Hello Does anyone manage to load code in external memory with CCS 1.2 ? (It works with the 2.2 version.) The error message is "Memory section is not writable! Aborting Load" Thank you
[CCS 1.2] code in external memory.
Started by ●March 24, 2005
Reply by ●March 24, 20052005-03-24
>Hello > >Does anyone manage to load code in external memory with CCS 1.2 ? >(It works with the 2.2 version.) > >The error message is "Memory section is not writable! Aborting Load" > >Thank you > >Which hardware? Whats ISA? Simulator? Whats the memory map of the device? Its hard to answer with that level of detailing, well its hard anyways, Its been sometime since I saw any one doing any thing with CCS1.2. well, from memory I think i used to address the external/internal memory(0x80000000+) of my c6211 dsk fine.. But i could be wrong...If you want me to reply with certainity I could re-install CCS1.2, try it next week and let you know. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
