<eric.jacobsen@ieee.org> wrote:>On Tue, 14 Feb 2017 06:52:32 +0000 (UTC), spope33@speedymail.org>>I'm very unclear that it would not optimize past the first butterfly. >>They can also optimize across pipeline stages and also modify >>the number of bits of state and their logic values within a pipeline >>register.>The results of synthesizer optimization on something like an FFT will >depend a LOT on the architecture used. A highly parallel >architecture, or an architecture where the FFT stages are >independently pipelined, would likely benefit from optimization when >the imaginary inputs are static zeroes than a serial architecture >would.I agree. Sequential designs especially those that resemble a microcoded architecture will not optimize well. An FFT built around a single multiplier-accumulator would not optimize, OTOH it isn't very high gate-count to begin with. Steve
All-real FFT for FPGA
Started by ●February 12, 2017
Reply by ●February 14, 20172017-02-14
On 2/14/2017 11:39 AM, Steve Pope wrote:> Tim Wescott <tim@seemywebsite.com> wrote: > >> On Tue, 14 Feb 2017 06:52:32 +0000, Steve Pope wrote: > >>> If for example you compute (a * b) and also compute (a * -b), >>> the synthesizer is smart enough to know there are not two full >>> multipliers needed. > >> I would be very leery of an optimizer that felt free to optimize things >> so that they are no longer bit-exact -- > > Of course, synthesizers need to be bit-exact and conform to the > HDL language spec > >> and for some combinations of >> bits, I'm pretty sure that -(a * b) is not necessarily (a * -b). > > That is not the example I gave, but in either example you still would > not need two multipliers, just one multiplier and some small amount of > logic; any reasonable synthesizer would not use two multipliers > worth of gates.How is that not the example you gave? If the tool is going to use a single multiplier for calculating (a * b) and (a * -b), that implies it calculates (a * b) and then negates that to get (a * -b) as -(a * b), no? I don't know that -(a * b) wouldn't be exactly the same result as (a * -b). -- Rick C
Am 14.02.17 um 20:21 schrieb rickman:> I don't know that -(a * b) wouldn't be exactly the same result as (a * -b). >It is bitexact the same. In IEEE float, the sign is signalled by a single bit, it doesn't use two's complement or similar. Therefore, -x simply inverts the sign bit, and it doesnt matter if you do this before or after the multiplication. The only possible corner cases re special values like NaN and Inf; I believe that even then, the result is bitexact the same, but I'm too lazy to check the standard. Christian
On Tue, 14 Feb 2017 20:42:12 +0100, Christian Gollwitzer wrote:> Am 14.02.17 um 20:21 schrieb rickman: >> I don't know that -(a * b) wouldn't be exactly the same result as (a * >> -b). >> >> > It is bitexact the same. In IEEE float, the sign is signalled by a > single bit, it doesn't use two's complement or similar. Therefore, -x > simply inverts the sign bit, and it doesnt matter if you do this before > or after the multiplication. The only possible corner cases re special > values like NaN and Inf; I believe that even then, the result is > bitexact the same, but I'm too lazy to check the standard.While the use of floats in FPGAs is getting more and more common, I suspect that there are still loads of FFTs getting done in fixed-point. I would need to do some very tedious searching to know for sure, but I suspect that if there's truncation, potential rollover, or 2's compliment values of 'b1000...0 involved, then my condition may be violated. And I don't know how much an optimizer is going to analyze what's going on inside of a DSP block -- if you instantiate one in your design and feed it all zeros, is the optimizer smart enough to take it out? -- Tim Wescott Control systems, embedded software and circuit design I'm looking for work! See my website if you're interested http://www.wescottdesign.com
rickman <gnuarm@gmail.com> wrote:>On 2/14/2017 11:39 AM, Steve Pope wrote:>> Tim Wescott <tim@seemywebsite.com> wrote:>>> On Tue, 14 Feb 2017 06:52:32 +0000, Steve Pope wrote:>>>> If for example you compute (a * b) and also compute (a * -b), >>>> the synthesizer is smart enough to know there are not two full >>>> multipliers needed.>>> I would be very leery of an optimizer that felt free to optimize things >>> so that they are no longer bit-exact -->> Of course, synthesizers need to be bit-exact and conform to the >> HDL language spec>>> and for some combinations of >>> bits, I'm pretty sure that -(a * b) is not necessarily (a * -b).>> That is not the example I gave, but in either example you still would >> not need two multipliers, just one multiplier and some small amount of >> logic; any reasonable synthesizer would not use two multipliers >> worth of gates.>How is that not the example you gave? If the tool is going to use a >single multiplier for calculating (a * b) and (a * -b),Okay so far> that implies it calculates (a * b) and then negates that to get > (a * -b) as -(a * b), no?Not necessarily exactly this.>I don't know that -(a * b) wouldn't be exactly the same result as (a * >-b).You just answered your own question. Steve
On 2/14/2017 4:56 PM, Steve Pope wrote:> rickman <gnuarm@gmail.com> wrote: > >> On 2/14/2017 11:39 AM, Steve Pope wrote: > >>> Tim Wescott <tim@seemywebsite.com> wrote: > >>>> On Tue, 14 Feb 2017 06:52:32 +0000, Steve Pope wrote: > >>>>> If for example you compute (a * b) and also compute (a * -b), >>>>> the synthesizer is smart enough to know there are not two full >>>>> multipliers needed. > >>>> I would be very leery of an optimizer that felt free to optimize things >>>> so that they are no longer bit-exact -- > >>> Of course, synthesizers need to be bit-exact and conform to the >>> HDL language spec > >>>> and for some combinations of >>>> bits, I'm pretty sure that -(a * b) is not necessarily (a * -b). > >>> That is not the example I gave, but in either example you still would >>> not need two multipliers, just one multiplier and some small amount of >>> logic; any reasonable synthesizer would not use two multipliers >>> worth of gates. > >> How is that not the example you gave? If the tool is going to use a >> single multiplier for calculating (a * b) and (a * -b), > > Okay so far > >> that implies it calculates (a * b) and then negates that to get >> (a * -b) as -(a * b), no? > > Not necessarily exactly this.If not this, then what? Why are you being so coy?>> I don't know that -(a * b) wouldn't be exactly the same result as (a * >> -b). > > You just answered your own question.No, that's a separate question. In fact, as Chris pointed out the IEEE floating point format is sign magnitude. So it doesn't matter when you flip the sign bit, the rest of the number will be the same. For two's complement the only issue would be using the values of max negative int where there is no positive number with the same magnitude. But I can't construct a case were that would be a problem for this example. Still, if that is a problem for one combination, then there will be cases that fail for the other combination. Typically this is avoided by not using the max negative value regardless of the optimizations. -- Rick C
On 2/14/2017 3:22 PM, Tim Wescott wrote:> On Tue, 14 Feb 2017 20:42:12 +0100, Christian Gollwitzer wrote: > >> Am 14.02.17 um 20:21 schrieb rickman: >>> I don't know that -(a * b) wouldn't be exactly the same result as (a * >>> -b). >>> >>> >> It is bitexact the same. In IEEE float, the sign is signalled by a >> single bit, it doesn't use two's complement or similar. Therefore, -x >> simply inverts the sign bit, and it doesnt matter if you do this before >> or after the multiplication. The only possible corner cases re special >> values like NaN and Inf; I believe that even then, the result is >> bitexact the same, but I'm too lazy to check the standard. > > While the use of floats in FPGAs is getting more and more common, I > suspect that there are still loads of FFTs getting done in fixed-point. > > I would need to do some very tedious searching to know for sure, but I > suspect that if there's truncation, potential rollover, or 2's compliment > values of 'b1000...0 involved, then my condition may be violated. > > And I don't know how much an optimizer is going to analyze what's going > on inside of a DSP block -- if you instantiate one in your design and > feed it all zeros, is the optimizer smart enough to take it out?There is such a thing as "hard" IP which means a block of logic that is already mapped, placed and routed. But they are rare, but not subject to any optimizations. Otherwise yes, if you feed a constant into any block of logic synthesis will not only replace that logic with constants on the output, it will replace all the registers that may be used to improve the throughput of the constants. There are synthesis commands to avoid that, but otherwise the tool does as it sees optimal. The significant optimizations in an FFT come from recognizing all the redundant computations which the optimizer will *not* be able to see as they are dispersed across columns and rows or time. Logic optimizations are much more obvious and basic. Otherwise you could just feed the tool a DFT and let it work out the details. Heck, that might get you some significant savings. In a DFT done all at once, the tool might actually spot that you are multiplying a given input sample by the same coefficient multiple times. But that's still not an FFT which is much more subtle. -- Rick C
rickman <gnuarm@gmail.com> wrote:>On 2/14/2017 4:56 PM, Steve Pope wrote:>> rickman <gnuarm@gmail.com> wrote:>>> On 2/14/2017 11:39 AM, Steve Pope wrote:>>>> Tim Wescott <tim@seemywebsite.com> wrote:>>>>> On Tue, 14 Feb 2017 06:52:32 +0000, Steve Pope wrote:>>>>>> If for example you compute (a * b) and also compute (a * -b), >>>>>> the synthesizer is smart enough to know there are not two full >>>>>> multipliers needed.Note: I did not say that in an HDL, -(a * b) is equal in a bit-exact sense to (a * -b).>>>>> I'm pretty sure that -(a * b) is not necessarily (a * -b).We agree>>> If the tool is going to use a >>> single multiplier for calculating (a * b) and (a * -b),>> Okay so far>>> that implies it calculates (a * b) and then negates that to get >>> (a * -b) as -(a * b), no?>> Not necessarily exactly this.>If not this, then what? Why are you being so coy?Because one would have to look at the HDL language definition, the declared bit widths and declared data types and possibly other stuff. But you still wouldn't need two multpliers to compute the two values in my example; just one multiplier plus some other logic (much less than the gate count of a second multiplier) to take care of the extremal cases to make the output exactly match. Steve
On 2/14/2017 5:48 PM, Steve Pope wrote:> rickman <gnuarm@gmail.com> wrote: > >> On 2/14/2017 4:56 PM, Steve Pope wrote: > >>> rickman <gnuarm@gmail.com> wrote: > >>>> On 2/14/2017 11:39 AM, Steve Pope wrote: > >>>>> Tim Wescott <tim@seemywebsite.com> wrote: > >>>>>> On Tue, 14 Feb 2017 06:52:32 +0000, Steve Pope wrote: > >>>>>>> If for example you compute (a * b) and also compute (a * -b), >>>>>>> the synthesizer is smart enough to know there are not two full >>>>>>> multipliers needed. > > Note: I did not say that in an HDL, -(a * b) is equal in a bit-exact > sense to (a * -b). > >>>>>> I'm pretty sure that -(a * b) is not necessarily (a * -b). > > We agree > >>>> If the tool is going to use a >>>> single multiplier for calculating (a * b) and (a * -b), > >>> Okay so far > >>>> that implies it calculates (a * b) and then negates that to get >>>> (a * -b) as -(a * b), no? > >>> Not necessarily exactly this. > >> If not this, then what? Why are you being so coy? > > Because one would have to look at the HDL language definition, > the declared bit widths and declared data types and possibly other stuff. > > But you still wouldn't need two multpliers to compute the two > values in my example; just one multiplier plus some other logic > (much less than the gate count of a second multiplier) to take care of > the extremal cases to make the output exactly match.It was a *long* way around the woods to get here. I seriously doubt any logic synthesis tool is going to substitute two multipliers and an adder with a single multiplier and a bunch of other logic. Have you seen a tool that was that smart? If so, that is a pretty advanced tool. BTW, what *are* the extremal[sic] cases? -- Rick C
rickman <gnuarm@gmail.com> wrote:>On 2/14/2017 5:48 PM, Steve Pope wrote:>> But you still wouldn't need two multpliers to compute the two >> values in my example; just one multiplier plus some other logic >> (much less than the gate count of a second multiplier) to take care of >> the extremal cases to make the output exactly match.>It was a *long* way around the woods to get here. I seriously doubt any >logic synthesis tool is going to substitute two multipliers and an adder >with a single multiplier and a bunch of other logic.I very strongly disagree ... minimizing purely combinatorial logic is the _sine_qua_non_ of a synthesis tool. Lots of other things synthesizers try to do are more intricate and less predictable, but not this. Steve
