On Fri, 05 Nov 2004 18:31:35 +0800, Steve Underwood <steveu@dis.org> wrote:>Allan Herriman wrote: > >>On Fri, 05 Nov 2004 10:11:08 +0800, Steve Underwood <steveu@dis.org> >>wrote: >> >> >> >>>Allan Herriman wrote: >>> >>> >>> >>>>All "solid state" finals for broadcast FM have been around since the >>>>'80s. At the time, they were better in terms of reliability, but not >>>>initial purchase price. >>>> >>>>I don't know how the comparison stands today. >>>> >>>>Regards, >>>>Allan >>>> >>>> >>>> >>>> >>>I said big FM transmitters. 100kW ERP from a silicon final stage? I >>>haven't seem that used >>> >>> >> >>You're right. At 100kW, valves (tubes) still rule. Can't license >>anything like that around here though. >> >>Here's a 40kW solid state job from Harris: >>http://www.broadcast.harris.com/product_portfolio/product_details.asp?sku=WWWZDD40CD >>I think that's about as powerful as they get. >> >> >That one sounds pretty impressive for a solid state machine. > >> >> >>>Up to a couple of kW things are OK, but you need to stack too many well >>>matched transistors to keep scaling things. Minor mismatches cause a lot >>>of stress, and reliability tends to be rather poor. >>> >>> >> >>Interesting. Usually solid state transmitters are used because they >>are *more* reliable (= more cost effective in the long term) that the >>valve units they replace. >>That was certainly the case for the microwave SSPAs produced by a >>company I used to work for. >> >> >I believe the latest satellites still use small TWTs, because >semiconductor amps cannot match their reliability. I don't know how much >radiation tolerance might come into that, though. Big thermionic devices >are usually very reliable. The heaters wear, but in a more predictable >way than consumer devices used to. If swappped at the appropriate times, >unexpected failures seem pretty infrequent. Repairing big devices is a >fairly low cost activity. > >When I worked in radar, the TWTs were generally the most reliable part >of the system.I was actually thinking of TWTs when I said solid state ... [is] more reliable. I guess we have had different experiences. Regards, Allan
Re: PM demodulation
Started by ●November 5, 2004
