As you Know Matlab FFT function is built in. Anybody knows what algorithm has been implemented in it? I mean with details.
Matlab FFT function
Started by ●May 9, 2005
Reply by ●May 10, 20052005-05-10
in article 1115698065.510477.87350@z14g2000cwz.googlegroups.com, reseter at fangzheng1980@gmail.com wrote on 05/10/2005 00:07:> I think you can check any book about digital signal processing.but there are many ways of doing an FFT. even if you were to restrict it to powers of 2 (which isn't the case for MATLAB). i think the OP wants to know which particular one of those many methods that is intrinsic to MATLAB. it's probably a decimation-in-time or decimation-in-frequency algorithm. both have various rearrangements as can be seen in Oppenheim & Schafer. the other thing to point out is that the MATLAB FFT is off by 1 in its indices because they still just don't get it in Natick Mass. �help fft FFT Discrete Fourier transform. FFT(X) is the discrete Fourier transform (DFT) of vector X. If the length of X is a power of two, a fast radix-2 fast-Fourier transform algorithm is used. If the length of X is not a power of two, a slower non-power-of-two algorithm is employed. For matrices, the FFT operation is applied to each column. For N-D arrays, the FFT operation operates on the first non-singleton dimension. FFT(X,N) is the N-point FFT, padded with zeros if X has less than N points and truncated if it has more. FFT(X,[],DIM) or FFT(X,N,DIM) applies the FFT operation across the dimension DIM. For length N input vector x, the DFT is a length N vector X, with elements N X(k) = sum x(n)*exp(-j*2*pi*(k-1)*(n-1)/N), 1 <= k <= N. n=1 The inverse DFT (computed by IFFT) is given by N x(n) = (1/N) sum X(k)*exp( j*2*pi*(k-1)*(n-1)/N), 1 <= n <= N. k=1 The relationship between the DFT and the Fourier coefficients a and b in N/2 x(n) = a0 + sum a(k)*cos(2*pi*k*t(n)/(N*dt))+b(k)*sin(2*pi*k*t(n)/(N*dt)) k=1 is a0 = 2*X(1)/N, a(k) = 2*real(X(k+1))/N, b(k) = 2*imag(X(k+1))/N, where x is a length N discrete signal sampled at times t with spacing dt. See also IFFT, FFT2, IFFT2, FFTSHIFT. -- r b-j rbj@audioimagination.com "Imagination is more important than knowledge."
ALIMAR wrote:> As you Know Matlab FFT function is built in. > Anybody knows what algorithm has been implemented in it? > I mean with details.According to the rumour, matlab uses the FFTW library. Check out the documentation for the library to find details. Rune
Rune Allnor wrote:> > ALIMAR wrote: > > As you Know Matlab FFT function is built in. > > Anybody knows what algorithm has been implemented in it? > > I mean with details. > > According to the rumour, matlab uses the FFTW library.More than a rumor: http://www.mathworks.com/access/helpdesk/help/techdoc/ref/fftw.html If they do they must have licensed the right to do so from MIT: http://www.fftw.org/doc/License-and-Copyright.html Erik -- +-----------------------------------------------------------+ Erik de Castro Lopo nospam@mega-nerd.com (Yes it's valid) +-----------------------------------------------------------+ "The object-oriented model makes it easy to build up programs by accretion. What this often means, in practice, is that it provides a structured way to write spaghetti code." -- Paul Graham
