The answer is simpler than many did suggest. If you look for generator polynomials of many RS codes in literature they are given in direct form. But you also can modify these polynomials -- by applying additional multipliers in each branch. Say, first (MSByte) encoder's additional multiple is alpha, second one is alpha^2 and so on. Why they use this trick? I am not sure. But in my humble opinion is that this is done just to have some "proprietary" implementation. I encountered this problem ( decoder needs some modification too ;) ) when dealt with DVB-H/ISDB-T system. I guess this was true and for yours case.
Reed-Solomon example in 802.16 standard
Started by ●April 14, 2005
Reply by ●August 2, 20062006-08-02
