Hi. I've a problem with Interrupt Service Routines and Analog Devices DSP 21364. I've written an ISR that moves a sample from an input stream into a circular buffer, and it's triggered at a fixed rate. When I execute some code (while ISR is filling a buffer) like this (it's a Finite Impulse Response Filter part): lcntr = r2, do (pc,loopend_fir-1) until lce; f8 = f3*f4, f13 = f8+f13, f4 = dm(i2,m1), f3 = pm(i8,m9); loopend_fir: f13=f8+f13, f4 = dm(i2,-2); it gives me (along a 2048 pts buffer) some wrong results, while if I disable interrupts before calculus and I enable them after, all goes right. Only code is affected, ISR deploys samples regularly. I've ensured that ISR is executed in a transparent way (AFAIK). The same errors occur in other points of my code. It looks like it has a random behaviour, but it produces the same results at each try. How can I solve this issue, without enabling/disabling INTs along my code?? This is only VisualDSP simulation behaviour, but I'll try to ensure a good result before downloading code on EZ-KIT. Thank you very much for your support. (Btw, I've used ADSP-21262 before, and it works correctly even with INTs enabled).
ADSP-21364
Started by ●June 19, 2005
Reply by ●June 20, 20052005-06-20
Hi, Are you sure that your ISR is not being re-called while within the processing of a previous entry into the ISR? Maybe interrupt nesting is enabled, and the ISR is being triggered faster than it is being attended + processed. Regards, JaaC
Reply by ●June 21, 20052005-06-21
Jaime Andr�s Aranguren Cardona wrote:> Hi, > > Did you read the anomaly list for your silicon version? > > JaaC >Thank you very much for your answers. Analog has just written me, saying that there's an hardware bug in ADSP-21364, they asked me to send them my code so they can troubleshoot it, and can report a valid solution (in the meanwhile, disabling/enabling interrupt can be applied). :-(
Reply by ●June 23, 20052005-06-23
Hi, Those are good news... It would be nice from your part to let us know what ADI tells you. Regards, -- ------------------------------ Jaime Andr�s Aranguren Cardona jaac@sanjaac.com SanJaaC Electronics Soluciones en DSP www.sanjaac.com "Tony" <none@none.it> escribi� en el mensaje news:qDQte.24413$b5.1164403@news3.tin.it...> Jaime Andr�s Aranguren Cardona wrote: >> Hi, >> >> Did you read the anomaly list for your silicon version? >> >> JaaC >> > > Thank you very much for your answers. > > Analog has just written me, saying that there's an hardware bug in > ADSP-21364, they asked me to send them my code so they can troubleshoot > it, and can report a valid solution (in the meanwhile, disabling/enabling > interrupt can be applied). > > :-( >
