>I'm told that the Numerical Recipes in >> (FORTRAN,C,...) books have an implementation. > >Yes. NR has a section on spectral analysis on unevenly sampled data. >goto http://www.nr.com for a free copy of the book. > >if the sample is not that non-uniform you can pad with zeros..you can >check more on how exactly this can be done in the book >http://www.dspguide.com > >--Ramoj Paruchuri >*************************************************************************** Hello to all, Dear thanks for the nice tip, but i have another problem which is that there is always a wideband noise whenever we try to perform spectral analysis of a non uniformly sampled signal. Do you have some solution to this problem? Waiting for the reply. This message was sent using the Comp.DSP web interface on www.DSPRelated.com
How to do non-uniform (sampling) DFT?
Started by ●August 15, 2004
Reply by ●February 28, 20052005-02-28
