rand() on the ADSP21056l boards
Started by Toby Newman August 17, 2004
I'm using Analog Devices' SHARC ADSP21065l board.
My bundled VisualDSP++ documentation states:
"The rand function returns a pseudo-random integer value in the range
[0, 2^32 =3F 1]."
2^32 = 4294967296.
After running the below code for about an hour I ended up with
j = 2147483647
i.e. j was equal to exactly half of 4294967296
i.e. exactly half of (2^32 -1)
#include <stdlib.h> //allow rand() function
int main(void)
    int i;
    int j = 1;
    while(1)
        i = rand();
        if (i>j)
            j = i;
How come rand() isn't behaving as it is described to in the
documentation?
Toby
"Toby Newman" <google@asktoby.com> wrote in message
news:MPG.1b8c3327b8545dd1989933@localhost...
> > I'm using Analog Devices' SHARC ADSP21065l board. > My bundled VisualDSP++ documentation states: > > "The rand function returns a pseudo-random integer value in the range > [0, 2^32 =3F 1]." > > 2^32 = 4294967296. > > After running the below code for about an hour I ended up with > j = 2147483647 > i.e. j was equal to exactly half of 4294967296 > i.e. exactly half of (2^32 -1)
Well...you've declared j as an integer (not unsigned integer). An integer requires a sign bit and eats up 1 of the 32 bits. So you couldn't possibly store 2^32 in that variable. My VDSP++3.0 documentation for rand() says that it returns an integer value in the range [0, 2^32-1]. So you can blame it on the documentation I guess. Cheers Bhaskar
> > //========================================= > #include <stdlib.h> //allow rand() function > int main(void) > { > int i; > int j = 1; > while(1) > { > i = rand(); > if (i>j) > { > j = i; > } > } > } > //========================================= > > How come rand() isn't behaving as it is described to in the > documentation? > > -- > Toby
