Hi My problem is related with the timer.c example presented in AD site for the ADSP 2189. ftp://ftp.analog.com/pub/www/technology/dsp/218x/codeExamples/timer.zip #include"signal.h" #include"misc.h" #include"sysreg.h" void Timer_ISR(); main() { interrupt(SIGTIMER,Timer_ISR); timer_set(0xFFFF,0xFFFF,0xFF); timer_on(); enable_interrupts(); while (1) { asm("idle;"); // Wait for interrupt } } void Timer_ISR(){ //printf("Timer interrupt is generated!\n"); //Printed on Simulator's asm("toggle fl1;"); } I compile and run and everything seems to be ok. But when i uncomment the printf in the interrupt routine of the timer, the printf doesn t appear in the console. I putted some printfs in other places of the main program and it prints them but it takes to long like 30 to 40 seconds for printf, and if i put any printf after the intruction in the while(1)>>asm("idle;");<< it doesn �t gets printed on the console and when ipush F10 the program does not step just keeps halted on the printf. what might be the problem ?? best regards
Visual DSP ++ problem
Started by ●June 8, 2005
Reply by ●June 8, 20052005-06-08
"luis soares" <lmbpsoares@gmail.com> wrote in message news:8f1100bb.0506080942.911960d@posting.google.com...> Hi > > My problem is related with the timer.c example presented in AD site > for the ADSP 2189. > > ftp://ftp.analog.com/pub/www/technology/dsp/218x/codeExamples/timer.zip > > #include"signal.h" > #include"misc.h" > #include"sysreg.h" > > void Timer_ISR(); > main() > { > interrupt(SIGTIMER,Timer_ISR); > timer_set(0xFFFF,0xFFFF,0xFF); > timer_on(); > enable_interrupts(); > > while (1) > { > asm("idle;"); // Wait for interrupt > } > } > void Timer_ISR(){ > //printf("Timer interrupt is generated!\n"); //Printed on > Simulator's > asm("toggle fl1;"); > } > > > I compile and run and everything seems to be ok. But when i uncomment > the printf in the interrupt routine of the timer, the printf doesn t > appear in the console. > > I putted some printfs in other places of the main program and it > prints them but it takes to long like 30 to 40 seconds for printf, and > if i put any printf after the intruction in the while(1) > >>asm("idle;");<< it doesn �t gets printed on the console and when i > push F10 the program does not step just keeps halted on the printf. > > what might be the problem ??Try including <stdio.h> and rebuilding your project. Cheers Bhaskar> > best regards
Hi The problem seems to be in the printfs if when an interrupt occurs the visual DSP is in the middle of writting to the console and then another write occurs, there will be problems. But if this doesn t write it all goes well best regards luis
Reply by ●June 9, 20052005-06-09
luis soares wrote:> Hi > > The problem seems to be in the printfs if when an interrupt occurs the > visual DSP is in the middle of writting to the console and then > another write occurs, there will be problems. > > But if this doesn t write it all goes well > > best regards > > luisYou have to use some build option that it cant interrupt in the middle of writing.
