ML sequences look perfectly white if the fft length matches the sequence length exactly. However, let's say that you make a ML sequence that repeats after an hour with fs=48khz, and you play the 1's and 0's through a speaker. You can't guarantee that 5 minutes of that 1 hour sequence won't sound like the "Star Wars" theme song, while still maintaining "perfect whiteness" when analyzed over the entire 1 hour sequence length. Bob
Looking for the whitest sequence of 1's and 0's
Started by ●July 6, 2016
Reply by ●July 7, 20162016-07-07
Michael Shonle <mike.shonle@gmail.com> wrote:>On Wednesday, July 6, 2016 at 4:59:50 PM UTC-4, Tim Wescott wrote:>> No, I'm not suddenly turning racist -- this is about signal processing. >> >> I want to fill a vector with binary numbers, evenly balanced between ones >> and zeros, such that (with the exception of the honkin' big spike at DC) >> its FFT is as flat as possible. >> >> Is there an algorithm for doing this? >> I'm looking for work -- see my website!>So cant' you just start from the frequency domain, fill a vector with >random phase and constant magnitude and take the inverse?You can, but the result would not be bipolar, it would be real-valued. Tim states "a vector filled with binary numbers". (I think he meant bipolar, or bi-valued, or whatever the correct terminology du jour is.) Steve
<lito844@gmail.com> wrote:>All M-sequences are spectrally flat (except for DC) as a consequence of >their correlation property, namely R(0)=1 and R(n)=1/N 0<n<N where R() >is the circular correlation of the bipolar M-sequence.Thanks. I am going to define "whiteness" as follows. Suppose a sequence is time-limited and also is non zero only at values N*T for integers N. This sequence is white if its Laplace transform is constant for all frequencies F where F = M*(1/T) for positive integers M. Now I need to go back and convince myself that M-sequences satisfy this. Steve
Reply by ●July 8, 20162016-07-08
On Thu, 07 Jul 2016 17:51:50 -0700, radams2000 wrote:> ML sequences look perfectly white if the fft length matches the sequence > length exactly. > However, let's say that you make a ML sequence that repeats after an > hour with fs=48khz, and you play the 1's and 0's through a speaker. You > can't guarantee that 5 minutes of that 1 hour sequence won't sound like > the "Star Wars" theme song, while still maintaining "perfect whiteness" > when analyzed over the entire 1 hour sequence length. > > BobCould you give me the polynomial for the sequence in question? I want to try it. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
On Fri, 8 Jul 2016 02:20:39 +0000 (UTC), spope33@speedymail.org (Steve Pope) wrote:>Michael Shonle <mike.shonle@gmail.com> wrote: > >>On Wednesday, July 6, 2016 at 4:59:50 PM UTC-4, Tim Wescott wrote: > >>> No, I'm not suddenly turning racist -- this is about signal processing. >>> >>> I want to fill a vector with binary numbers, evenly balanced between ones >>> and zeros, such that (with the exception of the honkin' big spike at DC) >>> its FFT is as flat as possible. >>> >>> Is there an algorithm for doing this? >>> I'm looking for work -- see my website! > >>So cant' you just start from the frequency domain, fill a vector with >>random phase and constant magnitude and take the inverse? > >You can, but the result would not be bipolar, it would be >real-valued.Only if it is symmetric about DC. This is easily avoidable. And real-valued and antipodal and not mutually exclusive.>Tim states "a vector filled with binary numbers". (I think he >meant bipolar, or bi-valued, or whatever the correct terminology >du jour is.) > >Steve
On Thu, 7 Jul 2016 17:51:50 -0700 (PDT), radams2000@gmail.com wrote:>ML sequences look perfectly white if the fft length matches the sequence le= >ngth exactly. =20 >However, let's say that you make a ML sequence that repeats after an hour w= >ith fs=3D48khz, and you play the 1's and 0's through a speaker. You can't g= >uarantee that 5 minutes of that 1 hour sequence won't sound like the "Star = >Wars" theme song, while still maintaining "perfect whiteness" when analyzed= > over the entire 1 hour sequence length.=20 > >BobAbsolutely. This is why the specs matter...it's relatively easy to make something "white" and "DC balanced" over a specific interval, but to make it also hold those properties simultaneously over other intervals gets harder.
On Fri, 08 Jul 2016 02:20:39 +0000, Steve Pope wrote:> Michael Shonle <mike.shonle@gmail.com> wrote: > >>On Wednesday, July 6, 2016 at 4:59:50 PM UTC-4, Tim Wescott wrote: > >>> No, I'm not suddenly turning racist -- this is about signal >>> processing. >>> >>> I want to fill a vector with binary numbers, evenly balanced between >>> ones and zeros, such that (with the exception of the honkin' big spike >>> at DC) its FFT is as flat as possible. >>> >>> Is there an algorithm for doing this? >>> I'm looking for work -- see my website! > >>So cant' you just start from the frequency domain, fill a vector with >>random phase and constant magnitude and take the inverse? > > You can, but the result would not be bipolar, it would be real-valued. > > Tim states "a vector filled with binary numbers". (I think he meant > bipolar, or bi-valued, or whatever the correct terminology du jour is.)That's correct. Bipolar but not in a medication-needing sort of way. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com I'm looking for work -- see my website!
On Thursday, July 7, 2016 at 8:51:54 PM UTC-4, radam...@gmail.com wrote:> ML sequences look perfectly white if the fft length matches the sequence length exactly. > However, let's say that you make a ML sequence that repeats after an hour with fs=48khz, and you play the 1's and 0's through a speaker. You can't guarantee that 5 minutes of that 1 hour sequence won't sound like the "Star Wars" theme song, while still maintaining "perfect whiteness" when analyzed over the entire 1 hour sequence length. > > BobHere's a quick empircal test to get a feel for the 'whiteness' of small segments of a larger M-sequence. The Matlab code below generates a length 2^22-1 (~4.2e6 samples) M-sequence as well as the same length sample of a normal distribution. For each block of 16k samples compare the circular correlation of each record. What I observe is that a segment of M-sequence looks very simiar to the same length segment of wgn in terms of correlation. An easy modification to quantify the difference is to compute a correlation 'SNR' such as the ratio of the max correlation to the next highest value. With such a metric the M-sequence loses about 2-3dB compared to wgn depending on block size. % Generator poly: x^22 + x^21 + 1 hpn=comm.PNSequence('Polynomial',[22 21 0],'SamplesPerFrame','2^22-1, ... 'InitialConditions',[zeros(1,21) 1]); x=(1-2*step(hpn)); n=randn(size(x)); block=2^14; count=0; m=count*block; while m+block<length(x) xx=cconv(x(m+1:m+block),x(m+block:-1:m+1),2*block); nn=cconv(n(m+1:m+block),n(m+block:-1:m+1),2*block); plot([xx nn]); title(sprintf('block %d',count)); disp('pause'); pause; count = count + 1; m = count * block; end;
In article <8f1a3db2-5bc3-4626-8e99-3e42aca6e7be@googlegroups.com>, <lito844@gmail.com> wrote:>On Thursday, July 7, 2016 at 8:51:54 PM UTC-4, radam...@gmail.com wrote: >> ML sequences look perfectly white if the fft length matches the >sequence length exactly. >> However, let's say that you make a ML sequence that repeats after an >hour with fs=48khz, and you play the 1's and 0's through a speaker. You >can't guarantee that 5 minutes of that 1 hour sequence won't sound like >the "Star Wars" theme song, while still maintaining "perfect whiteness" >when analyzed over the entire 1 hour sequence length. >> >> Bob > >Here's a quick empircal test to get a feel for the 'whiteness' of small >segments of a larger M-sequence. > >The Matlab code below generates a length 2^22-1 (~4.2e6 samples) >M-sequence as well as the same length sample of a normal distribution.How do you know this is an M-sequence? (Just wondering.) Steve
On Friday, July 8, 2016 at 11:00:50 AM UTC-4, Steve Pope wrote:> >M-sequence as well as the same length sample of a normal distribution. > > How do you know this is an M-sequence? (Just wondering.) > > SteveSource: Horowitz & Hill "The Art of Electronics" Cambridge University Press There's a chapter entitled Pseudo-Random Bit Sequences and Noise Generation which includes a table of taps (generator polynomials) for maximal length sequences. Chapter number varies depending on edition. For degree m polynomial some taps they provide are listed below: m n 3 2 4 3 5 3 6 5 7 6 9 5 10 7 11 9 15 14 17 14 18 11 20 17 21 19 22 21 23 18 25 22 28 25 29 27 31 28
