"Al Clark" <dsp@danvillesignal.com> wrote in message news:Xns966097AD67874aclarkdanvillesignal@66.133.129.71...> "Jon Harris" <jon_harrisTIGER@hotmail.com> wrote in > news:1196uts4b5krfe6@corp.supernews.com: > > > "Richard Owlett" <rowlett@atlascomm.net> wrote in message > > news:1196sh38u0kgm10@corp.supernews.com... > >> Jerry Avins wrote: > >> > >> > Mark Borgerding wrote: > >> > > >> > ... > >> > > >> >> Bud: What's the difference between fixed-point and integer > >> >> processing? Lou: Just a bit. > >> >> Bud: But what exactly is the difference? > >> >> Lou: I told you -- just a bit. > >> >> Bud: Look here. Do you know how to do both types of processing? > >> >> Lou: Yes. > >> >> Bud: What do you do differently? > >> >> Lou: I halve the fixed-point product. > >> >> Bud: Sure. In the end everyone wants to have a product, but how do > >> >> you get there. > >> >> > >> > >> I'm a sucker. > >> I'll bite. > >> > >> What's the difference between fixed-point and integer? > >> > >> I suspect something subtle but significant. > > > > I'm not sure about the terminology used above, but in the many DSPs, a > > fixed-point number can be interpreted as either an integer or a > > fractional value. Assuming a signed 16-bit two's complement > > representation, the fraction interpretation of the bits means that the > > number is between -1 and +0.9999694. On the other hand with an integer > > interpretation, it is between -32768 and +32767. On the SHARC, when > > you multiply 2 fixed-point numbers together, you can specify for each > > number if it should be treated as integer or fractional. The > > difference is simply in the shifting of the result, but obviously it > > is quite significant to the answer! > > I'm not sure if Jon's explanation makes the difference clear: > > If you assume fixed point representation, you normally assume one sign > bit and N fractional bits. For example, the Sharc fractional format is > typically in 1.31. If the multiplier didn't do anything special, then > when you multiplied two 1.31 numbers you would get a result that was in > 2.62 format. There would be a redundant sign bit. This is automatically > adjusted for by the DSP by a bit shift of 1, so that the result is in > 1.63 format and therefore the fractional numbers are interpreted > correctly (you often round the result to 1.31 format at some point). > > Now if you reread Bud and Lou, you will get the joke.I didn't get the "halve" part the first time either, but now that you've explained it, I do! -Jon
Beginner: Integer FFT and Fixed Point FFT
Started by ●May 21, 2005
Reply by ●May 24, 20052005-05-24
"glen herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message news:m_mdnRGTIqACFQ7fRVn-uA@comcast.com...> Jon Harris wrote: > > (snip) > > > I'm not sure about the terminology used above, but in the many DSPs, a > > fixed-point number can be interpreted as either an integer or a fractional > > value. Assuming a signed 16-bit two's complement representation, thefraction> > interpretation of the bits means that the number is between -1 and+0.9999694.> > On the other hand with an integer interpretation, it is between -32768 and > > +32767. On the SHARC, when you multiply 2 fixed-point numbers together, youcan> > specify for each number if it should be treated as integer or fractional.The> > difference is simply in the shifting of the result, but obviously it isquite> > significant to the answer! > > The computer hardware, of course, doesn't know about the binary point at > all. <snip>On the SHARC at least, I think the hardware does "know about the binary point". Or at least you can tell it where the binary point is on the multiplicands, and it will give you the correct product based on that data. The low level multiply instructions can deal with 4 different types of data, each with a different binary point: unsigned integer, signed integer, unsigned fractional, signed fractional. But you are correct that the data in memory is just 32 bits, and what you make of them is up you as to the programmer.
Reply by ●May 25, 20052005-05-25
Al-->>> What's the difference between fixed-point and integer? >>> >>> I suspect something subtle but significant. >> >> I'm not sure about the terminology used above, but in the many DSPs, a >> fixed-point number can be interpreted as either an integer or a >> fractional value. Assuming a signed 16-bit two's complement >> representation, the fraction interpretation of the bits means that the >> number is between -1 and +0.9999694. On the other hand with an integer >> interpretation, it is between -32768 and +32767. On the SHARC, when >> you multiply 2 fixed-point numbers together, you can specify for each >> number if it should be treated as integer or fractional. The >> difference is simply in the shifting of the result, but obviously it >> is quite significant to the answer! >> >> >> > >I'm not sure if Jon's explanation makes the difference clear: > >If you assume fixed point representation, you normally assume one sign >bit and N fractional bits. For example, the Sharc fractional format is >typically in 1.31. If the multiplier didn't do anything special, then >when you multiplied two 1.31 numbers you would get a result that was in >2.62 format. There would be a redundant sign bit. This is automatically >adjusted for by the DSP by a bit shift of 1, so that the result is in >1.63 format and therefore the fractional numbers are interpreted >correctly (you often round the result to 1.31 format at some point).While you are not wrong in anything you said, just rephrase some of what you said in TI friendly language Now, am not sure if this a SHARC peculiarity, but in TI and I suspect elsewhere too, we always say Q0.31(where Q stands for the "Quantity of fractional bits) or Q31 but never 1.31, the reason being that a fixed point number is represented in m+n+1 number of bits where m->no of integer bits n->number of fractional bits and 1 *extra* sign bit(which also has a magnitude btw...) So, a Q0.31*Q0.31(fully fractional data) would result in a Q1.62, with one extra sign bit(which is sort of like a sign extension) but this aint a fully fractional number as the case was with the two inputs.And most likely one would want their output to be in the same *Q format* as the input many times and hence we need to condition the resulting Q1.62 number to become Q0.63 which is achieved by a simple left shift(loose out the *extra* sign bit but this also equal to multypliying the result by two, which is correct result in this case).This is achieved auto in many TI dsp's by simply using the appropriate fixed point multiply instruction.Ofcourse it is a different matter whether the processor will support 32 bit multiplication as was illustrated in this thread but something similar happens at the 16 bit level as well (Q15*Q15->Q1.30 left shifted by one bit, it results in Q0.31)... Finally, I have made some notes for my own personal reading and understanding on fixed point math.If someone needs it I can mail it across to you but folks please be forewarned there is nothing original or new about it, its just a collection of stuff I have read and assimilated at one place in an easier and friendly powerpoint format. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Glen-->The computer hardware, of course, doesn't know about the binary point at>all.Many high-level languages only provide an integer type and let >the user worry about anything else.The ANSI embedded C language(am not sure if the standard has alrady been published), as I understand , will incorporate support for fixed point formats, specifically for the use of DSP programmers along with support for various other embedded nuances, including support for a file called .b (which indicates "both").In this file one would be able to declare and define variables. For folks who have had to do work around on sharing a bunch of global variables across multiple files but needed to declare all of em at one place like a header file but could not do it because of multiple inclusion or multiple definition problems can now breathe a little easy...But may be not too soon, who is going to support embedded C standard? --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
bhooshaniyer wrote: (snip)> Now, am not sure if this a SHARC peculiarity, but in TI and I suspect > elsewhere too, we always say Q0.31(where Q stands for the "Quantity of > fractional bits) or Q31 but never 1.31, the reason being that a fixed > point number is represented in m+n+1 number of bits where m->no of integer > bits n->number of fractional bits and 1 *extra* sign bit(which also has a > magnitude btw...)(snip) I always like the PL/I notation better, which is FIXED BINARY(p,q) where p is the total number of bits, and q is the number after the binary point. q is allowed to be negative, too. And yes, for signed numbers the sign bit doesn't count. Q35.-4 looks very strange to me, but FIXED BINARY(31,-4) doesn't seem so strange. q can also be larger than p, so Q-4.35 would also be allowed, that is, FIXED BINARY(31,35) -- glen
"bhooshaniyer" <bhooshaniyer@gmail.com> wrote in news:P8CdnZZczL13kgnfRVn-3g@giganews.com:> Al-- > >>>> What's the difference between fixed-point and integer? >>>> >>>> I suspect something subtle but significant. >>> >>> I'm not sure about the terminology used above, but in the many DSPs, >>> a fixed-point number can be interpreted as either an integer or a >>> fractional value. Assuming a signed 16-bit two's complement >>> representation, the fraction interpretation of the bits means that >>> the number is between -1 and +0.9999694. On the other hand with an >>> integer interpretation, it is between -32768 and +32767. On the >>> SHARC, when you multiply 2 fixed-point numbers together, you can >>> specify for each number if it should be treated as integer or >>> fractional. The difference is simply in the shifting of the result, >>> but obviously it is quite significant to the answer! >>> >>> >>> >> >>I'm not sure if Jon's explanation makes the difference clear: >> >>If you assume fixed point representation, you normally assume one sign >>bit and N fractional bits. For example, the Sharc fractional format is >>typically in 1.31. If the multiplier didn't do anything special, then >>when you multiplied two 1.31 numbers you would get a result that was >>in 2.62 format. There would be a redundant sign bit. This is >>automatically adjusted for by the DSP by a bit shift of 1, so that the >>result is in 1.63 format and therefore the fractional numbers are >>interpreted correctly (you often round the result to 1.31 format at >>some point). > > While you are not wrong in anything you said, just rephrase some of > what you said in TI friendly languageThere is a TI friendly language? ;-) Q31 is the TI way of expressing 1.31 in ADI language. It means the same thing. I am a ADI partisan so I used an ADI example. I don't think Bud and Lou care either way. Al> > Now, am not sure if this a SHARC peculiarity, but in TI and I suspect > elsewhere too, we always say Q0.31(where Q stands for the "Quantity of > fractional bits) or Q31 but never 1.31, the reason being that a fixed > point number is represented in m+n+1 number of bits where m->no of > integer bits n->number of fractional bits and 1 *extra* sign bit(which > also has a magnitude btw...) > > So, a Q0.31*Q0.31(fully fractional data) would result in a Q1.62, with > one extra sign bit(which is sort of like a sign extension) but this > aint a fully fractional number as the case was with the two inputs.And > most likely one would want their output to be in the same *Q format* > as the input many times and hence we need to condition the resulting > Q1.62 number to become Q0.63 which is achieved by a simple left > shift(loose out the *extra* sign bit but this also equal to > multypliying the result by two, which is correct result in this > case).This is achieved auto in many TI dsp's by simply using the > appropriate fixed point multiply instruction.Ofcourse it is a > different matter whether the processor will support 32 bit > multiplication as was illustrated in this thread but something similar > happens at the 16 bit level as well (Q15*Q15->Q1.30 left shifted by > one bit, it results in Q0.31)... > > Finally, I have made some notes for my own personal reading and > understanding on fixed point math.If someone needs it I can mail it > across to you but folks please be forewarned there is nothing original > or new about it, its just a collection of stuff I have read and > assimilated at one place in an easier and friendly powerpoint format. > > --Bhooshan > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com-- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
Al-->> While you are not wrong in anything you said, just rephrase some of >> what you said in TI friendly language > >There is a TI friendly language? ;-)Even if not friendly there is definitely a TI peculiar language for sure and for most of us(With a TI market share of ~50% in programmable DSP market) who have been working a long time with TI DSP's the language ends up being friendly! :-)>Q31 is the TI way of expressing 1.31 in ADI language. It means the same >thing. I am a ADI partisan so I used an ADI example.Absoultely it means the same thing, no question there.I just wanted to help the *budding TI partisans* there...:-)>I don't think Bud and Lou care either way.Are they a distant relatives of Tom Engibous? If they are, they would sure care! :-) --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Jon Harris wrote: (snip)> On the SHARC at least, I think the hardware does "know about the binary point". > Or at least you can tell it where the binary point is on the multiplicands, and > it will give you the correct product based on that data. The low level multiply > instructions can deal with 4 different types of data, each with a different > binary point: unsigned integer, signed integer, unsigned fractional, signed > fractional. But you are correct that the data in memory is just 32 bits, and > what you make of them is up you as to the programmer.Well... A 32 bit multiply should generate a 64 bit product. So they supply instruction to generate the high and low half. But it is still only the relative position of the binary point that matters. The binary point of the product depends on the sum of the digits after the binary point of the numbers being multiplied, so only the sum needs to be known. For addition and subtraction the binary points must agree, but the hardware doesn't care which position it is, as long as they are both the same. -- glen
Al Clark wrote:>> If the multiplier didn't do anything special, then >>when you multiplied two 1.31 numbers you would get a result that was in >>2.62 format. There would be a redundant sign bit.[snip] bhooshaniyer wrote:> So, a Q0.31*Q0.31(fully fractional data) would result in a Q1.62, with one > extra sign bit(which is sort of like a sign extension)I was going to wait for Randy to jump in, but since he hasn't yet, I will. That "extra sign bit" is NOT extra. There is one case where the two msb's are not equal (and thus not redundant), and that's when you multiply -1 and -1 (or 0x8000000 and 0x8000000). The result is +1, aka 0x40000000:00000000 in 2.62. A fractional multiplier will automatically shift the result left one bit, which is fine for every combinaiton of inputs EXCEPT -1 times -1. In this case, it overflows, because +1 cannot be represented in 1.63 (or 1.31). -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 Nothing is ever so bad that it can't get worse. - Calvin
"The computer hardware, of course, doesn't know about the binary point at all. Many high-level languages only provide an integer type and let the user worry about anything else." And it seems, in my experience anyway, that all the other high level languages that provide hidden shifts/data types to help the user work with fixed point numbers just confuses everyone. As far as new hardware is concerned, looking at the results of couple of sample fixed point operations tells me immediatly if the microcode has any screwy "added fixed point features". "For multiply and divide hardware it is very useful to have a multiply that produces a double length product and divide that takes a double length dividend." Yes that hardware feature is key to preserve fixed point accuracy, always follow a fixed point mutliply with a fixed point divide and not the other way around. e.g., (32bit x 32 bit = 64bit)/ 32 bit
