Hi, I'm wondering if anyone has any code (C?) or suggestions for decoding SMPTE timecode from an LTC audio track? Thanks, Steve
How to decode SMPTE timecode from LTC audio track?
Started by ●May 12, 2005
Reply by ●May 12, 20052005-05-12
Assuming the quality of the timecode is good and a constant speed, it's not too difficult. Do you need help acquiring the audio track (e.g. with a soundcard) or do you already have it and now need to decode it? Assuming the latter, you definitely want to take a look at the SMPTE format specification. I would start with converting the audio waveform into a 1-bit binary code, i.e. every sample becomes either a 0 or a 1. A fixed threshold might work for a very clean waveform, but you might need some hysteresis or smart edge detection (i.e. ignore transitions that happen to close together) if it's noisy. Next find the sync word and start reading in the bits based on the SMPTE spec. It's bi-phase, so that means there is a transition at the start of every bit, and if the data is a one, a second transition in the middle of the bit time. Assuming you are synced up, look for a transition, then find the next transition and see if it is 1 bit time or a half bit time offset from the previous. This is where the job is really easy if you have relatively constant speed timecode but quite difficult if it is variable (e.g. from an analog tape player that is speeding up/slowing down, aka varispeeding or scrubbing). Go to the next bit and repeat. Once you have all the bits, it's very easy to convert to an actual timecode value. You might want to throw in some "sanity checking" especially for noisy data, such as if you get one frame that is a wildly different value from the previous/next ones, ignore it and interpolate. Sorry I don't have code to give you. "stephenbuck" <stephenbuck@mac.com> wrote in message news:1115937709.250321.126410@f14g2000cwb.googlegroups.com...> Hi, > > I'm wondering if anyone has any code (C?) or suggestions for decoding > SMPTE timecode from an LTC audio track? > > Thanks, > Steve >
