Hi, If a frequency bin width is determined, then the symbol time is known. How many bins are acceptable, i.e. is there a restriction on the bandwidth of the OFDM symbol? Thanks,
Is there a restriction on OFDM bandwidth for a determined symbol time?
Started by ●October 30, 2015
Reply by ●October 30, 20152015-10-30
On Fri, 30 Oct 2015 08:15:49 -0700 (PDT), fl <rxjwg98@gmail.com> wrote:>Hi, > >If a frequency bin width is determined, then the symbol time is known. >How many bins are acceptable, i.e. is there a restriction on the bandwidth >of the OFDM symbol? > > >Thanks,Adding subcarriers increases N, the FFT size. As long as you can keep up with the processing and have the channel bandwidth available there's nothing stopping you from adding more subcarriers. Eric Jacobsen Anchor Hill Communications http://www.anchorhill.com
