Dear all, I've created a SDM ( Sigma Delta Modulation) system. For the signal input, I used a 3000 Hz signal, but I need a 1500 Hz LPF (Low Pass Filter) with - 80 db / dekade slope for output signal after the signal being modulated and in demodulation process. my spec for SDM system: Input frequency 3000 Hz Output frequency 1500 Hz frequency sampling 25000 Hz If I used 3000 Hz LPF, the output signal become static and in bad condition. I've heard that SDM can push the noise to upper frequency. But why is it that I need a lower LPF for my SDM system? For the integrator, what voltage should I use for the reference voltage? Inside a book entitled "Feedback instrumental", the SDM block diagram is using a 2,5 volt for reference voltage for the integrator connected to the non-inverting pin amplifier. Why is it using me 2,5 volt for the references instead of 0 V or 5 V ? Thanks This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Delta-Sigma Modulator question
Started by ●April 26, 2005
Reply by ●April 26, 20052005-04-26
Victor K wrote:> Dear all, > I've created a SDM ( Sigma Delta Modulation) system. > For the signal input, I used a 3000 Hz signal, but I need a 1500 Hz LPF > (Low Pass Filter) with - 80 db / dekade slope for output signal after the > signal being modulated and in demodulation process. > my spec for SDM system: > Input frequency 3000 Hz > Output frequency 1500 Hz > frequency sampling 25000 Hz > If I used 3000 Hz LPF, the output signal become static and in bad > condition. I've heard that SDM can push the noise to upper frequency. But > why is it that I need a lower LPF for my SDM system?It reads a signal of one frequency and puts out a signal at double that? I don't understand.> For the integrator, what voltage should I use for the reference voltage? > Inside a book entitled "Feedback instrumental", the SDM block diagram is > using a 2,5 volt for reference voltage for the integrator connected to the > non-inverting pin amplifier. Why is it using me 2,5 volt for the references > instead of 0 V or 5 V ?In order for a circuit powered from a single supply to deal with bipolar signals, the signals must be offset. Half the supply voltage is a reasonable and common amount. Sometimes it's hard to distinguish between an offset voltage and a reference voltage. Often, it's merely a matter of viewpoint. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
