RV <do_not_use@email.com> writes:> On Fri, 24 Dec 2004 12:28:55 -0500, Jerry Avins <jya@ieee.org> wrote: > >>RV wrote: >> >> ... >> >>> At some point do you guys thinkl you can stick to windows multimedia >>> API's and forget the lesson on a whole lotta "stuff" that means >>> nothing to the guy whio is trying to worte to code in win mm API code. >> >>Simplifying is appropriate. Misinforming is not. > > Uh huh > So > Do you know the code used in Win32 mm API to do what the OP needs to > do or not?I responded with exactly this information a few days ago but no one seemed to care: http://groups-beta.google.com/group/comp.multimedia/msg/0a87318d38ea41eb?dmode=source --RY -- % Randy Yates % "The dreamer, the unwoken fool - %% Fuquay-Varina, NC % in dreams, no pain will kiss the brow..." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Eldorado Overture', *Eldorado*, ELO http://home.earthlink.net/~yatescr
soundcard buffer format
Started by ●December 21, 2004
Reply by ●February 2, 20052005-02-02
On Fri, 24 Dec 2004 12:28:55 -0500, Jerry Avins <jya@ieee.org> wrote:>RV wrote: > > ... > >> At some point do you guys thinkl you can stick to windows multimedia >> API's and forget the lesson on a whole lotta "stuff" that means >> nothing to the guy whio is trying to worte to code in win mm API code. > >Simplifying is appropriate. Misinforming is not.Uh huh So Do you know the code used in Win32 mm API to do what the OP needs to do or not?
On Thu, 23 Dec 2004 18:10:08 +0100, Stephan M. Bernsee <spam@dspdimension.com> wrote:>On 2004-12-23 15:59:48 +0100, RV <do_not_use@email.com> said: > >> Jerry was right >> 16 bit describes the size, not the rate > >Yes. And I was adding that for one channel, sample size * sample rate = bit rate.Not used in Win API audio coding.> >> I used bit rate in the begining and I was wrong, he was right. >> 16 bit means the is Bit "size". >> 8 bit means the Bit "size". > >No, it doesn't. A bit has always a size of exactly 1. >16 bit or 8 bit is the word length for your samples.Un huh Well for you then Ill shuffle it again. 16 bit means the is "size" in bits. 8 bit means the "size" in bits. Let me know if that still not self evident Ill try holding my toungue in the other direction when I post the reply.> >> You corrected him by saying that is the Bit rate.? > >No. The bit rate is the number of bits that go to the D/A per second. >That's what I wrote in my last post.Uh huh But how does that answer the question "You corrected him by saying that is the Bit "rate".?"> >> bit per sec describes the "rate" >> 16 bit and 8 bit refers only othe the size as he said. > >See my last posting - that's exactly what I said, too!He said ~~~~~> Most people I know would call that size, not rate. Is rate commonly used > that way among some groups? > > Jerry~~~~~~ To which you said ~~~~~~ I hope not! Bit rate generally means the number of bits/sec. Of course, for a change in sample rate this number changes, too. ~~~~~ rate was wrong size was right.> >> "bit rate" is used in compressed audio not PCM wave and was used by me >> to begin with incorrectly. > >"Bit rate" can be used for non-compressed audio as well. Like I said, >it just describes the number of bits that pass through your buffer per >second.Not in Win API audio code. Thats what the OP is using.> >> Last time I make that mistake on Usenet.. > >Don't worry - making mistakes is a good thing! I do it all the time. >:-) > >> When I wrote use samples per sec I mean use samples per sec in >> preference to bit per sec when specifying rate for a PCM wave file >> becuase thats what is used in PCM wave code. >> Not bit per sec. > >That's a matter of naming convention. You can use both units, but they >mean different things.Not in Win API audio code Apples aint oranges. The API code for PCM wave is the API code for PCM wave> >>> You store your data points (your SAMPLES) as numbers of a certain WORD >>> LENGTH (typically 8, 16, 24, 32 BITS each) collected a certain SAMPLE >>> RATE (typically specified as samples/sec). Also, you are usually >>> dealing with FRAMES which contain a certain number of samples per >>> channel. For a stereo recording, each frame contains 2 samples, left >>> and right. >> >> You might refer to them as frames but the WAVE structure doesnt so to >> call a stereo pair of samples a frame doesnt equate to what the OP is >> trying to do, which is write the code for WAVE. > >Yes I agree. Now I see our problem: you were talking about that WAVE >structure and how things are called therein. You should be aware that >M$ never actually cared a great deal about correct naming or sensible >units, obviously. Maybe that's part of the confusion here.The only confustion is when some people use terms not used in the code that is to be wrritten by the OP. Thats Win32 MM API code.> >>> Nope, the minimum level for signed 16 bit data is -32768, not -32767. >> >> -32768 might be the "minimum" level of a signed integer. >> (do you mean, the minimum "value" for a signed integer ?) > >Sure. The minimum value, or the most negative value, or the audio level >corresponding to the most negative value.And that audio level is?> >> Im refering to the number of audio "levels" each side of 0 to show >> that 0 is the lowest audio level. > >Right, zero is zero. No doubt about it. ;-) > >> But if it your wish it, make that. >> >> The range is >> 0 -32768 >> and >> 0 +32768 > >No again, a value of +32768 would wrap around. Either you are talking >about values, in which case your values go from -32768 to +32767 or >you're talking about a *range*, which is always a positive numberUhh huh Well back to Win API audio coding. We dont have -32768 and +32767 as the peak values of audio level. In Win API audio code. we have 2 peak signed values of the same order of scale, each side of 0
On 2004-12-23 15:59:48 +0100, RV <do_not_use@email.com> said:> Jerry was right > 16 bit describes the size, not the rateYes. And I was adding that for one channel, sample size * sample rate = bit rate.> I used bit rate in the begining and I was wrong, he was right. > 16 bit means the is Bit "size". > 8 bit means the Bit "size".No, it doesn't. A bit has always a size of exactly 1. 16 bit or 8 bit is the word length for your samples.> You corrected him by saying that is the Bit rate.?No. The bit rate is the number of bits that go to the D/A per second. That's what I wrote in my last post.> bit per sec describes the "rate" > 16 bit and 8 bit refers only othe the size as he said.See my last posting - that's exactly what I said, too!> "bit rate" is used in compressed audio not PCM wave and was used by me > to begin with incorrectly."Bit rate" can be used for non-compressed audio as well. Like I said, it just describes the number of bits that pass through your buffer per second.> Last time I make that mistake on Usenet..Don't worry - making mistakes is a good thing! I do it all the time. :-)> When I wrote use samples per sec I mean use samples per sec in > preference to bit per sec when specifying rate for a PCM wave file > becuase thats what is used in PCM wave code. > Not bit per sec.That's a matter of naming convention. You can use both units, but they mean different things.>> You store your data points (your SAMPLES) as numbers of a certain WORD >> LENGTH (typically 8, 16, 24, 32 BITS each) collected a certain SAMPLE >> RATE (typically specified as samples/sec). Also, you are usually >> dealing with FRAMES which contain a certain number of samples per >> channel. For a stereo recording, each frame contains 2 samples, left >> and right. > > You might refer to them as frames but the WAVE structure doesnt so to > call a stereo pair of samples a frame doesnt equate to what the OP is > trying to do, which is write the code for WAVE.Yes I agree. Now I see our problem: you were talking about that WAVE structure and how things are called therein. You should be aware that M$ never actually cared a great deal about correct naming or sensible units, obviously. Maybe that's part of the confusion here.>> Nope, the minimum level for signed 16 bit data is -32768, not -32767. > > -32768 might be the "minimum" level of a signed integer. > (do you mean, the minimum "value" for a signed integer ?)Sure. The minimum value, or the most negative value, or the audio level corresponding to the most negative value.> Im refering to the number of audio "levels" each side of 0 to show > that 0 is the lowest audio level.Right, zero is zero. No doubt about it. ;-)> But if it your wish it, make that. > > The range is > 0 -32768 > and > 0 +32768No again, a value of +32768 would wrap around. Either you are talking about values, in which case your values go from -32768 to +32767 or you're talking about a *range*, which is always a positive number. The range for both signed and unsigned 16 bit integers is 65536 different numeric values, or possible amplitude levels. It's not that this is my wish, it's just how things are. -- Stephan M. Bernsee http://www.dspdimension.com
On Wed, 22 Dec 2004 20:33:54 +0100, Stephan M. Bernsee <spam@dspdimension.com> wrote:>On 2004-12-22 14:36:51 +0100, RV <do_not_use@email.com> said: > >> On Wed, 22 Dec 2004 07:44:54 +0100, Stephan M. Bernsee >> <spam@dspdimension.com> wrote: >> >>> I hope not! >>> >>> Bit rate generally means the number of bits/sec. Of course, for a >>> change in sample rate this number changes, too. >> >> Not quite, bit rate is the "rate" of bits over time. > >That's what I said, is it not?As far as I know this is what was said ~~~~~~~>> Most people I know would call that size, not rate. Is rate commonly used >> that way among some groups? >> >> Jerry>I hope not!>Bit rate generally means the number of bits/sec. Of course, for a >change in sample rate this number changes, too.~~~~~~~~~ Jerry was right 16 bit describes the size, not the rate I used bit rate in the begining and I was wrong, he was right. 16 bit means the is Bit "size". 8 bit means the Bit "size". You corrected him by saying that is the Bit rate.? bit per sec describes the "rate" 16 bit and 8 bit refers only othe the size as he said. "bit rate" is used in compressed audio not PCM wave and was used by me to begin with incorrectly. Last time I make that mistake on Usenet..> >> "16 bit" or "8 bit" simply represents the block size in bits of each >> sample, it doesn't describe time. > >Yes - again that's what I said. > >> For bit per sec I suggest it's best to refer to wave as samples per >> sec. > >Samples per sec doesn't say anything about the word length of the >samples, this is something different. IOW: "samples per sec" does not >define "bits per sec" without knowing the word length.When I wrote use samples per sec I mean use samples per sec in preference to bit per sec when specifying rate for a PCM wave file becuase thats what is used in PCM wave code. Not bit per sec.> >Again, to recap: > >You store your data points (your SAMPLES) as numbers of a certain WORD >LENGTH (typically 8, 16, 24, 32 BITS each) collected a certain SAMPLE >RATE (typically specified as samples/sec). Also, you are usually >dealing with FRAMES which contain a certain number of samples per >channel. For a stereo recording, each frame contains 2 samples, left >and right.You might refer to them as frames but the WAVE structure doesnt so to call a stereo pair of samples a frame doesnt equate to what the OP is trying to do, which is write the code for WAVE. So if he uses samples and blocks for wave it might make more sense looking at the structure in code.. This is the WAVEFORMATstructure, Im sure youve seen it before. FormatTag Channels SamplesPerSec AvgBytesPerSec BlockAlign BitsPerSample no frames Blocks and Samples BitsPerSample describes block size in bits. And a Block is the BitsPerSample multiplied by number of channels For rate, which none of the above describe Samples per sec AvgByte per sec comes close to "bit per sec" being it describes the rate and bits via bytes, but "bit per sec" isnt use in PCM wave code. "bit per sec" is used in code for compression encoded audio like MPEG And no frames anywhere in the code for PCM wave. Not in WAVEHDR, WAVEINCAPS or WAVEOUTCAPS If you want to use "frames" see the description for any compression encoded audio like MPEG, where you will find your "frames" in the terminology of the code used. See MPEGLAYER3WAVEFORMAT FramesPerBlock So there are your Frames in MPEG compression encoded files. But "Frames" isnt used in the PCM wave code anywhere. So to be of most help to the OP with his code lets not put "Frames" where "Frames" are not used or needed. Me mentioning "bit rate" to begin with has caused enough confusion already I think.> >The BIT RATE would then be the total number of bits shuffled to the D/A >converters (or any other device in the signal chain) in each second >that passes.True but we are refering to the levels of each sample, or thats what the Jerry pointed out and in fact the OP did ask. Wanting to know the scale or "bit size" that applies to audio level incoming. For a change in sample rate.> This rate would consequently be the product of the word >length of the samples, the sample rate and the frame size (ie. number >of channels) over one second.Yeah but Block size for PCM wave. Or BlockAlign number of channels multiplied by bytes per sample. What you called the BIT RATE is called BytesPerSec in PCM wave audio code. samples per sec multiplied by block size.> >Now it is immediately clear why changing the sample rate will change >this number. Changing the sample rate does, however, NOT change the >word length of the individual samples because it's just a number >describing how many measurements are taken at each second, but not how >many amplitude levels they can distinguish (ie. how many bits each of >them contains). > >> So if you use samples per sec in non compression encoded files it >> defines the two seperately. > >I'm sorry but I don't know what you're getting at. I never mentioned >compression and this has nothing to do with it - I was referring to raw >PCM data. >My point was, there is no need to express the rate as "bit per sec" for a wave file, it doesnt mean anything in code for WAVE functions and structures "samples per sec" does. "bit per sec" is only going to be of any value in code terms for compression audio.>>> The word length (for the "short int" data type this is usually 16 bits) >>> does not change with sample rate. >> >> Yep, thats one channel maximum scale. >> So >> 16 bit audio is 4 byte per sample, 16 bit per channel stereo. > >One sample of a 16 bit audio recording is 2 bytes (= 16 bit) per >sample, with two samples per frame for stereo (left and right). This >equals 4 bytes in total. >Yeah I left out "block" size read "block" not "frame" in a PCM wave. 16 bits 4 bytes When he adds up 16 bits over 4 bytes for stereo L and R Im sure he will sort that one out in code. Stereo 16 bit per sample in 4 bytes or 16 bit per samples in 4 byte block size for stereo>> giving scale range of 65534 per channel of which the centre point of >> the scale at 32767 is 0 level sound. > >Nope. The correct number for the *range* is 65536 levels (0-65535) if >we're dealing with 16 bit unsigned data. > >> OR for working purposes >> 16 bit using signed values -32767 max to +32767 max audio levels and >> then 0 is 0 audio level. > >Nope, the minimum level for signed 16 bit data is -32768, not -32767.-32768 might be the "minimum" level of a signed integer. (do you mean, the minimum "value" for a signed integer ?) Im refering to the number of audio "levels" each side of 0 to show that 0 is the lowest audio level. and the audio level increases with the value each side of 0 32767 levels in the - direction for maximum audio level, and 32767 in the plus direction for maximum audio level But if it your wish it, make that. The range is 0 -32768 and 0 +32768
On 2004-12-22 14:36:51 +0100, RV <do_not_use@email.com> said:> On Wed, 22 Dec 2004 07:44:54 +0100, Stephan M. Bernsee > <spam@dspdimension.com> wrote: > >> I hope not! >> >> Bit rate generally means the number of bits/sec. Of course, for a >> change in sample rate this number changes, too. > > Not quite, bit rate is the "rate" of bits over time.That's what I said, is it not?> "16 bit" or "8 bit" simply represents the block size in bits of each > sample, it doesn't describe time.Yes - again that's what I said.> For bit per sec I suggest it's best to refer to wave as samples per > sec.Samples per sec doesn't say anything about the word length of the samples, this is something different. IOW: "samples per sec" does not define "bits per sec" without knowing the word length. Again, to recap: You store your data points (your SAMPLES) as numbers of a certain WORD LENGTH (typically 8, 16, 24, 32 BITS each) collected a certain SAMPLE RATE (typically specified as samples/sec). Also, you are usually dealing with FRAMES which contain a certain number of samples per channel. For a stereo recording, each frame contains 2 samples, left and right. The BIT RATE would then be the total number of bits shuffled to the D/A converters (or any other device in the signal chain) in each second that passes. This rate would consequently be the product of the word length of the samples, the sample rate and the frame size (ie. number of channels) over one second. Now it is immediately clear why changing the sample rate will change this number. Changing the sample rate does, however, NOT change the word length of the individual samples because it's just a number describing how many measurements are taken at each second, but not how many amplitude levels they can distinguish (ie. how many bits each of them contains).> So if you use samples per sec in non compression encoded files it > defines the two seperately.I'm sorry but I don't know what you're getting at. I never mentioned compression and this has nothing to do with it - I was referring to raw PCM data.>> The word length (for the "short int" data type this is usually 16 bits) >> does not change with sample rate. > > Yep, thats one channel maximum scale. > So > 16 bit audio is 4 byte per sample, 16 bit per channel stereo.One sample of a 16 bit audio recording is 2 bytes (= 16 bit) per sample, with two samples per frame for stereo (left and right). This equals 4 bytes in total.> giving scale range of 65534 per channel of which the centre point of > the scale at 32767 is 0 level sound.Nope. The correct number for the *range* is 65536 levels (0-65535) if we're dealing with 16 bit unsigned data.> OR for working purposes > 16 bit using signed values -32767 max to +32767 max audio levels and > then 0 is 0 audio level.Nope, the minimum level for signed 16 bit data is -32768, not -32767.> 8 bit audio is 2 byte per sample, 8 bit per channel. > giving 256 scale range per channel of which the centre point of that > scale at 128 is 0 level sound. > > OR for working purposes > 8 bit using signed values so - 128 max to +128 max audio levels and > then 0 is 0 audio level.Nope again. It's -128 to +127 for 8 bit signed integers. Hope this clears things up. -- Stephan M. Bernsee http://www.dspdimension.com
On Wed, 22 Dec 2004 07:44:54 +0100, Stephan M. Bernsee <spam@dspdimension.com> wrote:>On 2004-12-22 05:42:04 +0100, Jerry Avins <jya@ieee.org> said: > >> Emile wrote: >> >> ... >> >>>> How? What does "bit rate" mean in this context, anyway? >>>> >>> >>> i think it means how many bits are used to encode one sample in computer >>> memory, thus with 2^8 or with 2^16 possible values for the amplitude of >>> that sample. >> >> Most people I know would call that size, not rate. Is rate commonly used >> that way among some groups? >> >> Jerry > >I hope not! > >Bit rate generally means the number of bits/sec. Of course, for a >change in sample rate this number changes, too.Not quite, bit rate is the "rate" of bits over time. "16 bit" or "8 bit" simply represents the block size in bits of each sample, it doesn't describe time. For bit per sec I suggest it's best to refer to wave as samples per sec. Not to be confused with compression encoded files where you would count the bit rate of the encoded frames per sec to determine time, not the just sample rate of the input samples per sec alone to determine time as with a wave. As in more or less compression = more or less bit rate, but at the same sample rate from the input stream sample rate, the sample rate is stored in the header of the frame in the case of mpeg audio. So if you use samples per sec in non compression encoded files it defines the two seperately.> >The word length (for the "short int" data type this is usually 16 bits) >does not change with sample rate.Yep, thats one channel maximum scale. So 16 bit audio is 4 byte per sample, 16 bit per channel stereo. giving scale range of 65534 per channel of which the centre point of the scale at 32767 is 0 level sound. OR for working purposes 16 bit using signed values -32767 max to +32767 max audio levels and then 0 is 0 audio level. 8 bit audio is 2 byte per sample, 8 bit per channel. giving 256 scale range per channel of which the centre point of that scale at 128 is 0 level sound. OR for working purposes 8 bit using signed values so - 128 max to +128 max audio levels and then 0 is 0 audio level. HTH Cheers
On 2004-12-22 05:42:04 +0100, Jerry Avins <jya@ieee.org> said:> Emile wrote: > > ... > >>> How? What does "bit rate" mean in this context, anyway? >>> >> >> i think it means how many bits are used to encode one sample in computer >> memory, thus with 2^8 or with 2^16 possible values for the amplitude of >> that sample. > > Most people I know would call that size, not rate. Is rate commonly used > that way among some groups? > > JerryI hope not! Bit rate generally means the number of bits/sec. Of course, for a change in sample rate this number changes, too. The word length (for the "short int" data type this is usually 16 bits) does not change with sample rate. -- Stephan M. Bernsee http://www.dspdimension.com
