sound delay box
Started by Aleksander Wittlin November 27, 2004
Hi all,
I am looking for a simple and cheap  design of a sound delay box for
science fair exhibit. It should simply delay  microphone signal
within the range (regulated) from  0.1 to 5 seconds.
Sound quality does not really matter.
I considered a PC with sound card (bulky) or professional
audio console (expensive). Perhaps a simple DSP  board
with codec and some memory plus a small preamplifier would
be sufficient.  Any suggestions?
                                            Aleksander
"Aleksander Wittlin" <wittlin@aster.pl> wrote
> I am looking for a simple and cheap design of a sound delay box for > science fair exhibit. It should simply delay microphone signal > within the range (regulated) from 0.1 to 5 seconds. > Sound quality does not really matter. > I considered a PC with sound card (bulky) or professional > audio console (expensive). Perhaps a simple DSP board > with codec and some memory plus a small preamplifier would > be sufficient. Any suggestions?
A recent laptop with DirectX ? Heck, even my clunky second-oldest laptop (c. 1999) has sound in, sound out and can run DirectX. The laptop won't be bulky, and the DirectX SDK is downloadable from Microsoft and has many excellent pieces of example code. One should be able to be easily tweaked to do what you want. Sound quality should be as good as source. Ciao, Peter K.
"Aleksander Wittlin" <wittlin@aster.pl> wrote in message
news:coav49$1ofm$1@mamut1.aster.pl...
> Hi all, > > I am looking for a simple and cheap design of a sound delay box for > science fair exhibit. It should simply delay microphone signal > within the range (regulated) from 0.1 to 5 seconds. > Sound quality does not really matter. > I considered a PC with sound card (bulky) or professional > audio console (expensive). Perhaps a simple DSP board > with codec and some memory plus a small preamplifier would > be sufficient. Any suggestions? > > Aleksander > >
Hi Aleksander , if quality isn't a problem I would start thinking of two cheap scrap cassette recorders screwed to a length of wood. If you put a few idle wheels here and there you should be able to arrange for the delay between record from one player and play from the second to roughly fit your interval ( 0.1 second could be difficult though - maybe this technique not possible?) Best of Luck - Mike
U&#4294967295;ytkownik "Mike Yarwood" <mpyarwood@btopenworld.com> napisa&#4294967295; w wiadomo&#4294967295;ci
news:cocbj2$5j8$1@titan.btinternet.com...
> > "Aleksander Wittlin" <wittlin@aster.pl> wrote in message > news:coav49$1ofm$1@mamut1.aster.pl... >> Hi all, >> >> I am looking for a simple and cheap design of a sound delay box for >> science fair exhibit. It should simply delay microphone signal >> within the range (regulated) from 0.1 to 5 seconds. >> Sound quality does not really matter. >> I considered a PC with sound card (bulky) or professional >> audio console (expensive). Perhaps a simple DSP board >> with codec and some memory plus a small preamplifier would >> be sufficient. Any suggestions? >> >> Aleksander >> >> > Hi Aleksander , if quality isn't a problem I would start thinking of two > cheap scrap cassette recorders screwed to a length of wood. If you put a > few idle wheels here and there you should be able to arrange for the delay > between record from one player and play from the second to roughly fit > your > interval ( 0.1 second could be difficult though - maybe this technique not > possible?) > > Best of Luck - Mike >
Nice idea, thanks. However, it would be rather fragile, due to the tape. It should be children/teenagers/visitors proof. Moreover, I would either run out of tape after a while, or have to deal with a tape loop. Also I didn not mention that it should be duplex system (both participants talk and listen). Then I would need four recorders and two tapes. It may be too cumbersome to operate at the fair. regards, Aleksander
"Mike Yarwood" <mpyarwood@btopenworld.com> wrote
> Hi Aleksander , if quality isn't a problem I would start thinking of two > cheap scrap cassette recorders screwed to a length of wood. If you put a > few idle wheels here and there you should be able to arrange for the delay > between record from one player and play from the second to roughly fit your > interval ( 0.1 second could be difficult though - maybe this technique not > possible?)
Isn't that the way they used to do video delay loops? Except with wire instead of tape? :-) Ciao, Peter K.
Cheap microcontroller like Atmel AVR ATmega32 and external 128 Kb RAM will do the job, even a duplex communication with delay. Micro has built-in ADC (8-channels), DAC may be built by R-2R net and op-amp, or some cheap serial DAC chip, or by using micro's PWMs (the best choice). Counter like CMOS 4040 may be needed (in the case of R-2R net). Of course, you need a MIC pre-amps (micro has two ADC inputs with 200x gain, that may helps to reduce component number, but ADC resolution is then only 7 bits) and some audio driver for speakers. Computer speakers may be modified for that surpose. Complete device with all cables, housing etc. may be built and programmed for under 50 euro in one afternoon (experienced programmer). Best regards, Tomislav Canic
So you need two microphones and two speaker outputs?  Most standard soundcards
or laptop audio I/O only have one microphone input, so that probably means you
need a external 2-channel microphone pre-amp.  But then you could use the line
level inputs of either a laptop or a DSP or micro-controller demo board.  For
this simple application, most any commercially available boards will probably
work as long as you have enough memory.  Reducing the sample rate could save
memory, as could more processing-intensive solutions such as lossy compression
(MP3 or similar).
For robustness (child-proof) and ease of programming, I would suggest the
laptop, as everything is in a sealed package.  You may even be able to disable
the keyboard and mouse, or at least move it to where it is not easily
accessible.
"Aleksander Wittlin" <a.wittlin@aster.pl> wrote in message
news:cocoub$2t2m$1@mamut1.aster.pl...
> > U&#4294967295;ytkownik "Mike Yarwood" <mpyarwood@btopenworld.com> napisa&#4294967295; w wiadomo&#4294967295;ci > news:cocbj2$5j8$1@titan.btinternet.com... > > > > "Aleksander Wittlin" <wittlin@aster.pl> wrote in message > > news:coav49$1ofm$1@mamut1.aster.pl... > >> Hi all, > >> > >> I am looking for a simple and cheap design of a sound delay box for > >> science fair exhibit. It should simply delay microphone signal > >> within the range (regulated) from 0.1 to 5 seconds. > >> Sound quality does not really matter. > >> I considered a PC with sound card (bulky) or professional > >> audio console (expensive). Perhaps a simple DSP board > >> with codec and some memory plus a small preamplifier would > >> be sufficient. Any suggestions? > >> > >> Aleksander > >> > >> > > Hi Aleksander , if quality isn't a problem I would start thinking of two > > cheap scrap cassette recorders screwed to a length of wood. If you put a > > few idle wheels here and there you should be able to arrange for the delay > > between record from one player and play from the second to roughly fit > > your > > interval ( 0.1 second could be difficult though - maybe this technique not > > possible?) > > > > Best of Luck - Mike > > > Nice idea, thanks. However, it would be rather fragile, due to the tape. It > should be > children/teenagers/visitors proof. Moreover, I would either run out of tape > after a while, > or have to deal with a tape loop. Also I didn not mention that it should be > duplex > system (both participants talk and listen). Then I would need four recorders > and two tapes. It may be too cumbersome to operate at the fair. > >
regards,
Aleksander
Aleksander, Decent speech quality needs at least 8000 samples per second, so a 5 second delay needs 40,000 samples at that rate. Even using two bytes to store each sample, this is a reasonable amount of memory for a program on a laptop or desktop PC. Your program can implement a circular buffer with one pointer. Read from the pointed-to location and send the sample there to the audio output. Get the new sample from the microphone, and write it to the same location, then Check to see if the end of the buffer has been reached. If so, reset the pointer. If not, advance it. Then wait for the new sample and begin again. The size of the buffer determines the delay. Depending on the hardware and the signals it sends, you might need to modify the procedure a bit. If you have trouble getting it to work, let us know what it is and we'll try to help. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
