Hi all, Can anybody point me to some helps/tutorials/references/stories on how to do non-uniform (sampling) DFT? Thank you very much for your help, -Walala
How to do non-uniform (sampling) DFT?
Started by ●August 15, 2004
Reply by ●August 15, 20042004-08-15
walala wrote:> Hi all, > > Can anybody point me to some helps/tutorials/references/stories on how > to do non-uniform (sampling) DFT? > > Thank you very much for your help, > > -WalalaHere is a good source: Technique for frequency analysis of unevenly sampled radar data House, M.G. Mountcastle, P.D. XonTech Inc., Huntington Beach, CA, USA This paper appears in: Radar Conference, 2002. Proceedings of the IEEE Publication Date: 22-25 April 2002 On page(s): 63 - 67 ISSN: 1097-5659 Number of Pages: xix+508 Inspec Accession Number: 7366627 Abstract: A new technique is described that generalizes the usefulness of the discrete Fourier transform for spectral analysis of radar data to applications where the discrete data points to be analyzed are not sampled at regular intervals and/or do not have equal statistical weight. This method finds a frequency-domain representation which best represents the given time-domain data in the least-square-residual sense. The theoretical implications of such an approach are discussed, and an example of the technique applied to a Doppler processing task is given. The merits of the approach relative to other spectral analysis techniques are discussed. Good luck, OUP
In article <6f348bd1.0408151717.3bd80eda@posting.google.com>, walala <mizhael@yahoo.com> wrote:>Can anybody point me to some helps/tutorials/references/stories on how >to do non-uniform (sampling) DFT?I assume you mean something like this: There is a function f(t), assumed to be periodic with period (for convenience) 2 pi, and at some more-or-less arbitrary N points t_1,...,t_N you know f(t_k) = y_k. You want to (approximately) calculate the Fourier series coefficients c_k such that f(t) = sum_k c_k exp(ikt). Well, one thing you can do is assume only N coefficients count, e.g. f(t) = sum_{k=a}^b c_k exp(ikt) where a=-(N-1)/2,b=(N-1)/2 if N is odd, or perhaps a=-N/2+1,b=N/2 if N is even, and solve the N x N system of equations y_j = sum_{k=a}^b exp(ik t_j) c_k But this is really equivalent to a Lagrange interpolation problem: y_j exp(-ia t_j) = sum_{k=0}^{N-1} exp(ik t_j) c_{k+a} = P(exp(i t_j)) where P(z) = sum_{k=0}^{N-1} c_{k+a} z^k. One way of solving the Lagrange problem is this: if w(z) = product_{j=1}^N (z - exp(i t_j)) then P(z) = sum_{j=1}^n y_j exp(-ia t_j) product_{k <> j} (z - exp(i t_k))/(exp(i t_j) - exp(i t_k)) In particular the solution is unique as long as the t_j are distinct mod 2 pi. I make no claims about numerical stability. Robert Israel israel@math.ubc.ca Department of Mathematics http://www.math.ubc.ca/~israel University of British Columbia Vancouver, BC, Canada V6T 1Z2
Reply by ●August 16, 20042004-08-16
You could try Googling for the Lomb-Scargle Periodogram method. It works with unevenly sampled data. I believe it is used in the astrophysics community. I'm told that the Numerical Recipes in (FORTRAN,C,...) books have an implementation. I've never tried using it, but filed the reference away, just in case. Let me know how you get on. Jon mizhael@yahoo.com (walala) wrote in message news:<6f348bd1.0408151717.3bd80eda@posting.google.com>...> Hi all, > > Can anybody point me to some helps/tutorials/references/stories on how > to do non-uniform (sampling) DFT? > > Thank you very much for your help, > > -Walala
>Subject: How to do non-uniform (sampling) DFT? >From: mizhael@yahoo.com (walala) >Date: 8/15/2004 9:17 PM Eastern Daylight Time >Message-id: <6f348bd1.0408151717.3bd80eda@posting.google.com> > >Hi all, > >Can anybody point me to some helps/tutorials/references/stories on how >to do non-uniform (sampling) DFT? > >Thank you very much for your help, > >-Walala > > > > > >Try the following paper: Duijndam A. J. W. and Schonewille M. A., Nonuniform fast Fourier transform, Geophysics, Vol 64, No 2 (March-April 1999), pages 539-551. I have not actual reviewed the article in-depth, so it may not be of any help. Scott
Reply by ●August 17, 20042004-08-17
I'm told that the Numerical Recipes in> (FORTRAN,C,...) books have an implementation.Yes. NR has a section on spectral analysis on unevenly sampled data. goto http://www.nr.com for a free copy of the book. if the sample is not that non-uniform you can pad with zeros..you can check more on how exactly this can be done in the book http://www.dspguide.com --Ramoj Paruchuri
Reply by ●August 18, 20042004-08-18
"walala" <mizhael@yahoo.com> wrote in message news:6f348bd1.0408151717.3bd80eda@posting.google.com...> Hi all, > > Can anybody point me to some helps/tutorials/references/stories on how > to do non-uniform (sampling) DFT? > > Thank you very much for your help, > > -WalalaThis might help. function X=dft(t,x,f) % function X=dft(t,x,f) % Compute DFT (Discrete Fourier Transform) at frequencies given % in f, given samples x taken at times t: % X(f) = sum { x(k) * e**(2*pi*j*t(k)*f) } % k shape = size(f); t = t(:); % Format 't' into a column vector x = x(:); % Format 'x' into a column vector f = f(:); % Format 'f' into a column vector % It's just this simple: W = exp(-2*pi*j * f*t'); X = W * x; X = reshape(X,shape); -Aj
