dskinit code
Started by bashee August 4, 2005
Hello there,
can any one post the inicialization code of the C6713 DSK "...dskinit.c"
that comes with the book
"Digital Signal Processing and Applications with the C6713 and C6416 DSK"
by Rulph Chassaing. I don't have the cd because I lost my laptop with the
cd and all the code that I made. Now I have to do everthing again...
Thanks a lot.
This message was sent using the Comp.DSP web interface on
www.DSPRelated.com
>Hello there, >can any one post the inicialization code of the C6713 DSK "...dskinit.c" >that comes with the book >"Digital Signal Processing and Applications with the C6713 and C6416
DSK"
the
>cd and all the code that I made. Now I have to do everthing again... >Thanks a lot. > > > >This message was sent using the Comp.DSP web interface on >www.DSPRelated.com >
I have the CD and files, let me know, I may be able to get them to you if you still need them.
>>Hello there, >>can any one post the inicialization code of the C6713 DSK
"...dskinit.c"
>>that comes with the book >>"Digital Signal Processing and Applications with the C6713 and C6416 >DSK" >>by Rulph Chassaing. I don't have the cd because I lost my laptop with >the >>cd and all the code that I made. Now I have to do everthing again... >>Thanks a lot. >> >> >> >>This message was sent using the Comp.DSP web interface on >>www.DSPRelated.com >> > >I have the CD and files, let me know, I may be able to get them to you
if
>you still need them. > > >
>>>Hello there, >>>can any one post the inicialization code of the C6713 DSK >"...dskinit.c" >>>that comes with the book >>>"Digital Signal Processing and Applications with the C6713 and C6416 >>DSK" >>>by Rulph Chassaing. I don't have the cd because I lost my laptop with >>the >>>cd and all the code that I made. Now I have to do everthing again... >>>Thanks a lot. >>> >>> >>> >>>This message was sent using the Comp.DSP web interface on >>>www.DSPRelated.com >>> >> >>I have the CD and files, let me know, I may be able to get them to you >if >>you still need them. >>
Hey, the following code has been copied from the file. //C6713dskinit.c Includes functions from TI in the C6713 CSL and C6713DSK BSL #include "C6713dskinit.h" #define using_bios //if BIOS don't use top of vector table extern Uint32 fs; //for sampling frequency void c6713_dsk_init() //dsp-peripheral initialization { DSK6713_init(); //call BSL to init DSK-EMIF,PLL) hAIC23_handle=DSK6713_AIC23_openCodec(0, &config);//handle(pointer) to codec DSK6713_AIC23_setFreq(hAIC23_handle, fs); //set sample rate MCBSP_config(DSK6713_AIC23_DATAHANDLE,&AIC23CfgData);//interface 32 bits toAIC23 MCBSP_start(DSK6713_AIC23_DATAHANDLE, MCBSP_XMIT_START | MCBSP_RCV_START | MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC, 220);//start data channel again } void comm_poll() //added for communication/init using polling { poll=1; //1 if using polling c6713_dsk_init(); //init DSP and codec } void comm_intr() //for communication/init using interrupt { poll=0; //0 since not polling IRQ_globalDisable(); //disable interrupts c6713_dsk_init(); //init DSP and codec CODECEventId=MCBSP_getXmtEventId(DSK6713_AIC23_codecdatahandle);//McBSP1 Xmit #ifndef using_bios //do not need to point to vector table IRQ_setVecs(vectors); //point to the IRQ vector table #endif //since interrupt vector handles this IRQ_map(CODECEventId, 11); //map McBSP1 Xmit to INT11 IRQ_reset(CODECEventId); //reset codec INT 11 IRQ_globalEnable(); //globally enable interrupts IRQ_nmiEnable(); //enable NMI interrupt IRQ_enable(CODECEventId); //enable CODEC eventXmit INT11 output_sample(0); //start McBSP interrupt outputting a sample } void output_sample(int out_data) //for out to Left and Right channels { short CHANNEL_data; AIC_data.uint=0; //clear data structure AIC_data.uint=out_data; //32-bit data -->data structure //The existing interface defaults to right channel. To default instead to the //left channel and use output_sample(short), left and right channels are swapped //In main source program use LEFT 0 and RIGHT 1 (opposite of what is used here) CHANNEL_data=AIC_data.channel[RIGHT]; //swap left and right channels AIC_data.channel[RIGHT]=AIC_data.channel[LEFT]; AIC_data.channel[LEFT]=CHANNEL_data; if (poll) while(!MCBSP_xrdy(DSK6713_AIC23_DATAHANDLE));//if ready to transmit MCBSP_write(DSK6713_AIC23_DATAHANDLE,AIC_data.uint);//write/output data } void output_left_sample(short out_data) //for output from left channel { AIC_data.uint=0; //clear data structure AIC_data.channel[LEFT]=out_data; //data from Left channel -->data structure if (poll) while(!MCBSP_xrdy(DSK6713_AIC23_DATAHANDLE));//if ready to transmit MCBSP_write(DSK6713_AIC23_DATAHANDLE,AIC_data.uint);//output left channel } void output_right_sample(short out_data) //for output from right channel { AIC_data.uint=0; //clear data structure AIC_data.channel[RIGHT]=out_data; //data from Right channel -->data structure if (poll) while(!MCBSP_xrdy(DSK6713_AIC23_DATAHANDLE));//if ready to transmit MCBSP_write(DSK6713_AIC23_DATAHANDLE,AIC_data.uint);//output right channel } Uint32 input_sample() //for 32-bit input { short CHANNEL_data; if (poll) while(!MCBSP_rrdy(DSK6713_AIC23_DATAHANDLE));//if ready to receive AIC_data.uint=MCBSP_read(DSK6713_AIC23_DATAHANDLE);//read data //Swapping left and right channels (see comments in output_sample()) CHANNEL_data=AIC_data.channel[RIGHT]; //swap left and right channel AIC_data.channel[RIGHT]=AIC_data.channel[LEFT]; AIC_data.channel[LEFT]=CHANNEL_data; return(AIC_data.uint); } short input_left_sample() //input to left channel { if (poll) while(!MCBSP_rrdy(DSK6713_AIC23_DATAHANDLE));//if ready to receive AIC_data.uint=MCBSP_read(DSK6713_AIC23_DATAHANDLE);//read into left channel return(AIC_data.channel[LEFT]); //return left channel data } short input_right_sample() //input to right channel { if (poll) while(!MCBSP_rrdy(DSK6713_AIC23_DATAHANDLE));//if ready to receive AIC_data.uint=MCBSP_read(DSK6713_AIC23_DATAHANDLE);//read into right channel return(AIC_data.channel[RIGHT]); //return right channel data }
