Hi, I created an image in Matlab in the following way: I created 2 vectors that represent the image coordinates, and gave a value to each combination of the vectors. For example: a=[-0.4:0.02:0.4], b=a, image(y,x) is the value of a(y), b(x). Then I performed some operations that are like Fourier transform. I got new coordinates that were not equally spaced. So I made a grid, and interpolated the results I had to that grid. Then I performed ifft. I got an image that is similar to my original image, but not in the right coordinates. For example, If in the original I had a point in the upper right corner, in the new image it is in the middle of the image. What do I need to do in order to get back my true image? How is it related to the sampling frequency?
FFT in Matlab
Started by ●January 28, 2005
Reply by ●January 28, 20052005-01-28
Hi Chenitz, It sounds like you may be using fftshift on one of your transformations and not the other - I'd just check your code to see if this might be happening before worrying about anything more complicated. Best of Luck - Mike "chenitz" <chenitz@yahoo.com> wrote in message news:5f35af74.0501280022.b61c37f@posting.google.com...> Hi, > > I created an image in Matlab in the following way: I created 2 vectors > that represent the image coordinates, and gave a value to each > combination of the vectors. For example: a=[-0.4:0.02:0.4], b=a, > image(y,x) is the value of a(y), b(x). Then I performed some > operations that are like Fourier transform. I got new coordinates that > were not equally spaced. So I made a grid, and interpolated the > results I had to that grid. Then I performed ifft. I got an image that > is similar to my original image, but not in the right coordinates. For > example, If in the original I had a point in the upper right corner, > in the new image it is in the middle of the image. What do I need to > do in order to get back my true image? How is it related to the > sampling frequency?
