"Jane" <lunaliu3@yahoo.com> wrote in message news:dc1o5i$10k$1@news.Stanford.EDU...> Hi, > > Does anybody have the fastest method (using paper and pencil) to calculate > the convolution: > > y[n]=x[n]*h[n] > > where x[n]=u[n-3] - u[n-14], h[n]=u[n-5] - u[n-8], where u[n] is the step > function, u[n]=1 for n>=0, and u[n]=0 for n<0. > > Can you do it in 2 minutes?Easily. I did it in just over 1 minute. Here's how: I drew a "cartoon" of both functions to set the specifications. Then I went and got a timer. Set the timer and started: I realized that one of them has to be reversed before "sliding", so I drew another cartoon of it. Then I noted that 8 seconds had to pass before the first overlap and put a sample at 8 seconds. I continued figuring out where the next overlap would be in time and put a new sample at that point. It was easier because only one pair of samples coincided at the same time. It was easier because no samples had other than unity weight. All you have to do is figure out when the samples coincide - which is very simple to visualize. When I was done the clock had gone 1 minute and 5 seconds. There was no temporal scaling except to label the times of the samples. It was easy to do the simple arithmetic in my head and drawing scaled cartoons wasn't necessary. If it had been more complex then perhaps scaled drawings (in time) would have been helpful - assuming no computer. So, I think that visualization with a little help from the pencil and paper is the fastest method. Fred
fastest convolution
Started by ●July 25, 2005
Reply by ●July 25, 20052005-07-25
Reply by ●July 26, 20052005-07-26
"Jes�s Cid-Sueiro" <jcid@ing.uc3m.es> wrote in message news:dc2mq3$3o5$1@khitai.uc3m.es...> Noting that u[n]*u[n] = n u[n] =r[n] (which is a ramp with slope 1), > > y[n] = r[n-8] - r[n-11] - r[n-19] + r[n-22] > > which is a ramp starting at 8, becoming horizontal at 11, decreasing with > slope 1 at 19 and zero starting from 22. > > J. >Wow, this is the fastest method... !!! Yet just a small problem: when you say it starts at 8, you mean y[8]=0 or y[8]=1? Formal computation shows that y[8] should be 1, am I right? And also y[20]=1, y[21]=y[22]=... =0... So your result should be shifted a little bit to make it correct?
Jane wrote:> "Jes�s Cid-Sueiro" <jcid@ing.uc3m.es> wrote in message > news:dc2mq3$3o5$1@khitai.uc3m.es... > >>Noting that u[n]*u[n] = n u[n] =r[n] (which is a ramp with slope 1), >> >>y[n] = r[n-8] - r[n-11] - r[n-19] + r[n-22] >> >>which is a ramp starting at 8, becoming horizontal at 11, decreasing with >>slope 1 at 19 and zero starting from 22. >> >>J. >> > > > Wow, this is the fastest method... !!! Yet just a small problem: when you > say it starts at 8, you mean y[8]=0 or y[8]=1? > > Formal computation shows that y[8] should be 1, am I right? And also > y[20]=1, y[21]=y[22]=... =0... > > So your result should be shifted a little bit to make it correct?You are right... I should have started with... "Noting that u[n]*u[n] = (n+1)*u[n] = r[n] ..."
Reply by ●August 3, 20052005-08-03
Convolution is similar to long-multiplication which we learnt in school... so for ease of understanding, take signals 101 and 11 where both start from origin. now reverse 11. and- 101 x 11 ------------------- 1 0 1 1 0 1 x --------------------- 1 1 1 1 to find the origin, find out how many are to the right of origin in unreversed signal... in this case it is 3.. so our convolution sum in 1 1 1 1 , the signal starts at -1 "Jane" <lunaliu3@yahoo.com> wrote in message news:dc1o5i$10k$1@news.Stanford.EDU...> Hi, > > Does anybody have the fastest method (using paper and pencil) to calculate > the convolution: > > y[n]=x[n]*h[n] > > where x[n]=u[n-3] - u[n-14], h[n]=u[n-5] - u[n-8], where u[n] is the step > function, u[n]=1 for n>=0, and u[n]=0 for n<0. > > Can you do it in 2 minutes? > >
"Raghavendra Mahuli" <raghavendra.ma@in.bosch.com> wrote in message news:dcpnam$1co$1@ns2.fe.internet.bosch.com...> Convolution is similar to long-multiplication which we learnt in school... > so for ease of understanding, take signals 101 and 11 where both start > from > origin. now reverse 11. and- > > 101 x 11 > ------------------- > 1 0 1 > 1 0 1 x > --------------------- > 1 1 1 1 > > to find the origin, find out how many are to the right of origin in > unreversed signal... in this case it is 3.. > > so our convolution sum in 1 1 1 1 , the signal starts at -1I'm intrigued but don't understand your notation. Can you elaborate please? What happens if the sequence isn't single-bit? Fred
Reply by ●August 4, 20052005-08-04
Fred Marshall wrote:> "Raghavendra Mahuli" <raghavendra.ma@in.bosch.com> wrote in message > news:dcpnam$1co$1@ns2.fe.internet.bosch.com... > >>Convolution is similar to long-multiplication which we learnt in school... >>so for ease of understanding, take signals 101 and 11 where both start >>from >>origin. now reverse 11. and- >> >> 101 x 11 >>------------------- >> 1 0 1 >>1 0 1 x >>--------------------- >>1 1 1 1 >> >>to find the origin, find out how many are to the right of origin in >>unreversed signal... in this case it is 3.. >> >>so our convolution sum in 1 1 1 1 , the signal starts at -1 > > > I'm intrigued but don't understand your notation. Can you elaborate please? > > What happens if the sequence isn't single-bit? > > Fred > >Multiplying two numbers is the same as convolving the coefficients of two polynomials. The base is immaterial. In algebraic terms: (aB^2 + bB + c )(xB^2 + yB + z) evaluates to axB^4 (ay+bx)B^3 + (az+by+cx)B^2 + (bz+cy)B + cz just as conv( [a b c] , [x y z] ) evaluates to [a ay+bx az+by+cx bz+cy c] It doesn't matter if the base B is 2 (as in the previous example), 10 (as in decimal numbers), or 4294967296 (as might be useful for an extended precision integer library) -- Mark Borgerding
Reply by ●August 5, 20052005-08-05
"Mark Borgerding" <mark@borgerding.net> wrote in message news:ouAIe.45458$B52.11261@tornado.ohiordc.rr.com...> Fred Marshall wrote: >> "Raghavendra Mahuli" <raghavendra.ma@in.bosch.com> wrote in message >> news:dcpnam$1co$1@ns2.fe.internet.bosch.com... >> >>>Convolution is similar to long-multiplication which we learnt in >>>school... >>>so for ease of understanding, take signals 101 and 11 where both start >>>from >>>origin. now reverse 11. and- >>> >>> 101 x 11 >>>------------------- >>> 1 0 1 >>>1 0 1 x >>>--------------------- >>>1 1 1 1 >>> >>>to find the origin, find out how many are to the right of origin in >>>unreversed signal... in this case it is 3.. >>> >>>so our convolution sum in 1 1 1 1 , the signal starts at -1 >> >> >> I'm intrigued but don't understand your notation. Can you elaborate >> please? >> >> What happens if the sequence isn't single-bit? >> >> Fred >> >> > > Multiplying two numbers is the same as convolving the coefficients of two > polynomials. The base is immaterial. > > In algebraic terms: > (aB^2 + bB + c )(xB^2 + yB + z) > evaluates to > axB^4 (ay+bx)B^3 + (az+by+cx)B^2 + (bz+cy)B + cz > > just as > conv( [a b c] , [x y z] ) > evaluates to > [a ay+bx az+by+cx bz+cy c] > > It doesn't matter if the base B is 2 (as in the previous example), 10 (as > in decimal numbers), or 4294967296 (as might be useful for an extended > precision integer library) > > -- Mark BorgerdingThat's really interesting! I think you meant ax and cz tho... Now, back to the OP's question. I'm wondering how this approach makes convolution *fast* with pencil and paper. That's not obvious to me. Fred
Fred Marshall wrote:> "Mark Borgerding" <mark@borgerding.net> wrote in message > news:ouAIe.45458$B52.11261@tornado.ohiordc.rr.com... > > Fred Marshall wrote: > >> "Raghavendra Mahuli" <raghavendra.ma@in.bosch.com> wrote in message...> > Multiplying two numbers is the same as convolving the coefficients of two > > polynomials. The base is immaterial. > > > > In algebraic terms: > > (aB^2 + bB + c )(xB^2 + yB + z) > > evaluates to > > axB^4 (ay+bx)B^3 + (az+by+cx)B^2 + (bz+cy)B + cz > > > > just as > > conv( [a b c] , [x y z] ) > > evaluates to > > [a ay+bx az+by+cx bz+cy c] > That's really interesting! > I think you meant ax and cz tho...Yes. Good catch. The first and last term should be ax,cz. I was just checking to see if you were awake ;)> > Now, back to the OP's question. I'm wondering how this approach makes > convolution *fast* with pencil and paper. That's not obvious to me.Beats me. I was just commenting on an interesting side thread. I think it's pretty cool: some of the places convolution pops up. Something I noted about statistics, but haven't actually proven ( or perhaps remembered): adding together two or more random variables yields a probability distribution function (pdf) that is the convolution of the constituent pdfs. That led me to think that perhaps the quality that psychologists try to quantify as IQ is given its Gaussian distribution by the sum of a large number of more uniformly distributed factors. Just as repeatedly convolving a rectangular pulse with itself yields a Gaussian pulse, adding together many uniformly distributed random variables yields a Gaussian distributed rv. -- Mark Borgerding
Reply by ●August 6, 20052005-08-06
"Fred Marshall" <fmarshallx@remove_the_x.acm.org> schrieb im Newsbeitrag news:Ro2dnVQxgIhfmGzfRVn-hg@centurytel.net...> > "Raghavendra Mahuli" <raghavendra.ma@in.bosch.com> wrote in message > news:dcpnam$1co$1@ns2.fe.internet.bosch.com... > > Convolution is similar to long-multiplication which we learnt inschool...> > so for ease of understanding, take signals 101 and 11 where both start > > from > > origin. now reverse 11. and- > > > > 101 x 11 > > ------------------- > > 1 0 1 > > 1 0 1 x > > --------------------- > > 1 1 1 1 > > > > to find the origin, find out how many are to the right of origin in > > unreversed signal... in this case it is 3.. > > > > so our convolution sum in 1 1 1 1 , the signal starts at -1 > > I'm intrigued but don't understand your notation. Can you elaborateplease?> > What happens if the sequence isn't single-bit? > > Fred > >What he wanted to say was: a _multiplication_ of (integer) Numbers equals to a _convolution_ of its digits. in decimal: 11 x 11= 11 + 11 ----- 121 121 x 121 = 121 +_242 +__121 ------- 14641 Got the picture? This was actually an auto-convolution (Convolution of a signal with itself) resulting in a Gaussian Bell-curve afer a few steps. just do it with 14641 x 14641 and 'forget' the decimal carriage (allowing digits higher than 9 per column) and you'll see But this is not the fastest but the slowest method to do a convolution (for a pc). For human beings it may be the fastest method because i don't think a FFT is easier to write on paper. or take 12 x 2001. think the first number as the signal and the second as the impulse giving 24012.
