rickman <gnuarm@gmail.com> wrote:>On 6/5/2015 7:07 AM, kaz wrote:>> A related question. A DAC device produces multiple (infinite) images of a >> frequency. How come energy be infinite or should we say a receiver can >> detect the frequency at any point that corresponds to an image.>Funny that the replies to your post are dealing with the DAC waveform >without responding to the fact that you are likely confusing the DAC >with the ADC in your question.I would take this question at face value; I don't think it's confused.>It is the sampled output of an ADC which >can be considered to contain infinite aliased copies of the baseband >signals at the various reflection points. The energy in that waveform >is not infinite because these are just alternate ways of looking at the >same signals, not added signals.Okay>The output waveform of a DAC does indeed have energy at higher >frequencies, but at diminishing levels similar to how a square wave >contains an infinite series of sine waves and yet is finite in amplitude.Only if the output of the DAC is filtered (including any zero-order hold one has applied). An unadorned idealized DAC outputs an impulse "train", to which is often applied a "boxcar" zero-older hold, but this second step is a convenient practicality for typical systems which (by a happy coincidence) do not need or require the higher-frequency images. But other systems may want one of the higher images. Let's say the sample rate at the DAC is 10 KHz, containing a signal of interest which is narrowband and centered at 2.5 KHz. Construct a DAC which outputs a square impulse (perhaps best achieved in the current domain) of 1 usec duration. There is still a sinx/x rollof, but it is much further out than if you had a zero-order hold (a 1 usec boxcar instead of a 100 usec boxcar). In the frequency domain you now have a train of narrowband images, gently rolling off and separated by 5 KHz, and you can isolate out the image you desire with a bandpass filter. Steve
Slightly OT - Wireless Energy
Started by ●June 5, 2015
Reply by ●June 6, 20152015-06-06
spope33@speedymail.org (Steve Pope) writes:> rickman <gnuarm@gmail.com> wrote: > >>On 6/5/2015 7:07 AM, kaz wrote: > >>> A related question. A DAC device produces multiple (infinite) images of a >>> frequency. How come energy be infinite or should we say a receiver can >>> detect the frequency at any point that corresponds to an image. > >>Funny that the replies to your post are dealing with the DAC waveform >>without responding to the fact that you are likely confusing the DAC >>with the ADC in your question. > > I would take this question at face value; I don't think it's confused. > >>It is the sampled output of an ADC which >>can be considered to contain infinite aliased copies of the baseband >>signals at the various reflection points. The energy in that waveform >>is not infinite because these are just alternate ways of looking at the >>same signals, not added signals. > > Okay > >>The output waveform of a DAC does indeed have energy at higher >>frequencies, but at diminishing levels similar to how a square wave >>contains an infinite series of sine waves and yet is finite in amplitude. > > Only if the output of the DAC is filtered (including any zero-order > hold one has applied). > > An unadorned idealized DAC outputs an impulse "train", to which is > often applied a "boxcar" zero-older hold, but this second step > is a convenient practicality for typical systems which (by a > happy coincidence) do not need or require the higher-frequency > images. > > But other systems may want one of the higher images. Let's say the > sample rate at the DAC is 10 KHz, containing a signal of interest which > is narrowband and centered at 2.5 KHz. Construct a DAC which outputs a > square impulse (perhaps best achieved in the current domain) of > 1 usec duration. There is still a sinx/x rollof, but it is much > further out than if you had a zero-order hold (a 1 usec boxcar > instead of a 100 usec boxcar). > > In the frequency domain you now have a train of narrowband images, > gently rolling off and separated by 5 KHz, and you can isolate out > the image you desire with a bandpass filter.I actually saw this phenomenom on a spectrum analyzer at Sony Ericsson many years ago. For a minute or two I was confounded, but then I realized it was the images from the digital source. Yes, the images attenuated eventually, but at least the first couple were significant. I'm sorry but I can't remember the exact context (sample rate, etc.). -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
Randy Yates <yates@digitalsignallabs.com> writes:> spope33@speedymail.org (Steve Pope) writes: > >> rickman <gnuarm@gmail.com> wrote: >> >>>On 6/5/2015 7:07 AM, kaz wrote: >> >>>> A related question. A DAC device produces multiple (infinite) images of a >>>> frequency. How come energy be infinite or should we say a receiver can >>>> detect the frequency at any point that corresponds to an image. >> >>>Funny that the replies to your post are dealing with the DAC waveform >>>without responding to the fact that you are likely confusing the DAC >>>with the ADC in your question. >> >> I would take this question at face value; I don't think it's confused. >> >>>It is the sampled output of an ADC which >>>can be considered to contain infinite aliased copies of the baseband >>>signals at the various reflection points. The energy in that waveform >>>is not infinite because these are just alternate ways of looking at the >>>same signals, not added signals. >> >> Okay >> >>>The output waveform of a DAC does indeed have energy at higher >>>frequencies, but at diminishing levels similar to how a square wave >>>contains an infinite series of sine waves and yet is finite in amplitude. >> >> Only if the output of the DAC is filtered (including any zero-order >> hold one has applied). >> >> An unadorned idealized DAC outputs an impulse "train", to which is >> often applied a "boxcar" zero-older hold, but this second step >> is a convenient practicality for typical systems which (by a >> happy coincidence) do not need or require the higher-frequency >> images. >> >> But other systems may want one of the higher images. Let's say the >> sample rate at the DAC is 10 KHz, containing a signal of interest which >> is narrowband and centered at 2.5 KHz. Construct a DAC which outputs a >> square impulse (perhaps best achieved in the current domain) of >> 1 usec duration. There is still a sinx/x rollof, but it is much >> further out than if you had a zero-order hold (a 1 usec boxcar >> instead of a 100 usec boxcar). >> >> In the frequency domain you now have a train of narrowband images, >> gently rolling off and separated by 5 KHz, and you can isolate out >> the image you desire with a bandpass filter. > > I actually saw this phenomenom on a spectrum analyzer at Sony Ericsson > many years ago. For a minute or two I was confounded, but then I > realized it was the images from the digital source. Yes, the images > attenuated eventually, but at least the first couple were significant. > I'm sorry but I can't remember the exact context (sample rate, etc.).PS: When it hit me what I was looking at, it was quite a revelation: where theory and reality crossed! -- Randy Yates Digital Signal Labs http://www.digitalsignallabs.com
>Randy Yates <yates@digitalsignallabs.com> writes: > >> spope33@speedymail.org (Steve Pope) writes: >> >>> rickman <gnuarm@gmail.com> wrote:>>>>Funny that the replies to your post are dealing with the DAC waveform>>>>without responding to the fact that you are likely confusing the DAC >>>>with the ADC in your question. >>> >>> I would take this question at face value; I don't think it'sconfused.>>>Both DAC and ADC (theoretically) show sort of broadcast of signal. A DAC without sinc envelope and no further filter will broadcast frequency to infinite points. In fact some NCO are based on having a high image as their output instead of the fundamental. An ADC similarly receives frequency from infinite points into the digital domain (assuming no filter). Though I can't explain it in terms of energy physics. Kaz --------------------------------------- Posted through http://www.DSPRelated.com
