chicken molecule"... each of those is a > complex arrangement of various fats, proteins, and > carbohydrates. So it may be a *lot* harder to remove the > okra from the gumbo than the salt, if you are trying to work > on a molecular basis. > > Best regards, > > > Bob Masta >For a single channel speech plus noise I agree. For multiple microphone recordings of course this is not the case as seen by Blind Source Separation algorithms using Independent Component Analysis.
