Question about Gaussian window and parabolic interpolation
Started by Michael Plet March 9, 2017
> >I forgot to say that I knew there was an inverse relationship between >the width of the window and the width of it's DFT. > >So intuitively I thought the best "a" would correspond to a certain >ratio of those two widths. > >Michael
Yep. My playing around seems to indicate that the best ratio is 1:1. I was not rigorous about testing this. Ced --------------------------------------- Posted through http://www.DSPRelated.com
On Sun, 12 Mar 2017 10:11:19 -0500, "Cedron" <103185@DSPRelated>
wrote:
>> >>Thanks. ( N-1)/2 is the midpoint of the sequence, so I am surprised >>that N/2 is better. E.g. if you have 8 numbers 0,...,7 the midpoint is >>3.5. >>So how does your window function look exactly? >> >>With the complex signals I testet I got exact results for a range of >>"a" values. >>But I am still curious about the real case. >> >>If I use a = 0.2 (instead of my constant 0.265...) I get these results >>for a real frequency: >> >>3 3,00853376764318 >>3,1 3,09972285705032 >>3,2 3,19535649624848 >>3,3 3,29522039607512 >>3,4 3,39729649299645 >>3,5 3,49933200116124 >>3,6 3,59993967651388 >>3,7 3,70027774300613 >>3,8 3,80035465470425 >> >>So even a small change in "a" make the results a lot worse. >> >>Michael > >You're welcome. For the frequency determination the (N-1) vs N isn't that >important. I am using a steady signal with a constant frequency, so >according to r b-j's equation I expect that the imaginary part of the >first and second differences should be zero. > >With all the quibbling we've had around here about the meaning of the word >"exact" it would be nicer if you said "numerically correct". Since the >formula is based on the assumption of a single complex tone your results >are what is expected. I haven't even started to test in the presence of >noise yet which may have a big impact on what "a" should be. > >The real case is a special case of two complex tones. Perhaps solving the >general case of two tones will give you a better answer for the specific >case. Anyway, I ran the 3.3 real signal case with your same other >parameters (other than the center) and got the results below. Changing >the center back to (N-1)/2 didn't change my frequency results much. > >It's strange that your results don't match mine. What phase value did you >use? > >Notice that the frequency determination at bin 6 is much more accurate >than the one at bin 3. This is due to the underlying parabola not being >as affected by the other parabola at the -3.3 (28.7) frequency. > >I also ran the test with a 8.3 frequency real signal, which being near N/4 >is about as far as you can separate the two tones, and the interference >becomes symmetric. The results with the best frequency read was at bin 8 >as expected. > >Ced > >================================ >Code for the Window Definition > > > theCenter = N / 2.0; > theParabolaA = -0.5 / ( a * a * theCenter * theCenter ); > > x = n - theCenter; > theWindow[n] = exp( theParabolaA * x * x ); > >============================ >Excerpted sample run > >Real 3.3 * 2Pi/N + Pi/4 > > N = 32 > > This run's a = 0.2000 > > Sigma Range is -5.0000 to 4.8438 > >parabola A_time = -0.0488 > > > k Windowed DFT Log of WDFT First Diff Second Diff >-- ---------------- ------------- ------------- ------------- > 0 0.0046 0.0000 -5.39 0.00 0.00 1.75 4.39 0.00 > 1 -0.0074 0.0404 -3.19 1.75 1.49 -0.71 -1.42 -4.92 > 2 0.0141 -0.0882 -2.42 -1.41 0.55 -0.01 -0.46 6.30 > 3 -0.0193 0.1216 -2.09 1.73 0.12 -0.00 -0.40 -6.28 > 4 0.0178 -0.1124 -2.17 -1.41 -0.28 -0.00 -0.40 6.28 > 5 -0.0111 0.0700 -2.65 1.73 -0.67 -0.00 -0.39 -6.28 > 6 0.0047 -0.0294 -3.52 -1.41 -1.07 -0.00 -0.39 6.28 > 7 -0.0013 0.0083 -4.78 1.73 -1.46 0.00 -0.39 -6.28 > 8 0.0003 -0.0016 -6.44 -1.41 -1.86 -0.00 -0.40 6.28 >.. >22 0.0000 0.0000 -10.93 1.41 2.67 -0.05 -0.44 -6.17 >23 -0.0000 -0.0002 -8.49 -1.73 2.25 0.00 -0.39 6.28 >24 0.0003 0.0016 -6.44 1.41 1.86 -0.00 -0.40 -6.28 >25 -0.0013 -0.0083 -4.78 -1.73 1.46 0.00 -0.39 6.28 >26 0.0047 0.0294 -3.52 1.41 1.07 -0.00 -0.39 -6.28 >27 -0.0111 -0.0700 -2.65 -1.73 0.67 -0.00 -0.39 6.28 >28 0.0178 0.1124 -2.17 1.41 0.28 -0.00 -0.40 -6.28 >29 -0.0193 -0.1216 -2.09 -1.73 -0.12 -0.00 -0.40 6.28 >30 0.0141 0.0882 -2.42 1.41 -0.55 -0.01 -0.46 -6.30 >31 -0.0074 -0.0404 -3.19 -1.75 -1.49 -0.71 -1.42 4.92 > > > k A B C Freq DFT Mag >-- -------- ------- ------- -------- ------- > 0 2.1948 0.0000 -5.3883 -0.000000 0.0046 > 1 -0.7084 2.9032 -5.3883 2.049062 0.0410 > 2 -0.2287 1.4639 -4.4288 3.201164 0.0893 > 3 -0.1996 1.3188 -4.2546 3.303126 0.1231 > 4 -0.1976 1.3043 -4.2298 3.301068 0.1138 > 5 -0.1974 1.3029 -4.2267 3.300124 0.0708 > 6 -0.1974 1.3029 -4.2266 3.300092 0.0297 > 7 -0.1974 1.3024 -4.2252 3.299528 0.0084 > 8 -0.1976 1.3056 -4.2370 3.304009 0.0016 >.. >22 -0.2219 12.4282 -176.9734 28.008722 0.0000 >23 -0.1956 11.2456 -163.6754 28.748935 0.0002 >24 -0.1976 11.3392 -164.7754 28.695991 0.0016 >25 -0.1974 11.3289 -164.6490 28.700472 0.0084 >26 -0.1974 11.3307 -164.6716 28.699908 0.0297 >27 -0.1974 11.3308 -164.6736 28.699876 0.0708 >28 -0.1976 11.3394 -164.7911 28.698932 0.1138 >29 -0.1996 11.4571 -166.4677 28.696874 0.1231 >30 -0.2287 13.1698 -191.7227 28.798836 0.0893 >31 -0.7084 42.4364 -637.9190 29.950938 0.0410 > > parabola product = 3.1593 > >--------------------------------------- >Posted through http://www.DSPRelated.com
My parameters: Amp = 1 Phase = PI / 4 My signal: Factor = 2 * PI * Freq / N Real(k) = Amp * Sin(Factor * k + Phase)
>Thanks. ( N-1)/2 is the midpoint of the sequence, so I am surprised >that N/2 is better. E.g. if you have 8 numbers 0,...,7 the midpoint is >3.5.
> >Michael
I am also surprised by the alternating nature of the bin values. I am going to try to do some theoretical work to figure out why. The difference equations I used compensate for this implicitly. A little quirk that is beneficial. ForwardDifference = f[k+1] - f[k] BackwardDifference = f[k] - f[k-1] FirstDifference = ( ForwardDifference + BackwardDifference ) / 2 SecondDifference = ForwardDifference - BackwardDifference Ced --------------------------------------- Posted through http://www.DSPRelated.com
> > >My parameters: > Amp = 1 > Phase = PI / 4 > >My signal: > Factor = 2 * PI * Freq / N > Real(k) = Amp * Sin(Factor * k + Phase)
Okay, I feel better about it now. I used Cos instead of Sin. Here is a run with Sin: k A B C Freq DFT Mag -- -------- ------- ------- -------- ------- 0 0.4373 -0.0000 -3.4467 0.000000 0.0318 1 0.0788 0.3585 -3.4467 -2.275141 0.0493 2 -0.1525 1.0523 -3.9093 3.450714 0.0894 3 -0.1823 1.2014 -4.0882 3.295220 0.1195 4 -0.1850 1.2203 -4.1205 3.298204 0.1109 5 -0.1852 1.2224 -4.1252 3.299720 0.0711 6 -0.1852 1.2226 -4.1258 3.299981 0.0315 7 -0.1852 1.2226 -4.1257 3.299912 0.0096 8 -0.1853 1.2230 -4.1274 3.300610 0.0020 9 -0.1850 1.2190 -4.1101 3.293867 0.0003 10 -0.1878 1.2708 -4.3559 3.384139 0.0000 The values match. Phew. I reset my center to N/2 and created a formula to find the expected A for the frequency parabola. It turns out that the frequency calculations on the bins where the calculated A matches the expected A give much better results. Perhaps this should be the criteria rather than the peak bin (in the noiseless case). Ced --------------------------------------- Posted through http://www.DSPRelated.com
Not any more. The Fourier transform works the same way forward and backward. So, if you multiply a signal with a complex tone you get a shift in the frequency domain. The reverse is if you multiply the frequency domain with a complex "tone" you get a shift in the time domain, aka a phase shift. Alternating positive and negative ones corresponds to a complex tone with a frequency of N/2. So here is another reason that the window should be centered at N/2. Ced --------------------------------------- Posted through http://www.DSPRelated.com
On Sunday, March 12, 2017 at 2:59:12 PM UTC-4, Cedron wrote:
> > > > > >I am also surprised by the alternating nature of the bin values. > > Not any more. The Fourier transform works the same way forward and > backward. So, if you multiply a signal with a complex tone you get a > shift in the frequency domain. The reverse is if you multiply the > frequency domain with a complex "tone" you get a shift in the time domain, > aka a phase shift. > > Alternating positive and negative ones corresponds to a complex tone with > a frequency of N/2. So here is another reason that the window should be > centered at N/2.
it's centering the window in the time domain at N/2 that causes the alternating of the signs after the FFT. this is why MATLAB has this function called fftshift(). r b-j
>On Sunday, March 12, 2017 at 2:59:12 PM UTC-4, Cedron wrote: >> > >> > >> >I am also surprised by the alternating nature of the bin values. >> >> Not any more. The Fourier transform works the same way forward and >> backward. So, if you multiply a signal with a complex tone you get a >> shift in the frequency domain. The reverse is if you multiply the >> frequency domain with a complex "tone" you get a shift in the time >domain, >> aka a phase shift. >> >> Alternating positive and negative ones corresponds to a complex tone
with
be
>> centered at N/2. > >it's centering the window in the time domain at N/2 that causes the >alternating of the signs after the FFT. this is why MATLAB has this >function called fftshift(). > >r b-j
Thanks, that's the "duh moment" I had yesterday, aka "No $#!^ Sherlock". I don't use MATLAB (or SciLab) so I had to look up the documentation: https://www.mathworks.com/help/matlab/ref/fftshift.html This is not the same thing. fftshift does a shift in the frequency domain, it has nothing to do with alternating the signs which corresponds to a shift in the time domain. You can find the same concept in Vicanek's two bin frequency paper where he calls it a "Centered DFT". When I coded it, I called it "Rotating the Bins" in the commentary. For the case of N/2, the rotations turn out to be ones with alternating signs making for a short cut implementation. For the case of (N-1)/2 you have to do a complex multiplication with the correct "tone" value for that bin. The rotations for two subsequent bins are almost 180 degrees apart, i.e. their ratio is nearly -1. What this means is that I have to alter my previous advice about centering the window. For even values of N the center should be at N/2 and for odd values the center should be at (N-1)/2. If you don't, after you apply the centering fix you get a 180 degree phase discontinuity in the circularity of your DFT. If you are only using the log of the magnitudes, this doesn't matter, but to me the whole point of using this type of window is for the frequency sweep and amplitude ramp estimation capability which depend on the imaginary part of the Log of the DFT. Ced N = 16 parabola Middle A = -0.1963 Middle a = 0.1995 This run's a = 0.1995 Sigma Range is -5.0133 to 4.6999 parabola A_time = -0.1963 expected A_freq = -0.1963 k Rotated WDFT Log of RWDFT First Diff Second Diff -- ---------------- ------------- ------------- ------------- 0 0.0046 -0.0291 -3.52 -1.41 1.30 0.00 -0.39 -0.00 1 0.0138 -0.0874 -2.42 -1.41 0.90 -0.00 -0.39 0.00 2 0.0281 -0.1772 -1.72 -1.41 0.51 0.00 -0.39 -0.00 3 0.0384 -0.2426 -1.40 -1.41 0.12 -0.00 -0.39 0.00 4 0.0355 -0.2243 -1.48 -1.41 -0.27 -0.00 -0.39 -0.00 5 0.0222 -0.1400 -1.95 -1.41 -0.67 0.00 -0.39 0.00 6 0.0093 -0.0590 -2.82 -1.41 -1.06 -0.00 -0.39 -0.00 7 0.0027 -0.0168 -4.07 -1.41 -1.45 0.00 -0.39 0.00 8 0.0005 -0.0032 -5.72 -1.41 -1.85 -0.00 -0.39 -0.00 9 0.0001 -0.0004 -7.77 -1.41 -2.24 0.00 -0.39 0.01 10 0.0000 -0.0000 -10.20 -1.41 -2.58 -0.04 -0.31 -0.08 11 0.0000 -0.0000 -12.93 -1.49 -0.81 0.01 3.85 0.17 12 0.0000 -0.0000 -11.82 -1.39 1.88 0.04 1.53 -0.12 13 0.0000 -0.0001 -9.18 -1.42 2.46 -0.01 -0.36 0.03 14 0.0002 -0.0010 -6.90 -1.41 2.08 0.00 -0.39 -0.00 15 0.0010 -0.0065 -5.02 -1.41 1.69 -0.00 -0.39 0.00 k A B C Freq WDFT Mag -- -------- ------- ------- -------- ------- 0 -0.1964 1.2959 -3.5245 3.299796 0.0295 1 -0.1963 1.2959 -3.5245 3.300040 0.0885 2 -0.1964 1.2959 -3.5245 3.299990 0.1794 3 -0.1963 1.2959 -3.5245 3.300002 0.2456 4 -0.1964 1.2959 -3.5246 3.300004 0.2271 5 -0.1963 1.2959 -3.5245 3.299980 0.1417 6 -0.1964 1.2960 -3.5248 3.300088 0.0597 7 -0.1963 1.2955 -3.5232 3.299475 0.0170 8 -0.1966 1.2990 -3.5362 3.304434 0.0033 9 -0.1942 1.2586 -3.3652 3.240889 0.0004 10 -0.1526 0.4686 0.3770 1.535379 0.0000 11 1.9237 -43.1328 228.7651 11.211127 0.0000 12 0.7647 -16.4769 75.7836 10.773327 0.0000 13 -0.1810 7.1653 -71.7438 19.795857 0.0001 14 -0.1970 7.5981 -74.6611 19.283604 0.0010 15 -0.1963 7.5768 -74.5068 19.301514 0.0066 parabola product = 3.1416 --------------------------------------- Posted through http://www.DSPRelated.com
On Sun, 12 Mar 2017 22:43:13 -0700 (PDT), robert bristow-johnson
>On Sunday, March 12, 2017 at 2:59:12 PM UTC-4, Cedron wrote: >> > >> > >> >I am also surprised by the alternating nature of the bin values. >> >> Not any more. The Fourier transform works the same way forward and >> backward. So, if you multiply a signal with a complex tone you get a >> shift in the frequency domain. The reverse is if you multiply the >> frequency domain with a complex "tone" you get a shift in the time domain, >> aka a phase shift. >> >> Alternating positive and negative ones corresponds to a complex tone with >> a frequency of N/2. So here is another reason that the window should be >> centered at N/2. > >it's centering the window in the time domain at N/2 that causes the alternating of the signs after the FFT. this is why MATLAB has this function called fftshift(). > >r b-j
fftshift just swaps the output halves of the FFT depending on whether you want DC in the middle or not. Many people used to call this and how it is used in algorithms (like fast convolution) "folding" the output or not. Naturally you can exploit some of the symmetry properties with this, too, like some alternating sign conditions with even or odd symmetry signals, etc. --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus
On Thu, 09 Mar 2017 23:58:56 +0100, Michael Plet <me@home.com> wrote:
>I have done some experiments with a Gaussian window applied to real >signals. The signals were pure sinusoids of a fixed frequency and >phase. > >I used this window: > >w(k) = e^( -(1/2) * (k - (N-1)/2)^2 / (a*(N-1)/2)^2 ) > >with N=32, k = 0, ..., N-1 and a = 0.265391249974779 > >I multiplied my signal with the window and did the DFT. >Then I calculated the magnitudes around the peak. >I took the natural logarithm of the magnitudes and did parabolic >interpolation to find the location of the true peak. >The results were almost exact. > >Now I have this question: >I found a = 0.265391249974779 by minimizing the MSE between the real >and the estimated frequency. >That value gave the most exact results. >I believe it is supposed to have something to do with std dev, but can >someone explain why this is the correct value to use? >And maybe give an analytical expression for the number. > >Michael
Michael, I got your email but can't respond due to "relaying not allowed", which appears to have something to do with your mail server. FWIW, though, yes, you have it right. I was going to add some info on tradeoffs, but they're not a big deal. Cheers, Eric --- This email has been checked for viruses by Avast antivirus software. https://www.avast.com/antivirus
On Wed, 15 Mar 2017 16:51:16 GMT, eric.jacobsen@ieee.org wrote:
>On Thu, 09 Mar 2017 23:58:56 +0100, Michael Plet <me@home.com> wrote: > >>I have done some experiments with a Gaussian window applied to real >>signals. The signals were pure sinusoids of a fixed frequency and >>phase. >> >>I used this window: >> >>w(k) = e^( -(1/2) * (k - (N-1)/2)^2 / (a*(N-1)/2)^2 ) >> >>with N=32, k = 0, ..., N-1 and a = 0.265391249974779 >> >>I multiplied my signal with the window and did the DFT. >>Then I calculated the magnitudes around the peak. >>I took the natural logarithm of the magnitudes and did parabolic >>interpolation to find the location of the true peak. >>The results were almost exact. >> >>Now I have this question: >>I found a = 0.265391249974779 by minimizing the MSE between the real >>and the estimated frequency. >>That value gave the most exact results. >>I believe it is supposed to have something to do with std dev, but can >>someone explain why this is the correct value to use? >>And maybe give an analytical expression for the number. >> >>Michael > >Michael, > >I got your email but can't respond due to "relaying not allowed", >which appears to have something to do with your mail server. > >FWIW, though, yes, you have it right. I was going to add some info >on tradeoffs, but they're not a big deal. > >Cheers, > >Eric > >--- >This email has been checked for viruses by Avast antivirus software. >https://www.avast.com/antivirus
Thank you for your quick answer Eric. I'm glad I got it right. "Relaying not allowed". That is strange. Thanks, Michael
