Hi all !!! I am new to this field. I want to know in detail/brief that why we need to preprocess the speech signal. As i was going through the G.729 annex B . In which it is written that if u take the input speech then u have to preprocess it before doing the manipulation/encoding it. So why we need to do this. ??? We see that if we take the audio file. then the value is stored into the short int format. Now as in my case I have a 16 bit data. as an input. Now what i want to know that the how the values which is say like 26.89 or 74.54 etc are stored into the audio file..... as if we look the audio file then its all the integer...... now where are these datas of the fraction part....... please let me know about this Thanks in advance Ranjeet
preprocessing
Started by ●September 1, 2004
Reply by ●September 17, 20042004-09-17
ranjeet.gupta@gmail.com (ranjeet) wrote in message news:<77c88a3b.0409010055.2a1d43b4@posting.google.com>...> Hi all !!! > > I am new to this field. I want to know in detail/brief that why we > need to preprocess the speech signal. As i was going through the G.729 > annex B . In which it is written that if u take the input speech then > u have to preprocess it before doing the manipulation/encoding it. So > why we need to do this. ??? > > > We see that if we take the audio file. then the value is stored into > the short int format. Now as in my case I have a 16 bit data. as an > input. > > Now what i want to know that the how the values which is say like > 26.89 or 74.54 > etc are stored into the audio file..... as if we look the audio file > then its all the integer...... now where are these datas of the > fraction part....... > > please let me know about this > > Thanks in advance > RanjeetPreprocessing is done is to block the DC components(If any) in the signal. This prprocessing is nothing but a high pass filter with a cutoff near to 100Hz or so. Regarding representation of numbers they will be done using Q-format which is well known menthodology.
Reply by ●September 20, 20042004-09-20
Hi, you right about input format, output must be same, interim may be any. Only by end you'll do output value=(short)(interim value+0.5); You may trust to me nobody can to hear the harmony errors. cheers> We see that if we take the audio file. then the value is stored into > the short int format. Now as in my case I have a 16 bit data. as an > input. > Now what i want to know that the how the values which is say like > 26.89 or 74.54 > etc are stored into the audio file..... as if we look the audio file > then its all the integer...... now where are these datas of the > fraction part....... > > please let me know about this > > Thanks in advance > Ranjeet
