hi, I got a problem w/ optimizing a loop. I use the TMS320C6414 DSP. It is an image processing algorithm and the loop contains a control statement (if), therefore sw pipelining is not possible. The if statements checks the lower and upper margines for the intensity of each pixel. Here is a pseudo code snippet: for(i = 0; i < scr_mfs->m_nRoiHeight; i++) { [...] for(j = 0; j < scr_mfs->m_nRoiWidth; j++, pOut += depth) { [...] // calculate the value of buf if(buf < 0) buf = 0; else if(buf > MAX_GRAY_SCALE) buf = MAX_GRAY_SCALE; pOut[0] = buf; //output } } The data type is short and the algo is working on 12bit images. Is there a way to do that differently? Are there any instructions to do the check that won't flush the pipeline? Any help is appreciated. Thank you, Mike
optimizing image processing - control statement in loop prevents sw pipelining
Started by ●February 8, 2005
Reply by ●February 8, 20052005-02-08
maikeru wrote:> hi, > > I got a problem w/ optimizing a loop. I use the TMS320C6414 DSP. > It is an image processing algorithm and the loop contains a > control statement (if), therefore sw pipelining is not possible. > > The if statements checks the lower and upper margines for the > intensity of each pixel. Here is a pseudo code snippet: > > for(i = 0; i < scr_mfs->m_nRoiHeight; i++) > { > [...] > for(j = 0; j < scr_mfs->m_nRoiWidth; j++, pOut += depth) > { > [...] // calculate the value of buf > if(buf < 0) > buf = 0; > else if(buf > MAX_GRAY_SCALE) > buf = MAX_GRAY_SCALE; > > pOut[0] = buf; //output > } > } > > The data type is short and the algo is working on 12bit images. > Is there a way to do that differently? > Are there any instructions to do the check that won't flush the > pipeline? Any help is appreciated. > > Thank you, > > Mike >You may have to do some assembly language programming. I'm not familiar with the '64xx series, so this is fairly general. First check to see if there are conditionally executable instructions: the ADSP21xx series will let you do a load depending on a flag, for instance. This would solve your problem right quick. If that fails, and if your buffer value calculation fits into the MAC paradigm then scale things so that MAX_GRAY_SCALE maps to 0xffffffff (or 0xffff) and 0 maps to zero. Then you should be able to do an accumulator saturate to hit 0 and 0xffffffff and shift things down to MAX_GRAY_SCALE once you're done. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Thx Tim, I've already done quite some assemble programming in that project, but so far I am not aware of any conditionally executable instructions on the C64xx. I did not exactly get the thing about MAC paradigm. I know what you are trying to tell me with the saturation and shifting back. I was actually looking for an approach like this, but I don't exactly know how to do it. Thank you again for the quick answer, Mike
maikeru wrote:> Thx Tim, > > I've already done quite some assemble programming in that project, > but so far I am not aware of any conditionally executable instructions > on the C64xx. > > I did not exactly get the thing about MAC paradigm. I know what you > are trying to tell me with the saturation and shifting back. I was > actually > looking for an approach like this, but I don't exactly know how to do > it. > > Thank you again for the quick answer, > > Mike >Basically if you arrive at the value of 'buf' through a series of multiply-accumulates, like: buf = sum from {n=0} to {N-1} {inputData_n * coefficient_n} That'll be executed as a vector dot product, and can be done entirely in a MAC instruction. All you would have to do in that case would be to adjust the values of the coefficients to do what I was suggesting. At worst you may be able to do a single MAC instruction, so * Get your value for buf * clear the accumulator * multiply by 0xffffffff / MAX_PIXEL_VALUE * saturate * shift (or multiply) down to MAX_PIXEL_VALUE -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
You can do conditional executes on the C6x. Every instruction conditionally executes based on A1, A2, B0, B1, B2. Read the manual (ie page 3.13 of the C62x instruction set) So do a CMP, put the result in one of the above registers, and then use the register in a conditional execute operation. Tim Wescott wrote:> maikeru wrote: > > > Thx Tim, > > > > I've already done quite some assemble programming in that project, > > but so far I am not aware of any conditionally executableinstructions> > on the C64xx. > > > > I did not exactly get the thing about MAC paradigm. I know what you > > are trying to tell me with the saturation and shifting back. I was > > actually > > looking for an approach like this, but I don't exactly know how todo> > it. > > > > Thank you again for the quick answer, > > > > Mike > > > Basically if you arrive at the value of 'buf' through a series of > multiply-accumulates, like: > > buf = sum from {n=0} to {N-1} {inputData_n * coefficient_n} > > That'll be executed as a vector dot product, and can be done entirelyin> a MAC instruction. All you would have to do in that case would be to> adjust the values of the coefficients to do what I was suggesting. > > At worst you may be able to do a single MAC instruction, so > > * Get your value for buf > * clear the accumulator > * multiply by 0xffffffff / MAX_PIXEL_VALUE > * saturate > * shift (or multiply) down to MAX_PIXEL_VALUE > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com
dan wrote:> You can do conditional executes on the C6x. Every instruction > conditionally executes based on A1, A2, B0, B1, B2. Read the manual > (ie page 3.13 of the C62x instruction set) > So do a CMP, put the result in one of the above registers, and then use > the register in a conditional execute operation. > > Tim Wescott wrote:snip This is a much better answer than mine, unless you're already doing MAC's and are poised to just saturate anyway -- perhaps even then. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Reply by ●February 9, 20052005-02-09
Hi guys, thank you for your answers, I was thinking them over (cuz I'm working on packed 16bit values) and reading the manuals again when I stumble over the MIN2 and MAX2 (spru189, 5-118 & 5-124) instructions for the 64xx. With their help I don't need to worry about anything, they check against a lower and upper boundery and return the right results automatically. I implemented it and it works just fine. Thx again for your help, Cheers, Mike http://mmatter.gmxhome.de/
