I want to use Visual DSP++ 3.5 to talk to an old 21061 EZ-Kit lite (and eventually a 21065L EZ-Kit) via RS-232. However, I can't seem to set-up an appropriate session in Visual DSP++ 3.5. In the New Session dialog box, I don't seem to have the option listed for the 21061 EZ-Kit. Under Debug target, I do see "EZ-KIT Lite (ADSP-21xxx)". I choose that, but now my only choices for processor are the 21160, 21161, or 21262. Nothing for the 210xx parts. I tried using the Configurator tool to create a Platform. I created a "ADSP-21061 EZ-KIT Lit via COM port" platform, but it never shows up in the New Session dialog box. I've tried multiple un-installs/re-installs, making sure all components are installed. I've tried this on 2 different PCs, one with Win2K and the other with Win98. I also had an old 2.0 version of the software hanging around so I tried with that with similar results. What am I missing? Is there some licensing issues that prevent certain products from appearing? My license is listed as "Validated (Permanent)". Thanks! -Jon
21061 EZ-Kit lite session?
Started by ●February 18, 2005
Reply by ●April 4, 20052005-04-04
>What am I missing? Is there some licensing issues that prevent certainproducts>from appearing? My license is listed as "Validated (Permanent)".Same issue here! I cannot program the darn thing... Is there a solution for this. It seems that the ez-kit adsp-21061 is simply missing from the config menu. grt. gtek This message was sent using the Comp.DSP web interface on www.DSPRelated.com
I ended up trying several different versions of VisualDSP, and eventually found one that worked. I believe it was version 3.0. I never found any explanation as to why this would be. I was able to find quite a few old versions on the Analog Devices web site for download. -- Jon Harris SPAM blocked e-mail address in use. Replace the ANIMAL with 7 to reply. "gtek" <gtekprog@hotmail.com> wrote in message news:0J6dnV3-4NfuJczfRVn-gA@giganews.com...> >What am I missing? Is there some licensing issues that prevent certain > products > >from appearing? My license is listed as "Validated (Permanent)". > > Same issue here! > > I cannot program the darn thing... > Is there a solution for this. It seems that the ez-kit adsp-21061 is > simply missing from the config menu. > > grt. > gtek > > > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
Reply by ●April 23, 20052005-04-23
Well, The answer to these problems is very simple. Analog devices DID not provide support in later versions then visual dsp 3.0. Very odd is the fact that support is somehow still implemented in the configurator. Only some config files seems to be missing, which causes visual dsp versions beyond 3.0 to produce .csv errors on loading. I copied these csv files: - Regfile61_EZKIT.csv ( in system directory visualdsp ) - Regfile.csv ( "" "" ) into the visual dsp3.5 directory, but still some errors, but not that it is missing the csv files!! help needed! grt. Gtekprog This message was sent using the Comp.DSP web interface on www.DSPRelated.com
YEAH!!! Visual dsp 3.0, 3.5 and 4.0 are working with the adsp-21061 EZ-lite kit now!!. Analog device wouldn't provide a fix, because they don't support the adsp-21061 ez-lite kit anymore. The fix is as follow: Download these csv files and put them into your visualdsp/system directory. http://62.216.16.167/evert/csv_adsp.zip load the configurator and select the adsp-21061 that's it. Feel free to ask me any question. Have fun. Evert verduin gtekprog@hotmail.com This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●April 11, 20062006-04-11
Hello Does anybody still have these csv files required to run Ez-kit 21061 Lite under Visual DSP++ 4.0? I've become a happy owner of that board and i'm trying to use one. Thanks in advance. Best regards braton (braton[at]gmail[dot]com)
Reply by ●July 14, 20062006-07-14
>Hello > > Does anybody still have these csv files required to run Ez-kit 21061Lite>under Visual DSP++ 4.0? I've become a happy owner of that board and >i'm trying to use one. Thanks in advance. > > Best regards > braton (braton[at]gmail[dot]com) > > >I still have those! My IP was changed after i moved into a new house. The only thing is that my own machine is still packed in a cardboard box in the attick. I have no clue which out of the 50 boxes holds my computer ;-) I will send these as soon as possible. Regards, Evert Drop me a line to remember me: ebverduin(REMOVE FOR SPAM)wanadoo.nl replace (REMOVE FOR SPAM) by an @ sign
Reply by ●April 28, 20072007-04-28
Can anyone who posseses my zip file ( the ones who i send it to ) please drop me the zip file. As i lost it when my server died.. Tnx Evert>>Hello >> >> Does anybody still have these csv files required to run Ez-kit 21061 >Lite >>under Visual DSP++ 4.0? I've become a happy owner of that board and >>i'm trying to use one. Thanks in advance. >> >> Best regards >> braton (braton[at]gmail[dot]com) >> >> >> > >I still have those! >My IP was changed after i moved into a new house. The only thing is that >my own machine is still packed in a cardboard box in the attick. I haveno>clue which out of the 50 boxes holds my computer ;-) > >I will send these as soon as possible. > > >Regards, > >Evert > >Drop me a line to remember me: >ebverduin(REMOVE FOR SPAM)wanadoo.nl >replace (REMOVE FOR SPAM) by an @ sign > > >_____________________________________ Do you know a company who employs DSP engineers? Is it already listed at http://dsprelated.com/employers.php ?
Reply by ●July 1, 20072007-07-01
Found the csv files! ( 01-07-2007 ) You will need these if you want to get the 21061 Ezkit working with visualdsp 4.0 Drop me a message if you need those files! ebverduin(SP@MREMOVE)@wanadoo.nl ( remove the obvious )>Can anyone who posseses my zip file ( the ones who i send it to ) please >drop me the zip file. As i lost it when my server died.. > >Tnx > >Evert > > > > > > > > > > > > > >>>Hello >>> >>> Does anybody still have these csv files required to run Ez-kit 21061 >>Lite >>>under Visual DSP++ 4.0? I've become a happy owner of that board and >>>i'm trying to use one. Thanks in advance. >>> >>> Best regards >>> braton (braton[at]gmail[dot]com) >>> >>> >>> >> >>I still have those! >>My IP was changed after i moved into a new house. The only thing isthat>>my own machine is still packed in a cardboard box in the attick. I have >no >>clue which out of the 50 boxes holds my computer ;-) >> >>I will send these as soon as possible. >> >> >>Regards, >> >>Evert >> >>Drop me a line to remember me: >>ebverduin(REMOVE FOR SPAM)wanadoo.nl >>replace (REMOVE FOR SPAM) by an @ sign >> >> >> > > > >_____________________________________ >Do you know a company who employs DSP engineers? >Is it already listed at http://dsprelated.com/employers.php ? >
