Getting my program to load (Code Composer)
Started by Larry Martell February 18, 2005
Larry Martell wrote:
> Dan Mills wrote: > >>Larry Martell wrote: >> >> >>>I don't want to slow down any part of the system by doing this. I >>>am also timing some things on the P4 side too. Messages and data > > are > >>>being passed back and forth between the P4 and the DSP and if I > > stop > >>>and do some calculations it will skew the results. >> >> >>Humm, OK. >>Do you have a spare IO pin? set it high at the start of your time > > consuming > >>code then low at the end (probably one instruction each). >>Connect to simple RC lowpass filter and a meter and read off > > processor load > >>directly (or to a scope if you are looking for exact timing details)! > > > At had to smile at this because a EE I work with suggested the same > thing. > He suggested it to a room full of programmers ... we all looked at each > > other and smiled. And I said, "Well, that's a EE's solution ..." > > Thanks! > -larry
Those who restrict the domain of solutions they accept get fewer workable solutions. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> Larry Martell wrote: > > Dan Mills wrote: > > > >>Larry Martell wrote: > >> > >> > >>>I don't want to slow down any part of the system by doing this. I > >>>am also timing some things on the P4 side too. Messages and data > > > > are > > > >>>being passed back and forth between the P4 and the DSP and if I > > > > stop > > > >>>and do some calculations it will skew the results. > >> > >> > >>Humm, OK. > >>Do you have a spare IO pin? set it high at the start of your time > > > > consuming > > > >>code then low at the end (probably one instruction each). > >>Connect to simple RC lowpass filter and a meter and read off > > > > processor load > > > >>directly (or to a scope if you are looking for exact timing
details)!
> > > > > > At had to smile at this because a EE I work with suggested the same > > thing. > > He suggested it to a room full of programmers ... we all looked at
each
> > > > other and smiled. And I said, "Well, that's a EE's solution ..." > > > > Thanks! > > -larry > > Those who restrict the domain of solutions they accept get fewer > workable solutions.
I did not mean to imply this was a bad solution ... just a different one from what a software person would come up with -larry
> I did not mean to imply this was a bad solution ... just a different > one from what a software person would come up with
To continue a bit in snide mode: I thought that even software people did I/O. Now for philosopher mode: software amounts to instructions for hardware. While it may be possible to create instructions for for a structure that one doesn't fully understand -- some officers and executives do that -- knowing what one is really doing is usually very beneficial. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Jerry Avins wrote:
> Larry Martell wrote: > > ... > > > I did not mean to imply this was a bad solution ... just a
different
> > one from what a software person would come up with > > To continue a bit in snide mode: I thought that even software people
did
> I/O.
Of course software people do I/O. My point was that as a software person my initial thoughts do not usually involve lowpass filters, meters, and oscilloscopes. It's just like if you're sick and you go to a traditional western medical doctor then will give drugs, if you go to a surgon they will operate, and if you go to a native american shaman they will give you herbs.
hardware.
that
I agree it's extremely beneficial, but very often not possible. I've worked on many large software projects that for various reasons management activly prevented any one person from knowing the big picture or even how your piece was going to be used. I've also worked on software for extremely complicated systems that I would never have a hope of understanding. -larry
