steve wrote:> TI has an application note concerning oversampling hints and tips, as > does a few other a/d manufacturers. Oversampling helps with noisy > systems, either to achieve the published a/d resolution or to surpass > it. This technique is very commonly used. >Can you point me to the application note? Since this post, I have successfully oversampled and averaged my input using the ADC. I haven't checked the percentage improvement, but I am sure it has improved.
Over-sampling with TMS320LF2407A
Started by ●November 25, 2004
Reply by ●November 30, 20042004-11-30
"Ajay" <ajaydsouza@gmail.com> wrote in message news:<1101789871.614717.57970@z14g2000cwz.googlegroups.com>...> steve wrote: > > TI has an application note concerning oversampling hints and tips, as > > does a few other a/d manufacturers. Oversampling helps with noisy > > systems, either to achieve the published a/d resolution or to surpass > > it. This technique is very commonly used. > > > > Can you point me to the application note?http://focus.ti.com/lit/an/spra461/spra461.pdf silabs also has a good application note about oversampling see http://www2.silabs.com/public/documents/tpub_doc/anote/Microcontrollers/Precision_Mixed-Signal/en/an118.pdf> > Since this post, I have successfully oversampled and averaged my input > using the ADC. I haven't checked the percentage improvement, but I am > sure it has improved.the tradeoff is you need a faster A/D and use more processor throughput then you would otherwise need, so your not getting something for nothing, I've see some people oversample by 1000, or 10,000. steve
