Hi, I'm looking for a DSP board with TMS320C64xx or c67xx. I need a board with small footprint. I need an access to the HPI , all McBSP ports , GPIO and external interrupts pins and MAC (TCP/IP). Thanks for helping Pini PS I want to connect the DSP HPI to an A2D converter. Can I use a flat cable (15-50cm) with a BUS transfer rate of 5-10Mhz. Should I use a line driver (LVDS)?
Small footprint DSP
Started by ●June 18, 2005
Reply by ●June 19, 20052005-06-19
Pini-->I'm looking for a DSP board with TMS320C64xx or c67xx. >I need a board with small footprint.May be I dont understand what you mean by "board with small foot print" or may be I dont understand this lingo? Can you please elloborate on what is it you infer by "board with a small foot print"? I would normally associate that language with one's own software implementation's performance rather than of that of a cold, unintelligent hardware board... --Bhooshan This message was sent using the Comp.DSP web interface on www.DSPRelated.com
bhooshaniyer wrote:> Pini-- > >I'm looking for a DSP board with TMS320C64xx or c67xx. > >I need a board with small footprint. > > May be I dont understand what you mean by "board with small foot print" or > may be I dont understand this lingo? Can you please elloborate on what is > it you infer by "board with a small foot print"? >> I would normally associate that language with one's own software > implementation's performance rather than of that of a cold, unintelligent > hardware board... >hi, I'm looking for a small size DSP board.> --Bhooshan > > This message was sent using the Comp.DSP web interface on > www.DSPRelated.com
"pinit" <pinit_bgu@yahoo.com> wrote in news:1119122222.435536.240870 @g47g2000cwa.googlegroups.com:> Hi, > I'm looking for a DSP board with TMS320C64xx or c67xx. > I need a board with small footprint. > I need an access to the HPI , all McBSP ports , GPIO and external > interrupts pins and MAC (TCP/IP). > > > Thanks for helping > > Pini > > > > PS > I want to connect the DSP HPI to an A2D converter. Can I use a flat > cable (15-50cm) with a BUS transfer rate of 5-10Mhz. Should I use a > line driver (LVDS)? >If you are not fixed on TI. we have 60mm x 60mm DSP boards based on SHARC. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
pinit wrote:> Do u have a TigerShark board? I need MIPS ....You might want to check out the DSM-STSL card from Kaztek Engineering http://www.kaztek.com/dsm.htm It includes a TS201 and a Spartan 3 FPGA for lots of custom I/O on a 54 x 100 mm card. -- Dave Tweed
Reply by ●June 20, 20052005-06-20
"pinit" <pinit_bgu@yahoo.com> wrote in news:1119209605.470724.12340 @g47g2000cwa.googlegroups.com:> Do u have a TigerShark board? I need MIPS .... >We do not have a TigerSHARC board. You mentioned the C67xx in your original post which is not faster than the third generation SHARCs. Some of our dspbloks have a companion FPGA which can be used for algorithm acceleration. I would be happy to discuss your specific requirements to see what might be possible. -- Al Clark Danville Signal Processing, Inc. -------------------------------------------------------------------- Purveyors of Fine DSP Hardware and other Cool Stuff Available at http://www.danvillesignal.com
