I read the following in Matlab Help Document of Image Processing ToolBoxes, "FIR filters can be designed to have linear phase, which helps prevent distortion. " I am wondering what does phase distortion look like in image processing? Also, "Another class of filter, the infinite impulse response (IIR) filter, is not as suitable for image processing applications. It lacks the inherent stability and ease of design and implementation of the FIR filter. Therefore, this toolbox does not provide IIR filter support..." I want to ask what kind of inherent stability issue does IIR filter have? Thanks lot!
Started by ●November 15, 2004
Reply by ●November 16, 20042004-11-16
lucy wrote:> I read the following in Matlab Help Document of Image Processing ToolBoxes, > > "FIR filters can be designed to have linear phase, which helps prevent > distortion. " > > I am wondering what does phase distortion look like in image processing? > > Also, > > "Another class of filter, the infinite impulse response (IIR) filter, is not > as suitable for image processing applications. It lacks the inherent > stability and ease of design and implementation of the FIR filter. > Therefore, this toolbox does not provide IIR filter support..." > > I want to ask what kind of inherent stability issue does IIR filter have? > > Thanks lot! > >These questions are probably best answered by running some images through the applicable filters and seeing what the results are. Just make yourself an all-pass filter with considerable phase distortion, filter your image, and take a look. Similarly, you can either filter your image with an IIR by hand and see what it looks like, or you can whomp up a FIR filter with IIR-like characteristics, and see how _that_ looks. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Tim Wescott <tim@wescottnospamdesign.com> writes:> ...or you can whomp up a FIR filter ..."whomp up" - similar to "cook up" but usually performed with more force and intention. -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://home.earthlink.net/~yatescr
You'll get a fuzzier image than you started with, because some of the frequency components in your image (sine waves) will have their amplitude peaks at positions on your image that are physically separated from where they were originally. (Remember that we're talking about phase as a function of distance or space, and not as a function of time.) "lucy" <losemind@yahoo.com> wrote in message news:cnbp9l$ftf$1@news.Stanford.EDU...> I am wondering what does phase distortion look like in image processing?
lucy wrote:> > I read the following in Matlab Help Document of Image Processing ToolBoxes, > > "FIR filters can be designed to have linear phase, which helps prevent > distortion. " > > I am wondering what does phase distortion look like in image processing?Motion blur (when the object being photographed or the camera moves while the image is taken) is the most common example of phase distortion. And of course, to counteract motion blur in an image one would need to develop a filter with non-linear phase.> > Also, > > "Another class of filter, the infinite impulse response (IIR) filter, is not > as suitable for image processing applications. It lacks the inherent > stability and ease of design and implementation of the FIR filter. > Therefore, this toolbox does not provide IIR filter support..." > > I want to ask what kind of inherent stability issue does IIR filter have?Well, IIR's can be unstable, but I wouldn't say this is the main problem with using them on images. Mostly they have (theoretically) infinite support while images are pretty short term with low dynamic range. Also, IIR's do not have linear phase. Those would be most likely the main reasons they are avoided. -jim ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! >100,000 Newsgroups ---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Randy Yates wrote:> Tim Wescott <tim@wescottnospamdesign.com> writes: > > >>...or you can whomp up a FIR filter ... > > > "whomp up" - similar to "cook up" but usually performed > with more force and intention.I don't know where I picked that phrase up, but it sure fits with hacking out some quick little thing to solve a point problem. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"lucy" <losemind@yahoo.com> wrote in message news:<cnbp9l$ftf$1@news.Stanford.EDU>...> I read the following in Matlab Help Document of Image Processing ToolBoxes, > > "FIR filters can be designed to have linear phase, which helps prevent > distortion. " > > I am wondering what does phase distortion look like in image processing?Maybe something usefil in: http://www.ysbl.york.ac.uk/~cowtan/fourier/fourier.html Best regards, Jon C.
On 2004-11-16 17:14:13 +0100, jg.campbell@ntlworld.com (Jonathan G Campbell) said:> Maybe something usefil in: > > http://www.ysbl.york.ac.uk/~cowtan/fourier/fourier.html > > Best regards, > > Jon C.Hi Jon, great link, thanks for posting! -- Stephan M. Bernsee http://www.dspdimension.com
