When trying to load the program (in Microprocessor mode) I got the following message "Load Failed. A section of your program fails into a memory region that is not writable. Check your linker configuration and/or memory map." I've changed nothing, my code is the same as before and it has been working fine until now. Can someone help me ? Hardware : eZdsp LF2407A Software : C2xx code composer studio Sorry for my english Thanks
Code Composer Studio - Load Failed
Started by ●May 23, 2005
Reply by ●May 25, 20052005-05-25
I have the same error message with the tutorials included with Code Composer Studio. Maybe it's an hardware issue ? HELP PLEASE
>I've changed nothing,You have changed nothing from what?>my code is the same as beforeDefine *before* what code? who wrote it? for which platform?>and it has been >working fine until now.Who checked it?>Can someone help me ?I would like to help you but am not sure if you will understand what I would say.You need to probably read one tutorial or manual completely. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
Reply by ●May 27, 20052005-05-27
Hello bhooshaniyer, I've solved the problem, it was the .gel file for a reason I don't understand (because it has been working before with the same file). Regards
>Hello bhooshaniyer, > >I've solved the problem, it was the .gel file for a reason I don't >understand (because it has been working before with the same file). > >Regards >Thats good.Iam glad that you cud through the problem but beware of the magic wand.Problems dont dissapear out of good will. My sincere advice to you is: Understand how to program an embedded system and how does the tool chain work.You could possibly take the help of the Embedded Systems Book by David.E.Simon. --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
