"Mark Borgerding" <markab@xetron.com> wrote in message news:413871c0$1@news.xetron.com...> Tom wrote: > > If you don't put in the (1-beta) part then you get an offset ie you haveto> > re-scale afterwards to get the right > > answer. > > On the contrary, it is impossible to get the right answer if you DO put > in the 1-beta part. > > ... if the question being answered is the one the original poster asked: > how to correlate two sequences using the fft. > > Or perhaps I am also guilty of assuming too much. Perhaps the OP > wanted the single-valued correlation : cov(x,y) / sqrt( var(x)*var(y) ) > But I don't think so. Covariance and variance operations are already > linear complexity. I can't see how FFTs would make them any faster. > I'm pretty sure the OP wanted cross-correlation when he asked for > correlation. > > There is a very specific definition for cross-correlation. > See http://mathworld.wolfram.com/Cross-Correlation.html > or http://cnx.rice.edu/content/m10686/latest/ > Notice the pure integration and infinite bounds. > > The formula you posted may have uses for continuous (open loop) > processing, but it is NOT cross-correlation. > > I can only assume the question for your "right answer" is "how do I get > a time-decaying approximation of cross-correlation". That question was > never asked. You made a good suggestion that was certainly topical, > considering more people read a thread than just the few persons writing > it. But the OP had signals "up to 45 seconds long", far from infinite. > > -- Mark > ]It is certainly Cross Correlation. In fact the method is more general (with modification) - I mentioned the Hannan-Thomson algorithm and the SCOT method for instance. In its simpler form it is just the Wiener-Kinchen theorem ie the Fourier Transform of cross-corr is power spectral density. The basic idea is found here http://www.paper.edu.cn/scholar/known/qiutianshuang/qiutianshuang-1.pdf though it is much older. You are confusing the pure integration in smoothing the cross-periodograms with the pure integration of getting a Cross-Corr (as you point out). The method I quoted is only to smooth the cross periodogram (PSD estimate).You don't need pure integration as this happens when you do an inverse FFT ie the Wiener Kinchen theorem again. In fact you don't need to smooth the cross-periodograms at all but you would get quite a noisy estimate. Also ordinary cross-corr whether you do it in the freq domain or the ordinary method has drawbacks with certain problems - particulalry estimating time-delays (or multple time-delays) and this is why generalised cross-corr is necessary. Hope this helps you to understand. Tom
Correlation using FFT
Started by ●August 28, 2004
Reply by ●September 4, 20042004-09-04
Reply by ●September 7, 20042004-09-07
Mark Borgerding wrote: ...> never asked. You made a good suggestion that was certainly > topical, considering more people read a thread than just the few > persons writing it. But the OP had signals "up to 45 seconds > long", far from infinite. > > -- MarkI'm one other reading the thread... maybe my contribution is far off the original goal of the OP. Just to satisfy my interest (and enhance my knowledge...), I would like to put in two more general questions: 1) given two such signals of 45 seconds, which are equal. now cut 5s from the beginning of the first and paste it to the end of it . then correlating this modified signal with the other unmodified. I reckon that the frequency content is the same except on the borders where the signal has been cut/pasted. Therefore I would expect similar FFT results and probably a high degree of correlation. My question: does correlation detect the shift of most of the signal and show good correlation? Or would the result be a low correlation because signal contents don't match at any point? 2) Given, I want to compare a signal (endless stream) with a certain pattern (short piece of signal). I expect that the signal contains pieces which are similar to the pattern, but differ either * in amplitude or * in width or * in both. Which method would be chosen to find the occurrences? Is cross-correlation the right approach? Or will it fail in one of the cases? Remember: it's not a current task which bothers me, it's only that I'm curious (maybe I'll need the answer soon, nevertheless ...) so it's enough to give me a direction. Bernhard
Reply by ●September 8, 20042004-09-08
Mark Borgerding wrote:>> 2) Given, I want to compare a signal (endless stream) with a >> certain pattern (short piece of signal). >> I expect that the signal contains pieces which are similar to the >> pattern, but differ either >> * in amplitude or >> * in width or >> * in both. >> Which method would be chosen to find the occurrences? >> Is cross-correlation the right approach? >> Or will it fail in one of the cases? > > This is close to case b) above. > > Caveat on "width": Cross-correlation will not "stretch" a pattern > to > find a match. If a feature is "stretched", while keeping its > shape, its frequency spectrum is shifted. > > Perhaps there is a cepstral technique that could accomplish this > task. >Thanks for taking the challenge. Measuring the correlation with such a normalized pattern will probably be a future task, so I'm really interested in any ideas. What I bear in mind to solve this task has grown from the wavelet theory, and your response reminds me of that: If I generate a series of related patterns which differ only in width (time), sort of correlation with every pattern should bring up a vector which gives me a "best fit" result. Instead of working with generic sine and/or cosine signals which would certainly lead to something like FFT, it seems as if this were more a task for wavelet transform, which uses short patterns. Currently, I have no idea which would be the best approach, not even, if the results would be acceptable for a real application, just looking around ... Bernhard
Bernhard Holzmayer wrote:> Mark Borgerding wrote: > I'm one other reading the thread... > maybe my contribution is far off the original goal of the OP.You raise some good points. Ones that should've been addressed early on. In hand-waving terms, cross-correlation can be applied to a) two short signals, b) one long + one short, or c) two long signals For the first two scenarios, it is feasible to compute the cross-correlation in its entirety. The last scenario is basically defined as one where it is impractical to calculate the entire CC sequence. The latter case is what I've been talking about. For a), you can transform both signals into the frequency domain by zero padded ffts (length >= N+M-1), then conjugate multiply their spectral components to affect cross-correlation in the time domain. Note cross-correlation is is just time-reverse, conjugate convolution. Also note multiplication in the freq domain <==> conv in time D. Also^2 note conjugate in the freq D is time reversal and conjugation in time D. To apply this idea back to the original poster: To cross-correlate two audio signals of 45s at 44kS/s, ( roughly 2e6 samples each), an FFT of 4e6 points would be needed. Probably feasible for the OP's purpose. I probably should've suggested this straightaway due to its simplicity. tic; nf = ng = 2e6; nfft=2^nextpow2(nf+ng-1); f=randn(nf,1); g=randn(ng,1); F=fft(f,nfft); G=fft(g,nfft); cc=ifft( F.*conj(G) ); % time-shifted cross-correlation toc It took less than 30s on my computer. Sorry rg. Anyway ... For b), you can extend the above solution to work in a buffer-by-buffer case by applying overlap-add or overlap-save filtering, with the shorter sequence reversed and conjugated. For case c), it is impractical to compute the entire non-zero cross-correlation sequence. It is easy to calculate only a range of delay(aka lag) values. This is where the matlab script I posted earlier comes into play. It performs blockwise computation of only those cross-correlation values of interest. It postpones the ifft until an answer is needed by exploting the identity f + g <==> F + G.> Just to satisfy my interest (and enhance my knowledge...), I would > like to put in two more general questions: > > 1) given two such signals of 45 seconds, which are equal. > now cut 5s from the beginning of the first and paste it to the > end of it . > then correlating this modified signal with the other unmodified. > I reckon that the frequency content is the same except on the > borders where the signal has been cut/pasted. > Therefore I would expect similar FFT results and probably a high > degree of correlation.Yes. In fact for this case, they two would vary only in phase, |F1| == |F2| There would be a linear phase shift in the frequency domain corresponding to the constant time shift in the time domain. (Think about linear phase(AKA constant group delay) FIR filters)> My question: does correlation detect the shift of most of the > signal and show good correlation? > Or would the result be a low correlation because signal contents > don't match at any point?The cross-correlation sequence would be large and positive at the lag where t = 5s The CC seq is maximized when the two sequences have matching spectral phase components that match (linear scaling of either only affects the magnitude, of the CC).> > 2) Given, I want to compare a signal (endless stream) with a certain > pattern (short piece of signal). > I expect that the signal contains pieces which are similar to the > pattern, but differ either > * in amplitude or > * in width or > * in both. > Which method would be chosen to find the occurrences? > Is cross-correlation the right approach? > Or will it fail in one of the cases?This is close to case b) above. Caveat on "width": Cross-correlation will not "stretch" a pattern to find a match. If a feature is "stretched", while keeping its shape, its frequency spectrum is shifted. Perhaps there is a cepstral technique that could accomplish this task.> > Remember: it's not a current task which bothers me, > it's only that I'm curious > (maybe I'll need the answer soon, nevertheless ...) > so it's enough to give me a direction. > > BernhardI hope I helped. -- Mark
